Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-05-2015, 04:31 PM | #2493 |
There is both an OEM crash and camber bolt. We stock both. Crash bolts are 14mm, while the camber bolt is a 14mm with excentric lobe.
05-05-2015, 04:35 PM | #2494 | |
Depending on the track, I might sacrifice some power for more damper... The LSD is a steal at 1 point. |
05-05-2015, 04:35 PM | #2495 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
The Following User Says Thank You to finch1750 For This Useful Post: | CSG Mike (05-05-2015) |
05-05-2015, 04:49 PM | #2496 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Improvement wise, I'm mostly looking for some adjustability when I go on trackdays. If you want specifics, I'm mostly looking for better turn-in and moving the bias a little bit more towards oversteer, hence the camber bolts and stiffer rear sway bar. Just mostly curious what options you guys might recommend. Quote:
The Following User Says Thank You to BigFatFlip For This Useful Post: | CSG Mike (05-05-2015) |
05-05-2015, 04:53 PM | #2497 | |
05-05-2015, 04:56 PM | #2498 |
@BigFatFlip
I wouldn't use the tires to raise the car toooo much...it could start feeling sloppy. Just a set of Koni Yellow adjustable dampers would be one way to start. You get a pretty decent shock with some rebound adjustability. Add the FRS rear springs for a little more rear rate without a drop. Add some bushings. If you really wanted to, you could get coilovers (some will be okay with a 10mm drop) and then add some spacers to the top to get you back up to stock height without the risk of topping out the shock by running it out of it's intended range (and still have some droop). But I'm not sure that's the route I would take. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | BigFatFlip (05-05-2015) |
05-05-2015, 05:11 PM | #2499 | |
Off Topic
05-05-2015, 05:20 PM | #2500 | |
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post: | CSG Mike (05-05-2015), gramicci101 (05-05-2015) |
05-05-2015, 05:56 PM | #2501 | |
Off Topic
How thick are those spacers and what are they made of? I would think that you would need a significant amount of lateral stress right at the mounting points to cause those to fail, and when they did it would be because of the bolts shearing more than anything else. My question then is that given the A-frame shape of the front LCA, and the A-frame shape of the rear LCA/trailing arm combo, how much lateral stress is seen right at the top hats anyways? The shape of the arms prevent the strut from moving too much front to back or side to side, and the actual top mounts would absorb what little movement there is just like they do now. The front rotates around the steering axis, but that's handled by the bearing in the top mount. To generate that level of stress in just the right direction at just the right spot would require a pretty catastrophic event anyways. I've seen Jeeps snap body lift kits, but that's because you've got the entire weight of the body mounted on eight relatively small diameter pucks with single bolts and at least four inches of leverage on them, which makes it easier to push them over and snap the bolts. These seem a lot more stable. They're much shorter, wider, and there are more bolts per spacer, which would keep it from twisting and breaking. Keep in mind, I'm not a mechanical engineer or suspension expert, that's just what immediately came to mind. But people run tall wheel spacers all the time with no issues, and those put a lot more shearing stress directly onto the spacer than this would. If I am wrong, I'd like it if someone could explain why so I could learn. |
05-05-2015, 06:22 PM | #2502 | |
For not being a mechanical engineer/suspension expert, you are quite intuitive You are correct, the chance of failure is pretty small. My statement was more towards the extension of the studs which come with the kit to make up for the thicker spacers. I would guess that extending the studs adds more sheer force on them (like a lever arm) and may be multiplied during high stress situations, compared to the stock placement. Granted, I do still plan on tracking the car once in a while, so hence my hesitation. |
05-05-2015, 06:35 PM | #2503 | |
Off Topic
05-06-2015, 10:34 AM | #2504 |
Thanks
How important is blue loctite on camber plate. Raceseng calls for it.
Also it says to "grease" a few areas. I have silicone paste and also grease in my grease gun for zerk fittings. Which to use or something else?
05-06-2015, 10:44 AM | #2505 | |
Drives: 2015 Series.Blue BRZ
The Following User Says Thank You to ScionOfHorus For This Useful Post: | BigFatFlip (05-06-2015) |
05-06-2015, 10:57 AM | #2506 |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
