Old 02-09-2013, 01:09 PM   #2493
Alienate
Drives: 2013 Scion FRS
Originally Posted by DF-Aero View Post
all this noise everybody is talking about! can someone explain that noise more? if its the same im hearing?
Hold up a second. You DON'T have the same problem as us. This thread is for people who DO have a CEL and rough idle.
You don't. Go to a Dealer and let them examine YOUR car before you have worse problems. You have a WARRANTY.... Use it!
Scionara to you
Alienate is offline   Reply With Quote
Old 02-10-2013, 06:56 PM   #2494
jrodz09
Drives: Subaru BRZ Lmtd
Well update on my CEL situation. Initially the Puente Hills mechs told me it was a "hard code" for a stability control issue. Apparently that was not the case, the code that was stored was a P0512 a starter circuit error. Pretty much told me it must of happened cause someone previously held in the push start button too long several times and caused that code to pop up on me. Might be true, who knows. I did get the car with 100 miles of "test drive" miles. What can you do about that? Nothing. Anyways well that closes my case. Not CEL code since that time. So I must say I'm rather happy at the end.
jrodz09 is offline   Reply With Quote
The Following User Says Thank You to jrodz09 For This Useful Post:
Marrk (02-10-2013)
Old 02-14-2013, 05:00 PM   #2495
mgobrz
Drives: 2013 GBS Subaru BRZ 6MT
Originally Posted by ftc~brz View Post
no leaks checked and double checked its not a oil smell. Russell noticed too last time he was in my car. Smells like a belt but no signs of obvious wear also can't smell it outside checked under hood and around when it happens. Smell is intermittent and noticed after cel repair under normal driving conditions when heat is on. (But then my 1st cel was 70 miles.) I'm at 6200 now. I posted it hear b/c I wanted to make sure it had nothing to do with my parts replace. If it ends up a separate issue I will start thread elsewhere. =)
I am having the same "issue" and smell. It seems to be coming from the driver side of the engine. I have about 2600 miles on my car.
mgobrz is offline   Reply With Quote
The Following User Says Thank You to mgobrz For This Useful Post:
ftc~brz (02-15-2013)
Old 02-17-2013, 10:44 AM   #2496
regal
Originally Posted by foxhu View Post
Went in for the ECM recall(01/31) for about 10 min and everything is set hopefully the light doesn't come on XD
I got the CEL 5 miles of the dealer lot, the 5k miles later the SLP light, finally the recall letter. Took it in, and the dealer replaced the ECU, now the throttle seems not as responsive almost a lag as i revs even in neutral the new ECU seems to have less timing advance. Anyone else notice this ?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
The Following User Says Thank You to regal For This Useful Post:
Marrk (02-23-2013)
Old 02-17-2013, 12:21 PM   #2497
mobybrz
Drives: White 2013 BRZ
I have NOT gotten the CEL light but I HAVE noticed this on my car, along with a slight idle wander. It was something I didn't notice on the BRZ I rode/drove back in August. My car had a much later build date I think (bought it this month straight off the boat/truck). I am convinced something changed in the factory ECU calibration. It's not a big deal in general, but the tendency is very annoying in city traffic.
mobybrz is offline   Reply With Quote
Old 02-19-2013, 10:08 PM   #2498
brillo
Drives: 2013 Firestorm FR-S
What is the serial # on the most recent ECU revision?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 02-19-2013, 10:27 PM   #2499
Yruyur
Yruyur's Avatar
Im number 9 on the list. Im up to 21,000 miles now. Still have a rough idle and surging especially when the ac is on. My car has been considered a lemon by toyota not only for this issue. So hopefully the next one wont have the cel as well as the other issues.
Sent from my GT-P3113 using Tapatalk 2
The Following 2 Users Say Thank You to Yruyur For This Useful Post:
ftc~brz (02-21-2013), Marrk (02-19-2013)
Old 02-19-2013, 11:03 PM   #2500
Marrk
Drives: Honda Fit
Let us know, if not in this thread then in a separate one, how the replacement of the car goes. I'd like to know about the process involved and whether you were treated well by the mfr. and the dealer. Good luck.
Marrk is offline   Reply With Quote
The Following User Says Thank You to Marrk For This Useful Post:
ftc~brz (02-20-2013)
Old 02-20-2013, 02:18 PM   #2501
ftc~brz
Done
Drives: WRB BRZ
took it in monday got it back today with a nice crease and a chip of paint missing down to metal that was NOT there when I dropped it off. I'm now waiting on parts for other minor crap and didn't even address the burning smell. Just waiting for my cel to come back and make my day. LIVID
ftc~brz is offline   Reply With Quote
Old 02-21-2013, 09:12 AM   #2502
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Have you checked the skid plate underneath the engine? Someone stated that the skid plate sits too close to the engine and that there's a little opening in the plate, where debris gets in and just sits there and burns, which then, releases a smell into the cabin of the vehicle.
Eurasianman is offline   Reply With Quote
Old 02-21-2013, 09:36 AM   #2503
ftc~brz
Done
Drives: WRB BRZ
Yes. It was clean
Old 02-22-2013, 09:32 PM   #2504
Redzilla
Redzilla's Avatar
Drives: FIRESTORM RED AT
yes me too.
Redzilla is offline   Reply With Quote
Old 02-23-2013, 04:14 PM   #2505
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Mine seems to have a bit of a miss on initial start up. It goes away after a few minutes. I described it as a bit of a hiccup but my dad informed me it's definitely a miss.
Nevermore is offline   Reply With Quote
Old 02-24-2013, 07:11 PM   #2506
typeray12
typeray12's Avatar
Drives: 2011 STi/2013 BRZ
2013 BRZ
typeray12, BRZ, 300 Miles, 6029XX, In shop for 3 days, CA U.S.
Drove it home from the dealer, VSC and CEL came on along with rough idle. Took it right back to Subaru of Ontario.
This is my second Subaru to cause me problems. First one was my STi with steering rack whining noise that developed right after I bought it.
typeray12 is offline   Reply With Quote
The Following User Says Thank You to typeray12 For This Useful Post:
eurospeed (03-18-2013)
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 06:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 10:00 AM
