Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-03-2015, 06:46 AM | #2479 |
Drives: World Rally Blue BRZ
Don't want to start a new topic for this, I hope this is an appropriate place to ask this.
What's the length of the stock front endlink? Thanks |
05-05-2015, 01:59 PM | #2480 | |
Drives: 2004 Toyota RAV-4 5M
So I'm looking into taking a serious run at NASA East Coast Nationals in TTD either this year or next, and in order to fully optimize my car to the rules I've come to realize that I will need the 3 extra points that my Ohlins R&T setup is costing me (shaft diameter > 40mm and inverted front shocks). The Ohlins were great on both the street and track (especially after getting them custom revalved and sprung for the track), but those 3 points +1 more point for going back to stock intake gets me back onto Hoosier R7s.
Spring rates and valving will most likely end up being custom. Car will be run with stock sway bars and stock control arms and the primary tire will be 225/40R17 Hoosier R7. |
05-05-2015, 02:33 PM | #2481 | |
JRZ if you can fit them in the budget. Our RCE T2 clubsports would work well too at a lower cost (built by KW, starting from KW Clubsports but at a lower cost). Our T3 Clubsports would be great but have a piggyback canister. Give us a call if you'd like to talk. We're in MD as well and have run many set-ups on our BRZ. We also helped JRZ with some development work and testing with their coilovers for BRZ early on. Myles will have their newer RS line on his 2015 WRX very soon if you want a ride. - Andy |
05-05-2015, 02:34 PM | #2482 |
05-05-2015, 03:15 PM | #2483 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Wow, I can't believe I just read through all 113 pages (took me a couple weeks). Thank you @CSG Mike and @Racecomp Engineering for fielding everybody's questions! I have learned alot.
Now, I belong to the very small group of wanting/needing stock ride height (maybe even higher) thanks to the area I live in. I've been very happy with the stock suspension but have been trying to find more adjustable options. I don't claim to know what I'm doing so I've been leaning towards a single adjustable set-up, particularly the Ohlins R&T and the Bilstein B16's. Any other recommendations? If it ain't broke don't fix it (ie stay stock)? Now for the pertinent info everyone seems to ask: 90% street (including canyon/twisties) 10% track day I'm currently on 225/45-17 RE11A's (to eek out a few mm of additional height) Only other suspension mod is a WRX rear sway bar (16mm) and front camber bolts cheers! -Bryan |
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post: | CSG Mike (05-05-2015), Racecomp Engineering (05-05-2015) |
05-05-2015, 03:20 PM | #2484 | |
Glad to hear that people are reading through this full thread. Why the desire to stay stock height or higher? What type of improvement are you looking for specifically? - Andrew |
05-05-2015, 03:26 PM | #2485 | |
05-05-2015, 03:28 PM | #2486 | |
You can also get a 235/45/17 in some tires to get even MORE height. |
The Following User Says Thank You to CSG Mike For This Useful Post: | BigFatFlip (05-05-2015) |
05-05-2015, 03:43 PM | #2487 |
Drives: Hot Lava
Is there any significant difference between the OEM crash bolt and the SPC Camber Bolt Kit? Does one add more camber than the other? Or is one safer to use than the other?
05-05-2015, 03:51 PM | #2488 | |
The Following 2 Users Say Thank You to D_Thissen For This Useful Post: | Racecomp Engineering (05-05-2015), SimplePortal (05-05-2015) |
05-05-2015, 03:55 PM | #2489 | |
My theoretical setup with 3 point dampers: +5 Exhaust (header/overpipe/frontpipe) +3 Dampers +2 Springs +6 Tires (225 Hoosier R7) +2 BBK (I know everyone says that BBK isn't worth the points in TT, but I think my AP Sprint Kit might still be my favorite mod to the car) +1 LSD (Cusco RS) +0 E85 tune ----------------------------------- 19 points total (max in class) and I would probably be bumping right up against the max power to weight ratio for TTD as well. |
05-05-2015, 04:02 PM | #2490 | |
I think I might have to give you guys a call when I'm ready to make the jump. JRZ RS1's are looking like it might be the one to go for, but still want to look around a bit more and I would need to sell my Ohlins first. |
The Following User Says Thank You to ja1217 For This Useful Post: | Racecomp Engineering (05-05-2015) |
05-05-2015, 04:02 PM | #2491 | |
- Andy |
05-05-2015, 04:10 PM | #2492 |
Some bushings are. I've already done engine mounts, whiteline rear crossmember inserts, shift bushing and diff cradle. Other free mods include DSS CF driveshaft, ACT Prolite clutch/flywheel. I'm probably forgetting some others too.
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
