go_a_way1, MisterSheep
Old 11-13-2025, 05:36 PM   #24795
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by Th3rdSun View Post
The dealership decided to do it. I could've refused,like I always have,but they replaced all seals and gaskets while they were in there,which significantly reduced the cost of labor for that service.
Just keep us apprised. Hopefully you're part of the majority that comes out fine. I'm sure it'll be totally fine
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following User Says Thank You to DarkPira7e For This Useful Post:
Th3rdSun (11-14-2025)
Old 11-14-2025, 10:51 AM   #24796
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
I absolutely will. I think this dealership was competent. I never wanted to get the valve springs done early on because I didn't trust Toyota techs working on my boxer engine.I think they've been doing enough of them now that I think they know what they're doing.
I did called my local Subaru dealership early on and they said that they wouldn't work on my FR-S,which I thought was very odd,considering that even though it has Scion badges,those badges,and almost every single part is stamped with Fuji Heavy Industries on it.
Anyway,been driving it for just under a week now and everything seems like it's back to nomal.It's a daily driver and I don't really push it too hard,so I'm not too worried.
Th3rdSun is offline   Reply With Quote
Old 11-14-2025, 11:00 AM   #24797
I absolutely will. I think this dealership was competent. I never wanted to get the valve springs done early on because I didn't trust Toyota techs working on my boxer engine.I think they've been doing enough of them now that I think they know what they're doing..
Well, in the end, this didn't matter. The gasket design was unique, and Toyota actually had more of them than Subaru since Toyota sold more of the "offending" ones.
Yes, there were a handful that had issues, but for the most part nearly all were done correctly.
I had mine done for the same reason you stated, it provided an opportunity to have other labor covered. I had several things done (spark plug replacement, etc) for the cost of parts since they were already doing the work.
Th3rdSun (11-17-2025)
Old 11-14-2025, 02:41 PM   #24798
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
That makes much more sense, thanks
smackrel is offline   Reply With Quote
The Following User Says Thank You to smackrel For This Useful Post:
Old 01-25-2026, 04:11 PM   #24799
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Installed the vland V3 LED headlights, and restored the fog lights that were very oxidated.
Sent from my Pixel 10 Pro XL using Tapatalk
Rican_D is offline   Reply With Quote
The Following 2 Users Say Thank You to Rican_D For This Useful Post:
blsfrs (01-26-2026), Dadhawk (01-26-2026)
Old 01-26-2026, 06:20 PM   #24800
Rican_D
Rican_D's Avatar
Trying to figure out how to disable the DRL to stop it from turning on the high beams
