Old 11-25-2019, 11:34 PM   #2465
vladniko86
vladniko86's Avatar
Drives: FRS
Finally got everything mounted. Wish it wasn't night so I could take some proper pictures. Anyways this thing feels like a boat in the rear and I think it has to do with these funky control arms I bought to camber the rear in
https://rover.ebay.com/rover/0/0/0?m...2F172482094142
Anyways I'll align it and figure it out
Avid av20 +38 18x9.5
Michelin Sport AS3+
245/35 Front
275/35 Rear
vladniko86 is offline   Reply With Quote
The Following User Says Thank You to vladniko86 For This Useful Post:
Leonardo (11-26-2019)
Old 11-25-2019, 11:55 PM   #2466
vladniko86
vladniko86's Avatar
Drives: FRS
Those guys on eBay are just reselling these guys.
https://www.privatelabelmfg.com/prod...pw-rlca-sf.htm
I'm thinking of putting the bigger bushings on instead of the small swiveling one with the black extensions.
Also probably not a bad idea to get toe arms as one of mine is almost seized
Old 11-26-2019, 10:40 AM   #2467
Vital
Drives: 2015 BRZ
It feels like a boat because you paired heavy wheels which are pretty wide with wide tires and on top of that its staggered...
Vital is offline   Reply With Quote
Old 11-26-2019, 10:41 AM   #2468
vladniko86
vladniko86's Avatar
Drives: FRS
It’s a lot better now, I used the stiff wide bushings instead of the thin ones.
Vital (11-26-2019)
Old 11-27-2019, 01:41 PM   #2469
vladniko86
vladniko86's Avatar
Drives: FRS
So I did my alignment today and figured out what the boat feeling / oversteer was about. Had .30 and .45 toe out from my new control arms. Made them .1 toe in and it feels so much better!
The Following 2 Users Say Thank You to vladniko86 For This Useful Post:
Leonardo (11-27-2019), StraightOuttaCanadaEh (11-27-2019)
Old 12-02-2019, 11:26 AM   #2470
Glitchy86
Drives: Red 86
Can someone pls advise me if I can put 245/45R17 without fuckin my gearing ratio coz I cant seem to find 245/40R17 where I live. My wheel size ia 17×9 +38
Sent from my SM-G975F using Tapatalk
Glitchy86 is offline   Reply With Quote
Old 12-05-2019, 03:40 PM   #2471
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Generally speaking, a diameter difference of + or - 3% is acceptable.
215/45/17 is 24.6" diameter (stock size)
225/45/17 is 25.0" diameter +1.6%
235/45/17 is 25.3" diameter +2.8%
255/40/17 is 25.0" diameter +1.6%
245/45/17 is 25.7" diameter +4.5%
For size comparison, in the pics above of the 275/35/18 on the rear has a diameter of 25.6"
I have seen a few guys run a 245/45/17 without rubbing on a 17X9 +38. (rubbing will also depend on how much you are lowered)
It will change your gearing though. For DD, I don't think it would be that bad. For track, 245/45/17 is not ideal.
I LIKE TIRES!
The Following 4 Users Say Thank You to Leonardo For This Useful Post:
Glitchy86 (12-05-2019), JD001 (04-13-2020), phm14 (04-22-2020), Spankopotomous (12-17-2020)
Old 04-12-2020, 11:57 PM   #2472
FRSK1RK
FRSK1RK's Avatar
Drives: 2013 SCION FR-S
adding some pics of my 2013s newly member
17x9. 245/40. +40 -- sweet spot no rubbing or fender roll, TANABE REVEL COILS ✌
IG: @k1rkky
2013 FR-S ARGENTO
FRSK1RK is offline   Reply With Quote
The Following 3 Users Say Thank You to FRSK1RK For This Useful Post:
HaXx (04-24-2020), JD001 (04-13-2020), new2subaru (04-26-2020)
Old 04-21-2020, 07:16 PM   #2473
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
17x9 +35 Enkei RPF1
255/40 Firehawk Indy 500 tires.
Tein Flex A coilovers, -2.55 camber in the front, -1.25 in the rear.
kevaughan is offline   Reply With Quote
The Following User Says Thank You to kevaughan For This Useful Post:
JD001 (04-24-2020)
Old 04-22-2020, 08:53 PM   #2474
rt
@rayhere
rt's Avatar
^ Hello fellow Torontonian.
Current setup is 17x9.5 +36 TE37SL vs. 17x9.5 +45 TE37 Saga with 3mm spacers last year. Both sets wrapped in 255/40 and -3.3F/-2.4R for camber. The Sagas rubbed at full lock but no issues with the SLs. Concavity is much better on the SLs and makes the Sagas look flat in comparison.
rt is offline   Reply With Quote
The Following 2 Users Say Thank You to rt For This Useful Post:
JD001 (04-24-2020), Vic4uf (07-11-2020)
Old 04-24-2020, 04:06 PM   #2475
KAR
Drives: Whiteout 6spd
So simple, so clean.. just the way I like em
KAR is offline   Reply With Quote
The Following User Says Thank You to KAR For This Useful Post:
FRSK1RK (05-05-2020)
Old 04-24-2020, 04:08 PM   #2476
KAR
Originally Posted by kevaughan View Post
17x9 +35 Enkei RPF1
So aggressive, I like!
kevaughan (05-03-2020)
Old 05-04-2020, 05:47 PM   #2477
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
I have the 18x8.5 +35 with 245/35. I think the 245/40 17s like that probably a little better ride still looks good especially if you drop it over an inch.. so props I like it. I don't really want to drop mine over inch because I don't want that much neg camber in the back and toe in. I don't want LCA and links in the back at this time. So my 18s look a little better in that scenario, but they don't ride as good and tires are more expensive
AKITA is offline   Reply With Quote
The Following 2 Users Say Thank You to AKITA For This Useful Post:
FRSK1RK (05-06-2020), SuperTom (05-04-2020)
Old 05-04-2020, 10:50 PM   #2478
WC-BRZ
Drives: Black BRZ
Are these Advan RG-II?
WC-BRZ is offline   Reply With Quote
The Following User Says Thank You to WC-BRZ For This Useful Post:
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
