Old 03-23-2015, 02:24 PM   #2465
bholliday
Drives: 2022 BRZ Premium
How much does the tread width effect the tire performance? I was looking at the Tire Rack's published data on the RE71R and was surprised by the numbers.
215/45/17 - 7.2"
225/45/17 - 7.6"
235/45/17 - 7.7"
245/40/17 - 8.6"
245/45/17 - 8.2"
For the same size tire, the RE71R tread width is significantly less the the ZII* and Rival S
225/45/17: 7.6 (RE71R), 8.2 (ZII*), 8.5 (Rival S)
245/40/17: 8.6 (RE71R), 9.2 (ZII*), 9.1 (Rival S)
I was planning to buy 225/45/17 RE71R, but maybe I should buy something wider?
bholliday is offline   Reply With Quote
Old 03-23-2015, 02:28 PM   #2466
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yeah this all weird since the section width is supposed to be a measurement in mm and universal, but in reality ends up being completely different from one manufacturer to the next.
Old 03-23-2015, 02:52 PM   #2467
bholliday
The Tire Rack shows the section widths to be the same on these tires. But, the tread width varies substantially.
Old 03-23-2015, 02:56 PM   #2468
qoncept
qoncept's Avatar
...and, as I suspected, not even consistent amongst a single tire model (in bholliday's post, each should be ~.4" wider than the last and they aren't).
This makes my buddy's spreadsheet documenting width * grip / cost completely futile. And as I've mentioned in the past, I'm almost positive you can count on tire weights, between manufacturers and even different sizes of the same model tire being inaccurate/imprecise enough to make them useless.
All this, plus the limited scientific evidence suggests to me that you should just pick a tire you like among the "common sense" options we've discussed ad nauseam.
qoncept is offline   Reply With Quote
Old 03-23-2015, 03:26 PM   #2469
Jawnathin
Drives: Toyobaru FRZ
If it'll help, I can stack my RS3 V2s and RE71Rs next to each other and see which stack is taller. They are both 245/40/17s and pinched on 17x7 +42 RPF1s.
Jawnathin is offline   Reply With Quote
Old 03-23-2015, 06:27 PM   #2470
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by simpleisbest View Post
Did you even talk to a Scion dealer prior to writing your post or forming your opinion?
Call your local Scion dealer and ask, or chat with customer service. Talk to someone who will actually look into the database for you and they will all confirm that the PNs are listed in the database as port options. There is nothing "grey" here. Its pretty black/white.
Like I said before, its not about verification, its about documentation from this point. The documentation will surface eventually.
Also, please stop the "careful what you wished for" BS. I didn't wish for it. It was just a reality that no one had previously uncovered. What would rather prefer? This info in the open and clarified in advance or some guy pulling up to you at Nats with these and YOU unprepared?
I dont know about you, but I would rather start dealing with the reality of the now vs crying about "what may be".
Did you bother getting a ruling before declaring "all clear"? You're projecting just a smidge there, and you seem very eager to try and shout down anyone who might dare to question your interpretation of it or expand on the possible implications. That's the point of a discussion forum.
Yes, I talked to a dealer. My dealer is also my region's assistant RE. So, I have pretty ready access and don't need to hope he understands what I'm driving at with the questions, as opposed to some stranger in a call-center. He is looking into it. At first response, yes, they are/were at least available as port options that were, shall we say, poorly advertised.
If you are hunting documentation that will
surface eventually
then yeah, it's still a gray area. If you aren't looking to dive in feet first without the documentation being sought on-hand, it's a gray area. I get that you see it differently, though. When/if settled, legal is legal, though, whether by an inch or a mile. Hair shirts are hairy, but legal hair shirts are legal.
I will grant that I should have phrased "be careful what you wish for" differently. How about this: This may not be a solely/purely beneficial discovery.
As for what I'd prefer? I've said twice now:
Will be interesting to see how this pans out.
And I mean it. I'd prefer to see how this pans out before deciding what's next for me. I can see this going in a few different directions, all with pros and cons. Depending on how those cards change, I'll change how I play my hand.
There are additional relevant questions here that aren't "is it legal." If you don't want to discuss them, then don't. But please don't try to commandeer the whole conversation just because somebody is pointing out that it's not all beer and boobies. Particularly in the fashion in which you do it. That's just disrespectful.
Last, I am quite glad that somebody is trying to address this more proactivley instead of surprising folks. So thanks for volunteering as a test case. Kudos. It's frankly quite wise.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 03-23-2015, 06:36 PM   #2471
xwd
Originally Posted by renfield90 View Post
I get that it's different from a perspective of what options the SEB has available to deal with the situation. There was no way a base Miata could install just the MSR springs because they weren't a line item option, it was a package; so you just move the whole package to a different class and problem solved without affecting base model folks.
My point is that Mazda never once delivered a fully built MSR, despite their documentation that the option package was a port install - in other words, just the documentation saying "this is port installed" was enough to be legal, despite the fact that no port installs ever took place. If the part number existed, the option was technically available for order for 2013, and the part came out in 2013, I'm not sure that's a stretch especially given the supply chain issues you noted.
I know people who have MS-R Miatas delivered as such from Mazda. Chris Fenter is a good friend of mine and his was an original MS-R, he did not do a conversion. That's kind of here nor there however. It will be interesting how all the spring stuff turns out.
Everyone is flocking to the RE71R now, then everyone will probably flock to the Rival-S when it comes out. Even though we are going to softer compounds, they are still a hell of a lot cheaper than Hoosiers. A 245/40/17 A6 is $289/ea. now...
Old 03-23-2015, 06:38 PM   #2472
klittl06
Drives: FRS?
Anyone have recommendations on alignment specs? I dd my car and drive a good amount if that makes a difference.
klittl06 is offline   Reply With Quote
Old 03-23-2015, 08:54 PM   #2473
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
So I am on the stock wheels and need some help/opinions. I have read that 245/40/17s rub a little when running stock wheels. Not something I want to do, nor do I want to buy rpf1s or any other aftermarket wheel. Where do 245/40/17s rub? Has anybody had any rubbing with 235/45/17s?
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 03-23-2015, 09:33 PM   #2474
Jawnathin
245/40 on stock offset rubs on the spring. You can always get spacers. But then you need new wheel studs too.
I don't know about a 235/45 but I think a 235/40 is ok on stock offset.
Old 03-24-2015, 03:02 AM   #2475
cactus
cactus's Avatar
Drives: 13 SWP BRZ
ZIIs rubbed when at full left lock. Mine never rubbed on the spring with crash bolts.
cactus is offline   Reply With Quote
Old 03-24-2015, 07:55 AM   #2476
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
I am assuming this was 235/40/17? Or is it 235/45/17?
Old 03-24-2015, 09:18 AM   #2477
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
He had 245/40/17.
G_Ride is offline   Reply With Quote
Old 03-24-2015, 10:35 AM   #2478
qoncept
qoncept's Avatar
My Kook Z214 245/40/17s didn't rub with as much camber as I could get with crash bolts, but they were very close to the springs. Hit or miss I think. I added 5mm spacers because I had them.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
