Old 12-28-2013, 04:32 AM   #2437
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by xjohnx View Post
Wonder if the innovate one mounts without modification. Hmmm.
If its Sprintex's own intercooler like I have, the horn is taken off but then put back in the same place when the IC brackets are installed.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-28-2013, 09:05 AM   #2438
whataboutbob
AutoX-10/10ths every run
Originally Posted by Sellout View Post
Maybe BSPT is common in Australia?
I'd say yes. [ame="http://en.wikipedia.org/wiki/British_Standard_Pipe"]British Standard Pipe - Wikipedia, the free encyclopedia[/ame]
Build thread:Here
Old 12-28-2013, 09:07 AM   #2439
whataboutbob
@whataboutbob - I too would love the part #'s you up using.
I'll post the part # and specs once I get them.
Build thread:Here
Old 12-28-2013, 09:31 AM   #2440
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Don't really care!
The more relevant question is, "What taper thread standards are used in the automotive world, and what standards are in use on the 86s?"
Here, I've just learned something new: Subaru uses BSPT threads on oil galley plugs and so forth. I don't have info on the 86 specifically, but it's a good bet that it uses BSPT, as well.
So I will concede that there's some logic in Sprintex' design choice. But given the failure rate of these hose connections and their general difficulty to source in the US, I think there's an opportunity here for some really excellent customer support (which was my main point).
Ralph Spoilsport is offline   Reply With Quote
Old 12-28-2013, 02:41 PM   #2441
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Originally Posted by Ralph Spoilsport View Post
Don't really care!
BSPT is used in Japan too. Looks like it's been adopted pretty much everywhere but here.
Asking them to drill and tap the holes for NPT is a little much. They're already realizing that they need to check them and make sure they're tight when they get them from Sprintex. I'd say that's about as far as they should be expected to go in the name of "customer service". They saw a problem and are doing what they can to make it right.
Sellout is offline   Reply With Quote
Old 12-29-2013, 01:06 PM   #2442
Mechazawa
Drives: FR-S, 6MT, White
BSPT is pretty common on cars in general. It should be easy enough to source fittings from mcmaster- carr or the like.
Sent from my SPH-L900 using Tapatalk 2
Mechazawa is offline   Reply With Quote
Old 12-29-2013, 04:45 PM   #2443
xxscaxx
Drives: 2013 SWP BRZ
I was taking a look at the upgrade manual for the intercooler kit, and noticed that the water pump is installed on the same spot that you need to install the hard inlet pipe with the factory OEM Forester oil cooler, like I have installed. I'm purchasing an intercooler kit so I can confirm if it will be an issue installing it on top of that piping or if it needs to be modified, but figured i'd give a heads up in case any other Innovate owner is running the forester cooler like I am.
xxscaxx is offline   Reply With Quote
Old 12-29-2013, 05:24 PM   #2444
whataboutbob
Here's the specs on the pump for anyone who is interested:
http://www.rpc.com.au/pdf/davies_cra...p_brochure.pdf
The plastic fittings can be found here:
http://www.egertonhydraulics.com/sho...ubgroups=3800C
Specifically, you'll need at least one of each of these:
1) N-WES8R 1/4
  • 8mm ID X 1/4" BSPT THREAD
  • NORMA ELBOW TAPER CONNECTOR
2) N-WES10R1/4
  • 10mm ID X 1/4" BSPT THREAD
I just went an measured the OD of the old barbs and they are 8 and 10mm.
I'm currently working with a US company to see if they can order them for me. Here's a link to the site: http://mdmetric.com/
I haven't heard back from them yet to know if they can get them, but I plan to order a few extras from them or the British company once I hear back from them.
Build thread:Here
Old 12-29-2013, 08:52 PM   #2445
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
I posted a page back about having problems with my belt squeaking. All fixed after Sprintex came to my house and swapped the belt and topped up the supercharger oil.
Got to see some goodies on the prototype car which i have to keep secret but i will say that they have hit 311whp with the smaller blower.
It's good to live a suburb away from the company that makes and prototypes this blower.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 12-29-2013, 09:09 PM   #2446
Calum
That Guy
Drives: 2013 asphalt FRS MT
What kind of gas was that?
Old 12-30-2013, 03:41 AM   #2447
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
At the time i didn't think to ask, The car isnt fitted with a flex fuel kit and e85 is very rare here so im hoping 93AKI/98RON. I'll be talking to them further in the new year about it.
He did say the increase over what i have was down to two things the secret thing and tuning that they sat in on to help the tuner here.
They said the secret they have on the prototype should be avaliable to customers "soon" as an add-on like the intercooler has been to the US folks.
I dunno if Innovate has something similar for USDM release but i would imagine so.
Build thread
Old 12-30-2013, 10:31 AM   #2448
whataboutbob
Here's the vendor spec sheet for the platic fittings:
http://normapacific.com/CA2579BB0013...Connectors.pdf
Build thread:Here
Old 12-30-2013, 10:53 AM   #2449
Calum
That Guy
"35 Rape oil (RME)"...rape oil?! o_O
Old 12-30-2013, 10:55 AM   #2450
xjohnx
Grip>Slip
xjohnx's Avatar
Rapeseed-Oil Methyl Ester (replacement for petroleum diesel)
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
