Old 02-09-2015, 10:02 AM   #2423
s2d4
s2d4's Avatar
Originally Posted by nunonuna View Post
Take a look at rpm.
It isn't peak torque?
s2d4 is offline
Old 02-09-2015, 12:11 PM   #2424
nunonuna
nunonuna's Avatar
I don't think so. According to the picture he posted, it indicates that torque numbers are 158.51nm @ 3795 rpm and 182.05 @ 4047 rpm. Correct me if I'm wrong, but it seems it is for the most gain of torque not the peak torque.
nunonuna is offline
Old 02-10-2015, 06:07 AM   #2425
s2d4
s2d4's Avatar
That is still odd since different rpm.
Even so, one curve shows greatest difference/gain and the other go for peak is kind of odd as well, although the stock torque peak is actually higher than tuned.
EDIT: why is the scaling on the torque curve 0-430 when power is 39-129? Especially when torque never gets over 200? Why not 130 to 220?
s2d4 is offline
Old 02-11-2015, 12:33 PM   #2426
h8meh8ers
Drives: 2014 FR-S
anyone have any issues with rattling? just had mine installed with the motiv overpipe and the car just doesn't seem right. getting going from a stop, it seems to have a weird chatter or something at low rpms. then under deceleration from a high rpm, it rattles. anyone have any ideas? i checked the overpipe, and that seems to have plenty of clearance. Also, reving in neutral seems totally fine if that means anything
h8meh8ers is offline
Old 02-11-2015, 12:44 PM   #2427
quicksilver30
quicksilver30's Avatar
Drives: '13 LR BRZ Limited| '07 Jeep GC
Are you using the stock front pipe? If so check the clearance of the front pipe. I was getting a strange rattle when I installed the nameless OP/DP and it was the front pipe hitting the passenger tub. My mistake was not loosening the entire exhaust when I had to remove the header so everything was on a bind.
'13 Lightning Red BRZ
Mods: Grimmspeed Cold Air Intake|FT86SpeedFactory Stage 2 Tune|FT86SpeedFactory Catted header|Nameless Catted and Resonated OP/DP|Perrin Resonated Cat-back|
quicksilver30 is offline
Old 02-11-2015, 12:45 PM   #2428
h8meh8ers
Drives: 2014 FR-S
should've mentioned that. i've got a motiv overpipe and catted front pipe. had the front pipe and speedfactory v1 exhaust installed a few months ago, and they've been great. now today i've got the rest installed and it just seems off
Old 02-11-2015, 01:14 PM   #2429
nunonuna
nunonuna's Avatar
Check the clearance of overpipe. If you look down right above ecu, there is some kind of metal plate(sorry its best I can describe) close to overpipe. I had same rattle right after I installed this header. Once the overpipe gets heat up, it expands and made contact with that piece of metal plate. You can see it better from under the car.
nunonuna is offline
Old 02-11-2015, 02:17 PM   #2430
h8meh8ers
Drives: 2014 FR-S
Thanks, i had already checked in the engine bay around the overpipe, and i can fit my hand all around it and there seems to be good clearance. Maybe it's just lots of extra vibration that i'm not used to?
Old 02-11-2015, 02:18 PM   #2431
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Did you check the Buttfor?
-Jack Burton
tahdizzle is offline
Old 02-11-2015, 05:54 PM   #2432
nunonuna
nunonuna's Avatar
It may not be the same reason, but the gap between overpipe and that metal piece I mention is not wide enough for my hand to be in. I will try to take a picture after work today & post it here.
nunonuna is offline
Old 02-11-2015, 06:44 PM   #2433
kodyo
Drives: Scion FR-S
I have pretty much the same setup with no unusual rattling that the car didn't already have. Could be that removing heat shielding/insulation makes it more apparent, IDK.
kodyo is offline
Old 02-11-2015, 08:46 PM   #2434
nunonuna
nunonuna's Avatar
@h8meh8ers
Here is the photo
Check that area I indicated on second photo.
The gap in the picture is when the engine is hot so over pipe was expanded. When it is cool, the gap is about 1/4". When I had rattling noise the gap was less than 1/8" when cool so when the over pipe got heat up, it made contact with that metal part. Hope it helps
nunonuna is offline
Old 02-12-2015, 08:06 AM   #2435
h8meh8ers
Drives: 2014 FR-S
@h8meh8ers
Here is the photo
Thanks for the pictures. After driving it some more, I think it's just extra noise and vibration associated with the new setup. Also, like Kodyo said, removing the heat shields could remove some of the insulation from the sound.
The car sounds amazing with this new setup, but I don't think it's for me. As a daily driver, it's way too loud for my taste. Probably going to be going back to the old setup with just the motiv front pipe and ft86-speedfactory v1 exhaust.
Old 02-12-2015, 08:21 AM   #2436
nunonuna
nunonuna's Avatar
Im just glad it turned out to be normal~
Maybe to consider for quieter cat back? As other members claims it sounds really great with Q300 for someone prefers quiet exhaust sound. I have Q300 also and it is quiet even with catless front pipe.
nunonuna is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
