Old 05-16-2023, 01:01 PM   #24277
MJones_RB
MJones_RB's Avatar
Originally Posted by Bonburner View Post
Installed new doorstops to stop the door shutting on me.
My doors are always closing on me, even on the slightest incline. Did you replace is with just a new stock part?
MJones_RB is offline   Reply With Quote
Old 05-16-2023, 02:03 PM   #24278
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
New door checks from subaru - new parts number 61124CA001
https://parts.subaru.com/p/68012324/61124CA001.html
Yes, my door stays open to wherever I open it to.
Really easy to swap the part too.
Old 05-16-2023, 05:29 PM   #24279
Jdmjunkie
Drives: Scion FR-S 10 Series
I installed my fire extinguisher mount today.
Jdmjunkie is offline   Reply With Quote
Old 05-16-2023, 05:49 PM   #24280
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Dayum son, what you runnin under the hood that might spontaneously burst into flames?!
Originally Posted by humfrz
I'm old and lazy
Old 05-16-2023, 06:01 PM   #24281
Jdmjunkie
Nothing much.
Old 05-16-2023, 06:08 PM   #24282
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
A boxer, duh
Old 05-16-2023, 06:56 PM   #24283
Clipdat
Proud of BOXER
Clipdat's Avatar
Lol, I didn't know John Visconti was still tuning twins.
I'm old and lazy
Old 05-25-2023, 11:41 PM   #24284
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Been too lazy to update, but today I installed PIAA 85115 330/400 hz horns.
Had a windshield guy inspect my front windshield for chips because the tint shop said I had some chips that needed to be repaired. Turned out I didn't need to get them repaired. I'll get my 70% ceramic windshield tint installed next time I have a day off of work.
I got my rear window retinted (finger started appearing along a defrost wire) with ceramic tints for heat rejection.
Installed new woofers (Kicker PSC65), I picked it because it was the lowest frequency that had 2 ohm impedence at 6.5". I used scotch extreme mount double sided tape to attach it to Scosch SAT6 speaker adapters.
I put on the red stitched padded door speaker trims, but didn't realize I needed to order the speaker grill because the 2013 was one single piece of plastic. So waiting for the grill to come in. I messed up with either the mounting or the wiring, there's some rattle coming out of the passenger's woofer above 85% max volume.
I got my Yonaka catback installed about 2 weeks ago. Really liking these, adds the missing grunt without getting me in trouble. Seems to be mostly in the 80 db's, even up to redline. Which I kind of need seeing how often I hit redline to scoot this slow car around.
Old 05-26-2023, 07:10 PM   #24285
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Swapped out the slave cylinder for the Impreza/Forester unit.
It added pedal weight which is expected but so far the feel is subjectively a bit better.
I have the Mtec assist spring I bet stock spring with this would be perfect.
Old 05-29-2023, 11:22 PM   #24286
Compelica
Compelica's Avatar
Drives: 86 GT
Found a set of 6K springs for my HKS coilovers to replace the rear 4K springs and got them installed.
Had also swapped the shifter springs to GKTech ones, where the company is based in Australia. MTECs would have been prohibitively expensive for the price and shipping to the other side of the world where I live, and MTEC wasn't willing to divulge on their shifter spring rates to estimate the additional stiffness. GKTechs, from them are approximately 25% stiffer over the stock springs.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 05-31-2023, 12:39 PM   #24287
Cedric
Cedric's Avatar
WHAT DID YOU DO TO YOUR FRS TODAY?
Track day at Thunderhill; the Fortune Autos are definitely better than the Flex Zs I had prior. I believe I have the height and dampening settings the way I want it now. Next thing on my list is an AP Racing or Stoptech BBK.
Cedric is offline   Reply With Quote
Old 05-31-2023, 07:56 PM   #24288
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
#nosidemarkergang
I lost mine on T3 at THill West like 7 years ago.
Old 05-31-2023, 09:37 PM   #24289
Ultramaroon
not playing cards
Ultramaroon's Avatar
toofless
Old 06-01-2023, 04:14 AM   #24290
Cedric
Cedric's Avatar
#nosidemarkergang
The ambers looked unappealing anyways
