, dpfarr
Old 06-24-2017, 12:51 PM   #2395
georgiafrsguy
Drives: white 2013 frs
Originally Posted by menikmati View Post
I need to access the high pressure side port of the AC system and it looks to be way too close to the supercharger, anybody have any tips on accessing the port?
I would be doing a full AC recharge and would need the car to be running in order to spin the compressor, so I can't just unbolt the supercharger and leave it floating.
you don't have to have the high side port to properly charge the system. you can do it all from the low side. but that also depends on if you are using and a/c machine. or just cans from the parts store or trying to use a gauge set to add.
georgiafrsguy is offline   Reply With Quote
The Following User Says Thank You to georgiafrsguy For This Useful Post:
menikmati (06-24-2017)
Old 06-24-2017, 03:07 PM   #2396
menikmati
Drives: 2015 BRZ, 2005 STI
I'm in the middle of the process now and I just removed the rearward bolt and loosened the two front-facing AC compressor bolts to inch the compressor out for enough clearance for the high side coupler.
I wanted to have access to the high side port to apply a vacuum to the entire system. I'll just bolt the AC compressor back into place and use the low side port for the actual recharge after applying vacuum.
Thank you for the info.
EDIT:
AC successfully recharged, if I need to top off in the future then the low side port should be sufficient.
menikmati is offline   Reply With Quote
Old 06-27-2017, 07:17 PM   #2397
TRDan
Drives: 2015 BRZ Limited 2005 Toyota Tundra
Has anyone added a larger coolant tank to the intercooler system? Think it would have enough affect to make it worth the work?
TRDan is offline   Reply With Quote
Old 06-29-2017, 12:59 AM   #2398
Gforce
Drives: 2013 Subaru BRZ
It would not or Edelbrock would have done so. Volume of coolant is adequate for the intercooler. Rate of heat rejection is actually higher if temperature is higher. A larger cooling radiator would be the answer if coolant volume were to be insufficient.
Gforce is offline   Reply With Quote
Old 06-29-2017, 09:23 AM   #2399
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
One thing Edelbrock did change is the capacity of the surge tank. V1 was too small and allowed air to be re-introduced back into the system.
http://www.ft86club.com/forums/showp...postcount=1628
V2 looks to be at least 3 - 4 times larger based on the pics. Maybe someone that gets a V2 tank can confirm its volume. I know that V1 was about 1 ounce.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Gforce (06-29-2017)
Old 06-29-2017, 12:01 PM   #2400
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Are they replacing v1 tanks for v1 purchasers ?
Silverfox is offline   Reply With Quote
Old 06-29-2017, 04:34 PM   #2401
B T
The one on the left is the newer unit?
B T is offline   Reply With Quote
Old 06-29-2017, 09:22 PM   #2402
BirdTRD
Simply Forgotus
BirdTRD's Avatar
That you would have to ask Edelbrock but I wouldn't count on it.
The larger of the two is the new one. V1 is the skinny one that I would suspect most people have.
Old 06-30-2017, 03:16 PM   #2403
B T
yeah, mines over a year old, so it's the skinny style, has anyone called about ordering the new tank version alone?
Old 06-30-2017, 03:23 PM   #2404
B T
Just talked to Edelbrock, there's no replacement reservoir in the works outside of what we already have.
Old 07-05-2017, 08:30 AM   #2405
Alysa
Alysa's Avatar
Drives: Whiteout '14 FR-S Monogram A/T
As me as an owner please! Installed mine a few weeks ago
Alysa is offline   Reply With Quote
Old 07-05-2017, 03:00 PM   #2406
B T
Has anyone tried installing one of these with the Edelbrock intake yet?
http://www.86worx.com/garage-vary-intake-duct.html
Old 07-05-2017, 09:59 PM   #2407
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Anybody running a carbon vented hood with their EBSC kit? Specifically the Seibon TS style ones?
I ordered one (ETA 6-10 weeks) and just realized, since it has vents, it drops down a little inside the hood, I know with the stock hood clearance is real tight, so tight that we had to remove the bottom insulation during the install.
I'm crossing my fingers this hood fits with the SC or else I'm screwed.
Dan37BRZ is offline   Reply With Quote
Old 07-06-2017, 12:50 PM   #2408
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Got any pics of the underside of that hood? I have a feeling there's a chance that the "flat" section in the center just may clear it.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
