Old 05-17-2019, 08:26 PM   #2381
Decep
Drives: 2013 FR-S Series 10
I wouldn't mind ripping mine out and replacing it with the newer leather (vinyl?) dash.
Old 05-17-2019, 08:48 PM   #2382
roosahorn
Drives: 2013 FRS 10 Series
Sweidit'd mine. Looks a lot better.
Sent from my SM-N950U using Tapatalk
roosahorn is offline   Reply With Quote
Old 05-18-2019, 12:29 AM   #2383
Trist0n
Trist0n's Avatar
Drives: FRS 10 Series
Originally Posted by MJones_RB View Post
FWIR, once they break they're broke. All you can do is replace them, if possible. Scion is gone and with it went all these cool things. I do believe some Priuses (Prii?) have EL badges but I'm not sure. I asked a Toyota parts tech if the parts could be replaced but he couldn't find a part # for them.
Damn shame. If it’s already a lost cause I might see if I can wire it into something else, or maybe just rig up my own solution to replace the lighting? I’ll have to take a look this weekend
Trist0n is offline   Reply With Quote
Old 05-18-2019, 08:47 AM   #2384
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I once heard that if you prove the ownership of the car such as VIN and Registration, they can help you order the parts.
IG: @rearwheelclub
FR-Sky is offline   Reply With Quote
Old 05-19-2019, 01:43 PM   #2385
Tien0227
Tien0227's Avatar
Drives: FRS 10 Series MT
Still loving mine at 55k. Though my EL stopped working too.
Sent from my SM-G955U using Tapatalk
Tien0227 is offline   Reply With Quote
Old 05-19-2019, 02:00 PM   #2386
Trist0n
Trist0n's Avatar
FR-S 10 Series Registry
I took a look at mine, looks like the controller might be done and the EL strip is burned out. I can’t find any info on replacing it, and something tells me that the OEM parts would be hella expensive. Upon pulling my dash apart it looks to be a plain EL strip behind the panel, I picked one up that’s the same size off eBay. I think I’ll make a vinyl overlay to have it say series 10 + my number or something and wire it into my cabin accent lighting. If it works out I think it’ll look cool
Edit: also I love the purple!
Old 05-20-2019, 01:05 PM   #2387
MJones_RB
MJones_RB's Avatar
Come to think of it, I can't remember the last time I saw my dash EL light up...
MJones_RB is offline   Reply With Quote
Old 05-20-2019, 01:11 PM   #2388
Trist0n
Trist0n's Avatar
It seems to be a pretty common thing for it to burn out
Old 05-21-2019, 11:01 AM   #2389
Cheeky
Drives: 10 Series FRS
Over 100k on mine... daily it (2nd owner).
My back Emblem stopped working... at the beginning of ownership I was slightly embarassed that it would light up so bright at night.
Now I miss it...
Cheeky is offline   Reply With Quote
Old 05-22-2019, 01:23 PM   #2390
Tien0227
Tien0227's Avatar
Good luck! And thank you!
Old 05-22-2019, 01:52 PM   #2391
FR-Sky
FR-Sky's Avatar
Now I miss it...
Mine still works!!!! @70k
IG: @rearwheelclub
Old 05-22-2019, 08:04 PM   #2392
Decep
Same, all emblems working @ 50k.
For you guys whose are not working, did you do any electrical mods like stereo, headlight etc? Wonder if its a fuse or wiring thing.
Old 05-22-2019, 08:40 PM   #2393
Trist0n
Trist0n's Avatar
My emblems still work after stereo and headlight mods, it’s just the EL that’s gone. From what I can tell they’re on a pretty separate system from the rest of the wiring, the emblems and the EL each have their own controllers.
Old 05-24-2019, 09:01 PM   #2394
Trist0n
Trist0n's Avatar
Ladies and gents I fixed it! Ignore my plastic wrap on the ground. Like I suspected the burned out EL panel had a film over it with the scion logo and lettering, so I peeled that off and applied it to my eBay EL strip. I wanted to leave the stock EL wiring alone in case I run into OEM parts someday so I ran an inverter off a tap from the drivers side fusebox, and routed a connector up to the hole behind the dashboard. That way if it ever burns out again it should be a super easy fix, simple disconnect and swap. It is now on all the time, but personally I like it that way, since it’s very unobtrusive, matches my accent lighting, and you can’t see it at all in the daytime. It’s also a ~20$ repair instead of a 400$+ repair if you can even find the parts. If anyone wants a more detailed list of what I did feel free to reach out.
86 Owners of New England - Registry MannyO New England 247 10-27-2025 03:45 PM
**Tennessee Registry** Xryn Southeast 139 11-02-2022 12:31 PM
Mid-Atlantic Owners Registry. IloveBaldEagles Mid-Atlantic 366 10-24-2022 08:55 PM
Issue updating Registry. IloveBaldEagles Site Announcements / Questions / Issues 1 03-18-2013 07:19 PM
First 86 Registry: 2013 Scion FR-S Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 44 05-18-2012 05:54 PM
