10-23-2013, 06:18 PM | #2381 | |
Drives: WR Blue BRZ, 240Z
Any of the other beta's run without the plug in the airbox?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
10-23-2013, 06:23 PM | #2382 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
10-23-2013, 06:23 PM | #2383 | |
Also do you hear it running when wot. It should be quite loud. Sent from my HTC One using Tapatalk |
10-23-2013, 06:27 PM | #2384 |
I don't see why you want to trip the cel though lol. How does it feel when driving it?
10-23-2013, 06:31 PM | #2385 |
While driving or when the engine is off? While driving I don't hear it. When the engine is off I hear it easily.
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel Last edited by Sojhinn; 10-23-2013 at 06:42 PM. |
10-23-2013, 06:32 PM | #2386 | |
The tq250 you don't really hear.... The tq300 however makes quite a bit of noise. Sent from my HTC One using Tapatalk |
10-23-2013, 06:45 PM | #2387 |
No cel.
10-23-2013, 06:58 PM | #2388 |
Drives: Subaru BRZ
I've been trying to figure out how to wire the arming switch to turn off and on with the ignition. Not having much luck. Five wires go to the arming switch and it appears the red wire carries the voltage info (18v-28V) and the yellow wire reads 12V when the switch is off and very little when it is on. I think Rob is working on doing this. I thought it might be easy but not sure now how to do it.
10-23-2013, 07:01 PM | #2389 |
Maybe you aren't getting full boost. I think that happened to @Bu-Tang when a cable came loose on the controller to motor. If everything is tight get ahold of Rob to troubleshoot. It should be quite loud when its off.
Does it feel faster ? Sent from my HTC One using Tapatalk |
10-23-2013, 10:24 PM | #2390 | |
[ame="http://www.amazon.com/124-114111-Solenoid-Isolated-Continuous-Normally/dp/B003JJ8FCY"]White Rodgers 124-114111 Solenoid, SPNO, 24 VDC Isolated Coil, Continuous Duty, Normally Open Continuous Contact Rating 100 Amps, Inrush 400 Amps - Amazon.com[/ame] You would put this on the positive from the 24V battery pack to the controller. This is an active low device so you would need to find a circuit that goes low (-) when the ignition is active. With this in place you can leave the ESC in ARM without fear of discharging the battery.
10-23-2013, 10:27 PM | #2391 | |
10-23-2013, 10:31 PM | #2392 |
Yea rob and I worked it out. Bad battery. Seems like I'm destined to run into issues right now. Obviously I did something to earn some bad karma. And now you guys probably think I'm an idiot in installing things or that my students may have f'd things up. But it was just a bad battery delivered. Yay....
10-23-2013, 10:35 PM | #2393 | |
Drives: 93'Camry, 82'Corolla, 76' Celica
10-24-2013, 06:22 AM | #2394 | |
Drives: 2013 FR-S Argento
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
