go_a_way1, MisterSheep
Old 08-05-2022, 07:15 AM   #23801
orz
orz's Avatar
Drives: Halo
37,500mi
Installed a cruise control relocation bracket. This whole install was more than I signed up for. Lost some sleep too.
Issues
ABS/Traction - Fixed - Cleared code using OBD2 cable/Techstream then ran a steering angle sensor reset.
SRS - Fixed. B1801/B1811. It was a loose airbag bypass wire. I figured out that you can push the terminal clip so it bites down on the resistor. Cleared the code and so far so good. It helps if u tin the prongs lightly with some solder.
Installed the Faction Fab Shifter bushing.
Installed Perrin/Whiteline Trans/Diff mounts. I noticed the cabin got louder. Did a short pull on the way home and the car sounds like it has a supercharger.
-Cheers
orz is offline   Reply With Quote
The Following 5 Users Say Thank You to orz For This Useful Post:
bcj (08-05-2022), MJones_RB (08-09-2022), RToyo86 (08-14-2022), villainous_frx (08-17-2022), Wally86 (08-05-2022)
Old 08-07-2022, 04:16 PM   #23802
redwood9d
redwood9d's Avatar
I replaced my rear diff fluid!
Sheared an adapter, tore my knuckles, and punched myself in the face but I did it all by myself
All that's left is brake fluid and race pads and ya boy's track-ready
redwood9d is offline   Reply With Quote
The Following 5 Users Say Thank You to redwood9d For This Useful Post:
bcj (08-08-2022), DarkPira7e (08-16-2022), new2subaru (08-08-2022), soundman98 (08-07-2022), Wally86 (08-08-2022)
Old 08-08-2022, 04:14 PM   #23803
WNDSRFR
Drives: FR-S,GTI
I removed this intake blockage and replaced it with the OEM intake.
I would suggest that anyone who has a similar blockage remove it and put it up for sale. Before it's too late.
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post:
MJones_RB (08-09-2022), Teseo (08-14-2022), Wally86 (08-09-2022)
Old 08-14-2022, 04:55 PM   #23804
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Uninstalled torque solutions short shifter and in went the OEM shifter. It feels great with the front and rear carrier bushings done.
Old 08-14-2022, 07:30 PM   #23805
Teseo
Drives: frs
Upgrade it with Perrin Inlet tube + high flow filter👌
Old 08-14-2022, 11:41 PM   #23806
jflogerzi
jflogerzi's Avatar
installed my 2 piece splitter from Verus with race upgrade, oil change, installed new OEM Fenders liners, and swapped out my cracked beat to hell Bumper to my new OEM pained by Maco.
2013 Series 10 FRS #553
The Following 6 Users Say Thank You to jflogerzi For This Useful Post:
blsfrs (08-15-2022), Busybee (08-14-2022), DarkSunrise (08-15-2022), KMA KiCKz (08-16-2022), norcalpb (08-15-2022), Wally86 (08-15-2022)
Old 08-16-2022, 04:15 PM   #23807
Decep
Drives: 2013 FR-S Series 10
How much they charge for the repaint?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 08-16-2022, 04:44 PM   #23808
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by Stephen02 View Post
Man that metal piece at the bottom is rusty. I don't envy you guys in Canada although not having our stupid 25 year import rule must be nice.
How to clean such a thing?
Old 08-16-2022, 05:24 PM   #23809
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
To combat IATs until a get a new intercooler setup, I wrapped the downpipe and added gold tape hastily to the cold side intake pipe. Didn't really make much difference in intake temps but it helped the engine bay cool off a bit!
Definitely not a fan of the gold piping, I'll probably remove it eventually.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
KMA KiCKz (08-17-2022), MJones_RB (08-17-2022), RToyo86 (08-18-2022), Wally86 (08-17-2022)
Old 08-17-2022, 09:24 PM   #23810
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
$20 later at Toyota and it is rust free
villainous_frx is offline   Reply With Quote
The Following 3 Users Say Thank You to villainous_frx For This Useful Post:
DarkPira7e (08-18-2022), JD001 (08-18-2022), Tcoat (08-17-2022)
Old 08-17-2022, 09:40 PM   #23811
And the only reason it was as rusty as that was the light haze of paint they put on thin tin. Pretty sure they just ran it nearby the paint stage and what fumes hit it they called good enough.
Much thicker paint on the 86 and not a rust speck to be seen. I get to save $20 in 4 more years.
Old 08-17-2022, 09:58 PM   #23812
new2subaru
Weight Weenie
Drives: 15 FR-S
Threw a check engine light and a few codes. Bought a can of MAF sensor cleaner at CT for 12 bucks.
Got lucky! Worked like a charm.
The Following User Says Thank You to new2subaru For This Useful Post:
soundman98 (08-17-2022)
Old 08-18-2022, 01:36 PM   #23813
villainous_frx
Off to the track!
Finished break in finally. It unlocked the rare 9000 RPM redline!
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
JD001 (08-18-2022), Tcoat (08-18-2022)
Old 08-18-2022, 01:46 PM   #23814
You've only put 19,000 kilometers on it?
That's almost Garage Queen status!
JD001 (08-18-2022), soundman98 (08-18-2022), Ultramaroon (08-18-2022)
