Old 09-12-2010, 08:16 PM   #225
Dimman
Kuruma Otaku
Dimman's Avatar
Is that GT-R one scaled properly? Because in real life they look HUGE.
Because titanium.
Old 09-12-2010, 09:29 PM   #226
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
FT86: 163.8
GT-R: 183.3
...so 20" difference. It's pretty against FT86, but if you compare w others
Supra (MKIV): 177.7~8
Impreza (GR): 173.8
Camero (5th): 190.4
Mustang (5th): 188.1
Veyron: 175.7
Comparing, I guess GT-R is American size. lol Now you know why GT-R is called Godzilla.
Old 09-13-2010, 10:58 AM   #227
AaronCompNetSys
AaronCompNetSys's Avatar
Drives: 01' S2000; 05' WRX
Originally Posted by Want.FR-S View Post
I scale the images based on length rather than height since the height can be changed depends on the source image that you have.
I would also like to stress the significance of aligning the images to the front wheel.
Unfortunately you are missing one more thing, , lens distortion. Lots of car pictures skew the front and rear bumpers because they are near the edges, and are fractionally off. This is why I only use wheel size to start with, and length just to double check.
Front wheel comment: yeah, that. And when I visualize sitting in the driver's seat, I kind of get the idea of weight distribution around me. Driver position in the diagram would be cool too, like road and track does I think.
AaronCompNetSys is offline   Reply With Quote
Old 09-13-2010, 04:22 PM   #228
Matador
hashiryu
Drives: Mk4 Supra
VVTL-i is closer to Honda's iVTEC not the old VTEC due to the cam phasing (old VTEC was just lift/profile changing). I think the newer Toyotas are VVT-i on both intake and exhaust (Intake valves are typically larger than exhaust valves) but there is something called 'Valvematic' I think it is, that is Toyota's next-gen cam/valve control tech.
I haven't really heard of VVTL-i in anything other than the 2ZZGE. Can anyone clarify for me?
The Lexus LFA I believe only used VVT-i on intake and exhaust.
Correct. And AFAIK the 2ZZ is the only engine that used VVTL-i.
Can't wait for Valvematic to hit it's stride though. Feel like they are taking forever with it.
p.s. Thread derailment much guys?
Matador is offline   Reply With Quote
Old 09-13-2010, 11:37 PM   #229
Dimman
Kuruma Otaku
Dimman's Avatar
I recovered, with that GT-R comparison, wonder if it's correct, cause they are massive in real life. Makes the FT/R-86/S look like it may come out bigger than I was expecting. (Were the wheel/tire sizes of the FT confirmed?)
Edit: How are you guys comparing wheels/tire sizes? Are you converting diameters properly?
Because titanium.
Old 09-14-2010, 12:22 AM   #230
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
I think, intuitively, you are correct on this since not all the images are taken based on the same focal point or same distance from the car, so there might be skewed at the edge of the picture. To be really precise, all the cars must be placed at the same distances away from the camera for this to be 100% precise. However, given that condition is almost impossible, we have to treat this as an estimate comparison.
I will work on the GT-R comparison. I actually had the pleasure to see one GT-R (gun metal color) in person, and saw a Celica (2000-2005 model, similar size with FT-86) at the same parking lot. Unfortunately, they are not parked very closed. But just based on my visual, the GT-R is really big compared with the Celica.
Last edited by Want.FR-S; 09-14-2010 at 01:02 AM. Reason: Removed the comment about GT-R looks like a Pondiac Grand Prix.
Want.FR-S is offline   Reply With Quote
Old 09-14-2010, 12:52 AM   #231
70NYD
70NYD's Avatar
Drives: RX8 S1
i wanna know that one 2.. its useless to compare RIM sizes.. its better to go of the wheel sizes (you know the WHOLE thing rim and tire..) cus that can be found relative easy and can be used to benchmark pixels by measuring from side to side of the wheel rather up to down (as the rubber distorts obviously arround the contact patch) cus even a few cm error on the wheel measurement which isnt much will translate to quite the few inches when scaled and comparing the whole car
roling diameter is found from from the aspect ratio so for eg a 225/40R18 has a aspect ratio of 40%
so the wheel height is 2 times 40% of 225mm (since there 2 sidewalls to the diameter) + 18" (but in mm)
so
(2*90)+457.2 = 637.2mm
and measuring across the wheel (ie from front to back rather than up and down) will get rid of the error due to flattening where the tire meets the ground
just a suggestion
70NYD is offline   Reply With Quote
Old 09-14-2010, 01:01 AM   #232
Want.FR-S
Want.FR-S's Avatar
Here is the comparison between GT-R and FT-86. My source image of GT-R is from the Nissan Canada web site.
FT86: 163.8 inches
GT-R: 183.3 inches
Here is the zip file that contains the PSD file with two layers (GT-R and FT-86). You can play around with the transparent ratios to see the differences between these two cars....
ft86_vs_gtr.zip
Old 09-14-2010, 01:13 AM   #233
Want.FR-S
Want.FR-S's Avatar
so
just a suggestion
Does anyone have the wheel sizes for both GT-R and FT-86? With a reasonable correct numbers, the scaling factor can be calculated quite easily. (Unfortunately I do not have those numbers..... )
Old 09-14-2010, 01:22 AM   #234
Dimman
Kuruma Otaku
Dimman's Avatar
GT-R: Front: 255/40R20 About 28.03" dia
Rear: 285/35R20 About 27.85" dia
FT/R-86/S: Unknown to me. (likely smaller. A lot. Even the concept. GT-R has 15" brakes. What I'm getting at is the GT-R's wheels are HUGE.)
Edit: For comparison, Supras (225/50R16 Mk3 front and rear, 255/40R17 Mk4 Rear)were about 25" dia
Because titanium.
Old 09-14-2010, 01:38 AM   #235
70NYD
70NYD's Avatar
Drives: RX8 S1
give me a few min il look through the photoes cus there are some closeups of the rims
edit
LOL talk about a fluke... just looked at the FT-86 wallpaper thread and the last picture in 2nd post looks like this. its from the same group of pictures taken on the same day (im assuming) when the side shot was taken we are using to compare so it will work just fine even if they changed the wheels later. please notice the 225/40 R19 writen on the side wall HAHA i wasnt far of in my guess b4.. but FUCK me thats massive, i thought they wre 18"s at msot as i dont recall reading anything in regards to their size.. i thought that the rims were a lot smaller.. this car just became very similar/close in size to my current one just by looking at the wheels in respect to the car..
this will make a 662.6mm diameter
and looking at the MASSIVE photoes on pg2 of the same thread the size markings on the side wall have been scrubbed of or touched up in photoshop for this photo but you can still read the 225..
Old 09-14-2010, 01:51 AM   #236
Dimman
Kuruma Otaku
Dimman's Avatar
I got 225/40R19 off of that.
26.09" dia
Because titanium.
Old 09-14-2010, 01:58 AM   #237
70NYD
70NYD's Avatar
Drives: RX8 S1
you can actualy see it as clear as day in this picture
Old 09-14-2010, 01:59 AM   #238
Want.FR-S
Want.FR-S's Avatar
So I took it as this:
FT-86: 225/40/R19 ==> 662.6 mm
GT-R : 255/40/R20 ==> 688.0 mm (<== incorrect, pointed by Dimman)
Now, based on my own judgement on where to see the single pixel of the wheel (this will introduce error since this is not a precise measurement...), here is the revised comparison.
(Warning: image was not scaled correctly.)
You can see that now the back of the GT-R is within the FT-86 image. I guess this is probably off one or 2 inches...
This is not an exact science....
Last edited by Want.FR-S; 09-14-2010 at 02:25 AM. Reason: Correction on the information.
Has anyone compared the rumored price range to.... demby123 Scion FR-S / Toyota 86 GT86 General Forum 22 10-09-2011 03:18 PM
Subaru BRZ Dimensions and More Teasers Released Ahead of Frankfurt BRZman BRZ First-Gen (2012+) — General Topics 48 09-03-2011 11:32 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
