Old 08-21-2013, 02:46 PM   #225
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
Originally Posted by DougW View Post
Just let everybody know I have been testing the Bilstein Damptronic package on my FRS. I make a control box for the Porsches and GTRs that we adapted to the FRS, it uses the CAN for G, steering ,tps and braking to control the shocks. It rides soft but firms up based on mapping, pretty cool.
DougW
Im subscribed to your other thread. Im holding off on coilovers till I grt more info on yours. Hopefully you'll keep us updated as you go along
Good luck
the.big.kahoona is offline   Reply With Quote
Old 09-03-2013, 05:59 AM   #226
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Spring rates for the STI Pinks and H&R sports????
info on RCE Blacks?
I have less than an inch of clearance coming into or out of my driveway and many places in town are worse. I just want stiffer springs with the least drop ( i know i'm one of the very few who doesn't want a 4inch drop and 11" wheels)
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 09-17-2013, 06:45 AM   #227
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Originally Posted by WingsofWar View Post
Please post a reply in this topic if you have new information.
I need your help to complete the data in this list!
Need to determine how much your car has lowered?
Distance between hub center and top of fender opening
Front is 14 7/16" and rear is 14 5/8"
Need to convert the metric spring rate to standard?
http://tinyurl.com/kg-to-lb
Want to install your own coilovers or springs?
Strut Replacement/Coil Spring Install DIY
Need to determine your spring rates?
ridetech.com/info/spring-rate-calculator
Want more information on basic suspension tuning?
http://www.rapid-racer.com/suspension-tuning.php
Code:
SPRINGS             Front/Rate     Rear/Rate      Part #        MSRP
OEM Toyota 86       0.0"/2.3k      0.0"/3.3k      TBD           $---
OEM Toyota GT86 (EU)0.0"/2.3k      0.0"/3.3k      TBD           $---
OEM Scion FR-S M/T  0.0"/2.3k      0.0"/3.8k    F:SU003-04144   $83.90
                                                R:SU003-04147   $83.90
OEM Scion FR-S A/T  0.0"/2.3k      0.0"/3.8k    F:SU003-04145   $83.90
OEM Subaru BRZ M/T  0.0"/2.7k      0.0"/3.5k    F:20330CA010    $79.70
                                                R:20380CA010    $79.70
OEM Subaru BRZ A/T  0.0"/2.7k      0.0"/3.5k    F:20330CA020    $79.70
                                                R:20380CA010    $79.70
Code:
Eibach Pro-Kit      1.0"/3.6k      1.0"/4.9k      8210.5.140    $359
Eibach Sportline    1.4"/3.8k      1.4"/5.3k      4.10582       $359
Espelir Active GT   0.5"/3.2k      0.5"/5.0k      4536190109385 $TBD
Hotchkis Sport      1.0"/3.3k      1.0"/4.7K      19445         $221
Intrax              ---            ---            ---           $---
Mach V              0.7"/TBD       1.0"/TBD       TBD           $239
Race Comp Yellow    0.8"/4.5k      0.8"/4.5k      RCE-BRZ       $349
RS-R Down           0.5"/2.8k      0.5"/4.5k      T065D         $TBD
RS-R S/Down         1.0"/3.2k      1.2"/4.5k      T065S         $TBD
RS-R Ti2000 Down    0.5"/2.8k      0.5"/4.5k      T065TD        $TBD
RS-R Ti2000 S/Down  1.0"/3.2k      1.2"/4.5k      T065TS        $TBD
Swift Sport FRS     1.0"/3.0kg     1.0"/4.5kg     4T909         $399
Swift Sport BRZ     1.0"/3.8kg     1.0"/4.5kg     4F912         $399
STi Pink            0.6"/TBD       0.6"/TBD     F:ST20330AS000  $210.97
                                                R:ST20380AS000
Tein H-Tech *NOTE*  0.9"/2.9k      0.7"/4.8k      SKSA0-G1B00   $TBD
Tein S-Tech *NOTE*  1.2"/3.3k      1.0"/5.0k      SKQ54-AUB00   $280
TRD (same set on CO)0.6"/3.5k      0.6"/5.8k      MS260-18001   $548.00
*Red/bold links denote link to review topic on FT86club.com
Code:
COILOVERS           Front/Rate     Rear/Rate      Part #        MSRP_
AirREX Kit Basic    0.0-3.0"/--    0.0-3.0"/--    S-JP09006     $3575
AirREX Kit Digital  0.0-3.0"/--    0.0-3.0"/--    S-JP09006     $5155
Amuse Hi-Tech       TBD-TBD/8K     TBD-TBD/8K     TBD           $TBD$
Apex'i N1          +1.6-2.4"/10k  +0.8-2.0"/8.0k  264CT090      $TBD$
Blitz Damper ZZR    0.0-2.0"/6.0k  0.0-2.0"/4.0k  TBD           $TBD$
BC Racing BR-Type   TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
BuddyClub D1 Damper     TBD/9k      TBD/7k   BC02-D112ZN6  $1549 **(solid upper mounts)
BuddyClub RSpec Damper    TBD/9k    TBD/7k   BC02-RSD12ZN6 $1799 **(pillow ball, w/ upper camber adjust.)
Cusco Spec-A        0.2-1.4"/4.5k  0.4-2.0"/5.0k  96560JCB      $1707
Cusco Zero-A       +1.0-1.4"/5.0k +1.0-2.0"/5.0k  96560NCN      $2374
Cusco Zero-A w/PB  +1.0-1.4"/5.0k +1.0-2.0"/5.0k  96560NCP      $2640
D2 Racing RS        0.5-3.5"/7.4k  0.5-3.0"/5.0k  D-SC-06       $1525
DG-5                TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Fortune Auto 500    TBD-TBD/6.0K   TBD-TBD/7.0K   TBD           $1149
Fortune Auto 510    TBD-TBD/8.0K   TBD-TBD/8.0K   TBD           $1499
Ground Control Kit  1.0-1.5"/6.7K  1.0-2.5"/7.7K  TBD           $TBD$
HKS Hipermax IV     0.0-2.8"/6.0k  0.0-3.0"/4.0k  80230-AT001   $2250
HKS Hipermax IV GT  TBD/8.0k       TDB/6.0k       80230-AT001V  $2350
JRZ RS1             TBD-TBD/CSTM   TBD-TBD/CSTM   TBD           $TBD$
KSport Kontrol Pro  0.5-3.5"/7.5k  0.5-3.0"/6.3k  CSC080-KP     $1600
KW Variant 3        0.8-2.0"/6.1k  0.8-2.0"/7.1k  35258004      $2299
KW Street          TBD-TBD/CSTM   TBD-TBD/CSTM   TBD           $TBD$
Megan Street        TBD-TBD/8.0    TBD-TBD/6.0    MRCDKSFR12    $999
Megan Track         TBD-TBD/10.0   TBD-TBD/8.0    MRCDKSFR12TS  $999
Nitron NTR          TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Ohlins BTO         +0.2-1.2"/9.0k +0.2-1.0"/7.0k  TBD           $3674.88
PRS Soft            TBD-TBD/6.0K   TBD-TBD/6.0K   TBD           $TBD$
PRS Medium          TBD-TBD/8.0K   TBD-TBD/8.0K   TBD           $TBD$
PRS Hard            TBD-TBD/10.0K  TBD-TBD/10.0K  TBD           $TBD$
RS*R iSport Soft   +0.6-1.6"/5.0k +1.2-3.2"/6.0k  SPIF065S      $TBD$
RS*R iSport Std    +0.6-1.6"/6.0k +1.2-3.2"/7.0k  SPIT065M      $2449
RS*R iSport Hard   +0.6-1.6"/7.0k +1.2-3.2"/8.0k  SPIF065H      $TBD$
Sachs (no model)    TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Stance (no model)   TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
Standard ENR        0.0-3.0"/CSTM  0.0-2.8"/CSTM  SC01I2        $4595
Standard R3         0.0-3.0"/TBD   0.0-2.8"/TBD   SC01R3        $1795
Standard R7         0.0-3.0"/TBD   0.0-2.8"/TBD   SC01D7        $2095
Standard R7-TA      0.0-3.0"/TBD   0.0-2.8"/TBD   SC01T7        $2095
Suivax Standard     TBD-TBD/7.0k   TBD-TBD/5.0k   TBD           $TBD$
Suivax 86 Edition   TBD-TBD/8.0k   TBD-TBD/6.0k   TBD           $TBD$
Tanabe Sustec Pro Z40  1.8"/5.0k    1.8/5.0k    TSE4166           $2,190.00
Tein M/Flex *NOTE*  0.2-1.8"/8.0k +0.2-2.8"/9.0k  GSQ54-F1SS1   $TBD$
Tein Street *NOTE*  TBD-TBD/TBD    TBD-TBD/TBD    TBA           $TBD$
Tein T/Flex *NOTE* +0.1-2.2"/7.0k +0.1-2.5"/7.0k  DSQ54-61SS1   $TBD$
TRD FRA Set      0.6"/3.5K   0.6"/5.8K   MS260-18001           $3289
XYZ Super Sport     TBD-TBD/TBD    TBD-TBD/TBD    TBD           $TBD$
*K-Sport SCS080-KP (FR-S) and CSB200-KP (BRZ) are identical
*AirREX S-JP09006 (FR-S), S-JP07010 (BRZ) and S-JP01027 (GT86) are identical
Correction: RSR Sports-i is now at $1799 MSRP rather than at the original $2499 after currency adjustment and LOTS of TWISTING ARMS by me...
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
Old 09-18-2013, 10:52 PM   #228
Racecomp Engineering
info on RCE Blacks?
http://www.ft86club.com/forums/showthread.php?t=39418
Old 09-19-2013, 01:53 AM   #229
StormTrooper
I guess I should have been more specific....
Is RCE developing springs similar to the black " regular guy" springs that are available for the wrx.?
Meaning a 10-15mm drop with spring rates a step softer than the yellows. But stiffer than stock. Maybe the market isn't large enough for those, idk.
GR86 MT premium
Old 09-24-2013, 03:46 PM   #230
Stevo22
Stevo22's Avatar
Drives: GR86
From what I understand the yellows for our cars are actually blacks. They have released a RCE Tarmac spring that is matched for their future Bilstein shock and for koni shocks which is the "yellow" for the wrx. I am sure someone will correct me if I am wrong.
Their site is down right now otherwise I would submit a link with this post.
Thread reviewing the Tarmac Springs
Last edited by Stevo22; 09-24-2013 at 03:54 PM. Reason: added link to review thread
Stevo22 is offline   Reply With Quote
Old 09-24-2013, 10:38 PM   #231
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
I don't see ark coils on the list. I know they make some. I wonder if anyone has installed them yet
Sent from my HTC One using Tapatalk 4
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
Old 10-20-2013, 12:19 AM   #232
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Any kinda info on the st suspension coilover spring rates?
karma003 is offline   Reply With Quote
Old 10-22-2013, 09:51 PM   #233
mokytron
i shoot cars
mokytron's Avatar
Drives: asphalt grey
has anyone put on the ST coilovers or the tein street BASIS?
i just saw those from brz-parts and was wondering if anyone here used them and what they thought of them
my automotive portfolios:
kevinkinguy.com
flickr
mokytron is offline   Reply With Quote
Old 10-22-2013, 10:11 PM   #234
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Code:
                                                R:20380CA010    $79.70
                                                R:20380CA010    $79.70
Code:
                                                R:ST20380AS000
Code:
RS*R iSport Std    +0.6-1.6"/6.0k +1.2-3.2"/7.0k  SPIT065M      $$1799
Ohlins "BTO" is Japan-only.
http://www.ft86club.com/forums/showp...6&postcount=46
US spec (regular Road & Track) is 6/6 front/rear
Japan spec (BTO listed above) is 9/7 front/rear
Old 11-15-2013, 11:50 PM   #235
uEih
Drives: CBS Subaru BRZ Limited
Looking at the Eibach Pro Kit Springs, hows the ride on this? Similar to stock for the BRZ?
uEih is offline   Reply With Quote
Old 11-24-2013, 12:47 PM   #236
Howardwei
Buying question
Hi guys,
I was wondering if there I just want an inch drop in order to fit 18x8.5 in front and 18x9.5 in back with 255/35 and 235/xx in the front. What would be the closest set up for stock ride comfort and about the same tail happiness. I know 255 and a stagger would make it understeer but thats the only fitment for my wheels.
Thank you all in advance.
Howardwei is offline   Reply With Quote
Old 11-25-2013, 12:02 AM   #237
rene0023
rene0023's Avatar
Drives: Scion FR-S (Red)
Excellent info!
rene0023 is offline   Reply With Quote
Old 02-07-2014, 03:13 PM   #238
Bomz
Does it drift?
Drives: 2013 Subaru BRZ
Just a question. Why is it that on the coilovers the spring rates seen to be higher for the fronts than the rears but if you look at stock set ups or just springs the rate is higher in the rear. For a car that has been engineered as well as it has why would you want to make something as important a spring rates the opposite as the designers. I'm not being sarcastic or anything I just honestly don't know.
Bomz is offline   Reply With Quote
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
