#225 |
E10 stoich?
A quick search with Google shows predominantly 14.13, rather than 13.9. Is that for WOT?
If I say yes, will that make you think I understand?
#226 |
Drives: Scion FRS
#227 |
Target AFR 14.15%
Here in WA it's up to 10%. Especially in winter. My favorite station uses ethanol year-round though, so I'm changing my AFR table to 14.15 in the lowest sections, instead of 14.70. I also changed the BRZ port scalar 4.6%, since that was about how far it was off in CL. I know it gets the best mileage when it is just the tiniest bit lean in OL, so 14.15 should be a good target. This is the only table with AFR ratios I could find. It's an Open Loop table, but I think it is referenced for Closed Loop as well. See pic for more info. @thambu19, I only changed the 14.70 cells, or do you think I should re-scale the whole table 3.7% richer
#228 | |
| The Following User Says Thank You to steve99 For This Useful Post: | thambu19 (12-11-2015) |
#229 |
Drives: Scion FRS
In general running stoich or slightly rich will make the engine feel a lot better under load but ofcourse at the cost of Fuel economy
#230 |
Drives: FR-S Whiteout
I've also noticed this in OL operation where the "commanded AFR" is actually a bit leaner than the actual requested values on the OL fuel map. This really messes with the MAF scaling tool as it tries to match the MAF scale to the "commanded AFR" and not the actual requested AFR on the fuel table.
Intent > Content
cowardice is the mother of cruelty. |
#231 | |
#232 | |
| The Following User Says Thank You to steve99 For This Useful Post: | KoolBRZ (12-12-2015) |
#233 |
Drives: UK GT86
@KoolBRZ they also don't seem to actually change the AFR you target in closed loop. Anything leaner than the minimum open loop enrichment value in the primary open loop fueling table is ignored and the closed loop fueling tables are referenced, however the ECU does seem to try and target stoich at all times.
.: Stealth 86 :.
#234 |
Yeah, I thought maybe I could take the easy route and just change anything 14.7 in the definition to 14.13, but the calculations are more complex than that.
#235 |
OK, this should do it
Here are my re-scaled Open Loop and Closed Loop tables that should bring my AFR down to 14.15. I just added .55 to all the cells in the A and B Compensation tables. I'll load up the tune and try it out this morning before I do my transmission fluid service/refresh, since I need it up to 42 C to measure correctly.
![]() Last edited by KoolBRZ; 12-12-2015 at 03:24 PM. Reason: !@#%*& minus sign! |
#236 |
OK. Got the comp cells to all be negative values, and took it for a test drive again. Here is a log I took, http://datazap.me/u/koolbrz/1st-e10-...g=0&data=1-4-9 @thambu19, is there any way you could create a table of recommended AFR's by Engine Load and RPM's. I want to try getting my logs closer to stoich with the E10 I'm running now.
#237 | |
Drives: UK GT86
The real "workaround" for this would be to change your O2 scale, however the ECU will try and target 14.7 so you'll actually make it run leaner
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | thambu19 (12-13-2015) |
#238 |
CL target afr=14.7 + value in closed loop table
there are probably some other compensations as well. as you have put bigger negitive values in them the car is runnung richer in closed loop. if you want to run close to 14.7 then put -0.01 in the cells in both the A and B tables. As these tables are reverse engineered the ecu code often has multiple references to same table hence the need to change 2 identical tables. As @Kodename47 said the ecu logic prevents targeting leaner than 14.7 and putting positive values in does not work, putting zero in appears to disable ltft in that area. |
| FR-S Gear Ratio Comparison | SpeedR | Engine, Exhaust, Transmission | 36 | 02-25-2016 09:34 AM |
| Best pistons to use and Comp ratio? | Fabron757 | Forced Induction | 36 | 02-05-2014 03:21 PM |
| Rear End Ratio | White64Goat | Engine, Exhaust, Transmission | 6 | 07-07-2012 11:37 PM |
| FR-S to BRZ Ratio | MannyO | New England | 11 | 03-08-2012 02:23 AM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 02:40 AM |
