#225 | |
Specifically, Emilio of 949 racing. He is an OS Giken dealer, but the testing was actually performed to confirm that a clutch LSD does improve performance. Why was the testing performed? Because it settled the debate on whether to ban aftermarket LSDs for the Supermiata series. It was banned because if it was allowed, it is mandatory to be competitive. Thus, with all aftermarket diffs being banned in the series, everyone runs an OEM Torsen. |
#226 | |
Now, if you're hardcore enough to be running slicks at the track, and set the LSD for that, then you're probably going to be willing to deal with the ratcheting. |
#227 | |
We've played with a lot of different settings on server different cars (and different platforms), and I can say that a badly tuned LSD can get REALLY annoying on the street. However, even an off-the-shelf LSD will make the car be substantially more behaved when cornering hard (both entry and exit; effect is lesser mid-corner unless you're at the level where you can consistently throttle steer) We consider it essential enough that a pair of LSDs (front and rear) were the first mechanical modifications that went in our 2015 WRX; the STI already comes with a front rear, and center LSD. Now if we could somehow get a center LSD into the WRX... |
#228 |
Drives: Hydra EMS Powered FRS Raven Black
Even factory STi diffs can wratchet so it's not really "unacceptable" in a performance car. My Cusco in my race car is only bad with a near full lock turn so that's like backing out of your driveway or parking lot situations.
I'm sure one day I'll have one and sooner than later if a sponsor tosses one my way
#229 |
One thing I'd like to point out, is the exotics. Everyone is constantly pointing out that exotics often have a Torsen (older) or electronic differential (newer), when they're obviously a very high performance car. There's a few reasons for that.
Exotics, while being high performance, are still luxury cars. Your average owner expects to only hear the engine. As such, they make the differential unintrusive, and brake pads quiet (street pads). They also have the budget to use things like electronic differentials, instead of a mechanical. |
#230 | |
#231 |
Off Topic
Is the DCCD in an STi a separate removable unit like the rear diff LSD is? Or is it woven into the inner workings of the transmission? If it's removable, do you think it would fit in the WRX transmission? If it's not... transmission swap? 6 speeds must be better because they have 1 more speed, right?
#232 |
#233 | |
It'll be swappable once the STI transitions to the FA20DIT... Also, 2015 WRX is a 6 speed with taller gearing than the STI in all gears.... |
#234 | |
Off Topic
Is it? Huh. I ought to go lie to the dealer and take one for a test drive. I won't buy one though; not having a turbo was actually one of the selling points for the BRZ when I was shopping. |
#235 | |
Drives: GT-86
#236 | |
#237 | |
Off Topic
http://forums.nasioc.com/forums/show....php?t=2384890 Here's a shot of the internals. Would it fit? Not a clue. It's an interesting idea though. |
#238 |
The STi 6 speeds are totally different and way stronger than the 6 speed used in the new wrx or the frs/brz. The DCCD center diffs cannot be installed in a WRX, BRZ, or Legacy 6 speed. They also vary depending on the year STi trans as they are conversion diffs (different front vs rear final drive in some models).
We are breaking 3rd and 4th gears in the 700 hp range (under race conditions) but that's pretty good for a factory transmission |
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 08:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 07:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 08:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 01:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 12:49 PM |
