Old 06-05-2014, 10:46 AM   #225
ProjectGT86
Drives: Fire Storm Red Slush box gt86/frs
Originally Posted by Guillaume View Post
Pulleys don't add a single horse power... This voids any point you might be trying to make.
Can you read??? I said Pulleys decrease rotational mass.... decreasing rotational mass FREES up horsepower, leading to less parasitic loss.
ProjectGT86 is offline   Reply With Quote
Old 06-05-2014, 10:50 AM   #226
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Well you're still wrong. It does decrease rotational mass, gives better engine response too. That's a similar effect to reducing the the overall weight of that car by several lbs, if you will.
It doesn't "free" or "add" any power whatsoever.
Old 06-05-2014, 10:54 AM   #227
ProjectGT86
Originally Posted by s2d4 View Post
It doesn't work like that.
Sent from my Galaxy Nexus using Tapatalk
Oh really? With just a CAI and an exhaust set up in addition with the stage 2 tune you get an additional 20whp, http://ft86speedfactory.com/ecutek-s...cable-457.html its basically the same thing you get from cosworth for about half the price, and probably with pulley upgrades (decreasing rotational mass doesnt add power but allows more power to reach the wheels) and some additional bolt ons im sure you get close to 40whp, and you its still cheaper than this cosworth rip off
Old 06-05-2014, 10:57 AM   #228
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Again, no. Gee, what's so hard to understand? Inertia does not cause powerloss.
Old 06-05-2014, 10:57 AM   #229
ProjectGT86
Are you trying to be stupid? If the crank has less resistence while spinning that means less power is being loss, which means more of the power at the crank is going to go to the wheels...
Old 06-05-2014, 11:01 AM   #230
JerryMichaels7
Drives: Whiteout FRS
Yes it does? If the motor has to spin said object how is it not wasting enery spinning said object? Taking and item out of the equation say going to an eletric water pump instead of manuel, or reducing drivetrain wheight thru pulleys/FW/DS. It frees up the motors wasted energy.
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 06-05-2014, 11:01 AM   #231
JerryMichaels7
^^beat me to it.
Old 06-05-2014, 11:08 AM   #232
Guillaume
Guillaume's Avatar
Drives: Exige S 240
We're talking about a light weight pulley with same gear ratio, yes? Not an underdrive pulley.
Then it does not "free" power that would be other wise consumed by a heavier pulley. Inertia affects transitory phenomenons (accelerating or decelerating). It doesn't cause energy loss (friction does, aero drag does, not inertia).
That's why people often say "Every pound of rotation mass is equvilent to 10 pounds dry mass.". Yes the car will accelerate faster with a lighter pulley, no the whp won't change.
Old 06-05-2014, 11:16 AM   #233
DatApex
Drives: 2013 WRB BRZ Limited
Bingo. When you see companies selling a lightweight pulley they will often have a marketing spiel along the lines of "equivalent of a 10whp increase!"
This is nothing but clever marketing to confuse the ignorant.
DatApex is offline   Reply With Quote
Old 06-05-2014, 11:21 AM   #234
s2d4
s2d4's Avatar
Oh really?
Yes. They don't add up that way.
Old 06-05-2014, 11:23 AM   #235
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
This.
The belt is still turning whatever device (alternator, water pump, AC, ect...) those are what are causing the parasitic loss, not the pulley themselves.
Lawn_Mower is offline   Reply With Quote
Old 06-05-2014, 11:32 AM   #236
Jason@DSG
Jason@DSG's Avatar
Drives: 1997 Eagle Talon TSi AWD
Dyno result on a WRX before and after with OEM versus lightweight crank pulley, 10whp freed up:
http://forums.nasioc.com/forums/show....php?t=1868471
I completely agree you aren't ADDING any power perse, but the engine requires less work when running lighter pulleys (or other lightweight drivetrain parts) freeing up power that was lost due to heavier drivetrain components getting more power to the wheels that was just being lost spinning heavier OEM parts.
Another really popular example, 3000GT's and Stealth R/T switching to PST Carbon or Aluminum Driveshafts. This is pretty much the first mod any of these guys do and as you can see here, 381whp OEM driveshaft and 413whp after (post #4):
http://www.3si.org/forum/f1/pst-1-pi...t-dyno-631730/
Jason@DSG is offline   Reply With Quote
Old 06-05-2014, 11:40 AM   #237
Guillaume
Guillaume's Avatar
Drives: Exige S 240
It's the effect of the dynamic load on the dyno.
http://forums.nasioc.com/forums/showthread.php?t=873912
Straight to the point :
The rate of acceleration on the dyno (controlled or uncontrolled) will directly effect the measured power.
Old 06-05-2014, 11:58 AM   #238
Jason@DSG
Jason@DSG's Avatar
I agree, but the increased rate of acceleration is directly correlated to the increase in efficiency in the drivetrain by freeing up weight. It's one of those things, we're saying the same thing but in a different way. You actually don't increase any power by doing lightweight drivetrain parts but it increases the rate at which the engine "works" which results in higher performance (on a dyno, this translates to more power because of the way dyno's measure power)
Vortech SC + Vishnu OFT300 power package Garrett@Openflash Forced Induction 22 03-15-2016 12:04 PM
DeatschWerks Power Package available at RallySport Direct! RallySport Direct Engine, Exhaust, Bolt-Ons 1 11-27-2013 07:51 PM
MAGNAFLOW CATBACK + AFE POWER/INJEN INTAKE PACKAGE DEAL!!! NJA Engine, Exhaust, Bolt-Ons 5 12-11-2012 09:05 PM
