Old 07-13-2014, 06:39 PM   #225
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
I told ya why I like this material. After my road kill incident, and hitting driveways and curbs on purpose, it's a solid material. Scrapes away when it needs to, flexes or stays rigid when it needs to.
I thought about using aluminum or a plexi, but not gonna happen after I've been torture testing this stuff.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline
The Following 3 Users Say Thank You to Wonderbar For This Useful Post:
eric6 (07-13-2014), Kwaziekeller (07-13-2014), Lawnik (07-13-2014)
Old 07-13-2014, 06:53 PM   #226
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Will a carbon fiber version be in the works?
Rocket.BRZ is offline
Old 07-13-2014, 07:05 PM   #227
Gunman
Drives: 2019 Mazda Miata RF
Carbon won't be as durable. Carbon splitters on race cars, have Jabroc replaceable pieces on the underside, because they scrape and wear away. Carbon, when hit, shatters, and doesn't break nice, or wear well. You'd want a kevlar, or carbon/kevlar weave to keep it together after an impact.
Gunman is offline
The Following 2 Users Say Thank You to Gunman For This Useful Post:
DAEMANO (07-12-2015), eric6 (07-13-2014)
Old 07-13-2014, 07:12 PM   #228
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I've hit triple digits multiple times at track events and it's been ok but it's definitely worth to upgrade to race version I think ..
Below is my post from my "Functional aero" thread
I had a chance to test the front splitter and @Wonderbar Driveway Labs T1 diffuser yesterday, woot!
ambient temps were about 92 F+ degrees (a more robust oil cooler is a must at this point) and I had to deal with the traffic all day.. I should be able to cut another 4-5 seconds with the current setup easily..
Important things to note, car feels a bit more planted after combining the Hancha/FT86SF front splitter with the Driveway Labs T1 rear diffuser (especially at high speed corners/sweepers) ..braking down feels a bit more improved as well ..either that or it's a placebo effect
[ame="http://youtu.be/lqiiD42H0d0"]http://youtu.be/lqiiD42H0d0[/ame]
glamcem is offline
The Following 2 Users Say Thank You to glamcem For This Useful Post:
eric6 (07-13-2014), zdr93523 (09-16-2014)
Old 07-13-2014, 07:20 PM   #229
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
We will never stop improving the products we create and are always on the hunt for a better material. The main issue is cost as we want to keep this as an affordable option for nearly everyone, that can then be replaced when/if needed without hurting your wallet.
eric6 is offline
The Following User Says Thank You to eric6 For This Useful Post:
JDKane527 (07-13-2014)
Old 07-13-2014, 07:31 PM   #230
Gunman
@Rocket.BRZ could have a layer of carbon put on the exposed top, if it's just for looks.
Gunman is offline
Old 07-13-2014, 07:57 PM   #231
eric6
eric6's Avatar
He definitely could. And that would make this splitter ridiculously rigid.
eric6 is offline
Old 07-13-2014, 07:59 PM   #232
Rocket.BRZ
Any chance you could give me your opinion on my apr splitter thread please.
Old 07-13-2014, 08:19 PM   #233
troek
troek's Avatar
Drives: 2012 Toyota 86
My friend had a carbon splitter on his r32 attached without any ties to actual structure, we warned him against it multiple times. then doing about 250kph i saw a cloud a mist come out the back of his car, us in the the car behind thouhgt it was an oil line or maybe a charge pipe. when we flagged him to pull over we found out it was his splitter. That thing just dissapeared.
troek is offline
Old 07-13-2014, 08:28 PM   #234
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Hey its no problem, don't mind being the guinea pig lol. The way I see it, it was bound to happen to someone eventually. Did I mention I miss it... car doesn't look the same/right without it, and the steering feel is all wrong again. Can definitely feel the shift of aero balance rearward (driveway labs type 1) since the splitter is off for now.
Kwaziekeller is offline
The Following User Says Thank You to Kwaziekeller For This Useful Post:
eric6 (07-13-2014)
Old 07-22-2014, 11:38 PM   #235
kster1
kster1's Avatar
Each kit will include a (8) 1" OD washer that can be used to install on the top side of the bumper with the rivet-nut. This should dissipate the load and reduce the likelihood of the rivet being pulled through in high force applications.
Eric,
I just received the splitter today (the etching looks great BTW). I don't see these eight washers that go into the ten rivets. The kit included maybe 14 washers but these don't fit in the rivets. Or have I misunderstood something?
I'm assuming the washers will go between the "x" of the rivet and the plastic bumper (on the inside).
Also planning on waiting for the splitter ties before I install this.
kster1 is offline
Old 07-23-2014, 11:09 AM   #236
eric6
eric6's Avatar
I sent these to ft86sf, I'm guessing he started sending out the splitters before he received this package. I'll talk to Jeremy and ask him to forward those bags.
eric6 is offline
kster1 (07-23-2014)
Old 07-23-2014, 01:09 PM   #237
kster1
kster1's Avatar
FT-86 SpeedFactory has already shipped out the washers to me. Great customer service all around.
kster1 is offline
The Following User Says Thank You to kster1 For This Useful Post:
eric6 (07-23-2014)
Old 07-24-2014, 12:31 PM   #238
eric6
eric6's Avatar
That's great to hear. And to expand on your other question.... Yes, the washers go on the top side of the bumper, where the "x" of the rivet nut will be.
eric6 is offline
kster1 (07-24-2014)
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
What front splitter? Takumi788 Cosmetic Modification (Interior/Exterior/Lighting) 7 04-30-2014 06:20 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 09:03 AM
BRZ Front Splitter Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 43 01-26-2014 03:29 PM
Front Air Splitter sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-17-2013 05:41 PM
