#225 |
in orbe terrum non visi
Drives: violent
Holesaw it and put short sections of pvc pipe through.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#226 |
The radiator needs to be moved forward. It was the only way enough clearance could be gained on my FB turbo kit.
I think the kit now comes with new upper-mount tabs, but moving the radiator forward at the bottom is where most of the clearance is gained. IMO every front mount turbo kit should include moving the radiator forward. It's too easy to do and gains the needed clearance to not melt/overheat parts. Fans on ALL the time, or on at a super low temp, keeps radiating heat from melting parts. With the extra clearance, there's room to install some heat shielding between the DP and where it is closest to the fans. My header and DP are both ceramic coated and wrapped, and it still gets hotter than hell under the hood. I'm not sure how effective my skidplate mods are yet, but either that or a vented hood I think is necessary for track use. The hot engine bay air needs a way to get out. |
| The Following User Says Thank You to mike the snake For This Useful Post: | D K (05-13-2014) |
#227 |
Trust me, I'm the Doctor
What about for those of us wanting to go the SC route with FI? Vented hood still a good idea, or unnecessary? I know that SC's produce LESS heat than a turbo, but how much?
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#228 | |
The amount of heat inside the engine bay is significantly less. It's not something we've quantified, but it's substantial. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | SirBrass (05-13-2014) |
#229 |
IMO, just as much attention must be paid to exhausting the engine bay air.
Hot air needs to be pushed or pulled out, preferably pulled out, so low pressure areas pulling the higher pressure engine bay air out. Vented hood accomplishes this, the mod I did to the skidplate helps I think as well. Otherwise, the highest pressure air coming in through the grill needs to pressurize the engine bay which pushes the hot air out underneath the car/engine. This is where we are now. Possibly reinstalling the air dams will help a little. Properly shaped and placed vents could passively pull the needed air and cause a quick air exchange, which is what is really needed. |
#230 | |
Would be nice if someone came out with a lightweight aluminum vented hood where proper R&D had been done for efficient venting and fitment.
#231 |
Drives: Silver BRZ
#232 |
#233 |
Drives: Silver BRZ
It seems you're looking to treat symptoms of the problem rather than preventing the problem in the first place ...
is radiant heat is the issue look for a more efficient turbo set up that produces less "radiant heat" this can be achieved by more efficient pipe routing, turbo selection, tune... I can understand that you see the issue as impossible to solve but i highly doubt you have exhausted all possible avenues of resolution. On a side note.... who cares if the fans melted.... Racecars don't need fans |
| The Following User Says Thank You to FAER For This Useful Post: | Mrc@ptuning (05-13-2014) |
#234 | |
Drives: S1000RR
That's the best thing you can do for your track car's cooling system in addition to upgrading the radiator, flush the coolant and run distilled water/redline waterwetter. |
| The Following User Says Thank You to Mrc@ptuning For This Useful Post: | OjiGeorge (05-14-2014) |
#235 | |
#236 |
What about moving it to a "behind the engine" configuration, or a rear-mount configuration? Is that possible with this turbo?
#237 | |
Perhaps at the end of the year... the car can't be down for that long while it's being campaigned. |
#238 | |
Is coating the turbine housing with a strong insulation coating as well as doing the turbo blanket an option? I'd have suggested good airflow over the turbo, but EGTs need to be kept up, but the radiant heat needs to be addressed. So, somehow divert the radiant heat of the turbo and hotside parts away from the radiator.... Hard in such tight confines. It's like expecting a virgin trapped on a lifeboat with 3 sailors for 3 months to remain a virgin....
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 09:23 AM |
| So who is running Forced Induction and tracking their car? | track_warrior | Tracking / Autocross / HPDE / Drifting | 88 | 08-20-2013 11:00 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
