Old 10-14-2014, 05:26 AM   #225
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
You need a pump to pump oil from the transmission through a cooler and back into the gearbox. We use a Tilton pump and they run about $250 retail and by the time you're done you'll have about $500 in parts total and a healthy amount of labor and some minor fab to get a good transmission cooler setup.
Element Tuning is offline   Reply With Quote
Old 10-14-2014, 07:57 AM   #226
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I'll be swapping in a tremec this winter.
Old 10-14-2014, 09:15 AM   #227
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
What's that going to cost reaper?
BRZGM3 is offline   Reply With Quote
Old 10-14-2014, 10:48 AM   #228
Element Tuning
Seems like the TKO has some shifting issues and is only rated for 6800 rpm. That's a far cry from 9k rpm we run up to with the Element motors. Probably worth talking to Don about the RPM he runs and or if he sells a kit without the transmission as there are some companies that build the TKOs to handle more rpm and shift better.
Old 10-14-2014, 09:11 PM   #229
Poodles
Drives: 2015 Series.Blue
I've got a communication in with someone I knew that ran a TKO in a car running 8K RPM to see his experiences. From what I remember he had zero issues.
Old 10-14-2014, 09:32 PM   #230
Dipstik-sportech
Dipstik-sportech's Avatar
I know of many tko's and t56/t6060's that don't like shifting over 7000rpm. You can modify them to shift at higher rpm but it requires you to faceplate the gearset, then it's not a really street friendly.
Old 10-14-2014, 10:38 PM   #231
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Because racecar and puck clutch arent street friendly enough
Old 10-14-2014, 10:39 PM   #232
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
In other news...it seems like 4th gear is the culprit in these transmission shearings.
Old 10-14-2014, 10:55 PM   #233
Reaper
Reaper's Avatar
Drives: violent
Liberty gear claims they have fixed the tko. Don says he runs them pretty hard
Old 10-14-2014, 11:05 PM   #234
Poodles
He got back to me...
"Had nothing but trouble shifting that Bitch Poo...
3rd set of synchro's and I was done.. "
I'm asking if he knows any other options besides the V160 since he's been building crazy cars since before I was born.
EDIT: His reply
"The newer TKO/Tremec line got much better Synchros "
I'm taking that to assume Tremec knew they had an issue and have fixed it... Honestly I'd be contacting Tremec directly.
Old 10-15-2014, 08:17 AM   #235
Element Tuning
Argh! Yeah based on what I had read for reviews it seemed like shifting at high rpm was questionable for many. This is why I was thinking of buying a Tremec that was worked over and getting a fitting kit from Don.
Maybe just pony up the $10k for the Hollinger sequential? Has anyone jumped on that and tested it to be the cat's meow? I'm nervous because one of the teams I race with picked up a $30k sequential for the STi and it broke at the same power level as OEM.
In any event guys I do think a transmission cooler will help the box handle more torque. Seems a little silly for a street car but definitely seemed to give me an edge on the track.
Old 10-17-2014, 11:55 AM   #236
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Another race weekend in the bag and the Element Tuning Pro Comp engine is still singing along. Very happy to say the least!!!! Not only that but we broke the NASA TT2 lap record at VIR running a 1:58.
The ABS computer is nuts in this car and God only knows why it shuts off and or goes into ICE mode.
Congrats. Makes me wish I had gone for a BRZ for my TT3/TT2 build, then I read that part at the end and it reminds me why I went with an S2000 instead, haha.
Old 10-17-2014, 12:37 PM   #237
D K
Stig's dark passenger
I have been talking to Tremec and a few other shops/specialists with regards to roadracing a Tremec for over a year...
Bottom line, if you want to use a Tremec, the only one that makes sense is the Magnum. And even then, you are very close to the upper rpm band here they like to shift.
Stock rpm is doable, 9k - not so much.
Dedicated dogbox is nice, but they require an infnite amount more servicing.
I wouldnt even mind the unfriendliness on the street so much, but the service interval reminds me of a top end job in a shifter kart.
Im personally looking at the Magnum, even if I have to mangle the tunnel.
David
D K is offline   Reply With Quote
Old 10-20-2014, 10:02 PM   #238
Element Tuning
David
Well all good information to work with. The Magnum is super heavy though!
A "dog" box is not the same as a "sequential. " Something like a PPG dog box or even a syncro (dog is just the engagement type) set don't really require any extra maintenance. For easier daily driving with dog engagement you just double clutch your upshifts and its not a "crash" box then.
A sequential can require more maintenance but most likely that's a scheduled "race" maintenance. I'm sure using your clutch when not racing would lengthen service intervals immensely.
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
