Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 06-30-2016, 01:01 AM   #225
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Cool stuff. I can't wait to hear your thoughts on those unfamiliar pads.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 06-30-2016, 02:46 AM   #226
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
I'm very keen to try them.
I'll fit them this weekend, which will give me two weeks to play with them before Michelin Cup on the 16th.
I must also do brake fluid - I could feel it was getting a bit squidgy last weekend.
BTW, I don't do a full brake fluid flush anymore - only once a year or even longer.
Normally, I just drain a bit from the front calipers which I dump, pump some fresh'ish fluid through the lines, and top-up.
Takes about 400ml.
Fish Eagle is offline   Reply With Quote
Old 06-30-2016, 02:59 AM   #227
sav
sav's Avatar
Cool, that's what Mike Bond from International Race Supplies(PFC) also suggested but with a twist. He said you should always bleed the fluid out of the calipers before a track day. Makes more sense doing it after to be honest.
I've never used Endless pads before so I can't compare but at P4P the 50m mark was just suggestion and I ended up braking much much later on every corner without any fade which I thought was impressive considering the sessions were longer than usual.
That's with one step compound below what you've got.
Speaking of bleeding brakes, I got myself one of these:
Which should make life a bit easier.
95RON SAV Tuned
Old 06-30-2016, 03:26 AM   #228
Fish Eagle
Platinum Member
Fish Eagle's Avatar
That's nice.
Fortunately I have sponsor who does my brake bleeding for me.
I normally do pads changes myself - he does bleeding and disc changes.
Old 06-30-2016, 03:30 AM   #229
sav
sav's Avatar
Lucky.
95RON SAV Tuned
Old 07-02-2016, 05:16 AM   #230
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Did brake pads this morning, and I decided to do the bleeding myself too.
Bad news for you @sav because the old pads still look great (after 6 track days) so I put them back in again, and you'll have to wait a bit longer to find out how the "unfamiliar" pads work in my car
It's amazing that the harder and faster I go, the less pads and tyres I use.
Old 07-04-2016, 12:46 AM   #231
sav
sav's Avatar
That is very good going. 6 track days...wow.
95RON SAV Tuned
Old 08-03-2016, 08:52 AM   #232
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Had my first ever brake disk failure today.
Amazing that it wasn't on track, and it wasn't under any stress whatsoever. Lindy and I were taking a leisurely drive up to Kaapsehoop when it went pop.
My brake disks always crack badly on track but they're surface cracks and not a problem - that's common. Today's failure is a crack right through the disk and it goes to the outer edge where it's very visible. Loud and obvious clack-clack-clack when braking.
The disk was at the very end of it's life anyway. I'd already decided to replace them because they're very worn and cracked, and new pads take a long time to seat on them because they're worn unevenly - more wear close to the hub than further out. They're a year old and have done 12 track days, so whatever...
New disks are on their way - should get them on Friday. It'll be my first set of Powerbrake's new black disks. Going to be interesting to see how they perform.
Old 08-04-2016, 12:33 AM   #233
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
What disks failed andy, oem or pb?
GeeTee86 is offline   Reply With Quote
Old 08-04-2016, 12:41 AM   #234
Fish Eagle
Platinum Member
Fish Eagle's Avatar
PB disks.
I'll put in new disks this weekend, then study the old ones carefully once they're out the car. It's possible (read likely) that I pushed them beyond reasonable temperature and wear limits.
Old 08-04-2016, 01:18 AM   #235
GeeTee86
86 Nut
GeeTee86's Avatar
Please share your findings with francois and leon
Old 08-05-2016, 07:30 AM   #236
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Yep, excessive and uneven wear (more wear closer to the hub) and I probably overheated the outer part of the disk when bedding in new pads.
Whatever. They were ready for the bin anyway...
Old 08-05-2016, 07:51 AM   #237
GeeTee86
86 Nut
GeeTee86's Avatar
are the heat indicators gone on the disk?
Old 08-05-2016, 08:21 AM   #238
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Yep, but they're normally all gone after my first day on track anyway, so not meaningful.
I'm not fussed about it at all.
Those old rotors were beyond their sell by date.
I'll know next time not to push them that far.
gc8 4 pot brakes wholeeoh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 05-15-2022 04:38 PM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 12:33 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
