Old 11-20-2020, 01:47 AM   #225
Steveiam
Drives: 86
-JDL V2 UEL Manifold, GTX2860R, Recirculated
-E85
-7/10 psi
-2.5'' JDL dual resonated frontpipe/overpipe combo, MXP SP Catback, Delicious EBCS, ID1050X fuel injector, DW300c fuel pump, PTuning flex fuel kit
-Tuned by Zach at Counterspace Garage
Steveiam is offline   Reply With Quote
The Following 6 Users Say Thank You to Steveiam For This Useful Post:
anticubus (11-20-2020), DarkPira7e (11-20-2020), Drifter X (11-20-2020), jflogerzi (11-21-2020), Pete (08-20-2021), tomm.brz (11-20-2020)
Old 11-20-2020, 11:02 AM   #226
Calum
That Guy
Drives: 2013 asphalt FRS MT
That's not a torque curve, it's a torque shelf. O_O
The Following User Says Thank You to Calum For This Useful Post:
Old 11-20-2020, 12:44 PM   #227
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
-E85
-7/10 psi
It's incredible that the GTX technology allows the turbo to reach those level ( E85 or not) with only 10 PSI. It's no wonder people are into 600s with the 3076
Old 11-20-2020, 09:21 PM   #228
anticubus
Drives: 2017 Toyota 86
I'm drooling over that, that's the closest I've ever seen to a perfect WOT dyno graph that isn't artificially torque limited by the tuner. Flat line of torque, HP goes up and to the right, it's a work of art.
anticubus is offline   Reply With Quote
Old 11-21-2020, 06:55 AM   #229
Calum
That Guy
Yeah, but what kind of damage is that non limited torque curve doing to the engine? (honestly curious)
Old 11-21-2020, 11:51 AM   #230
DarkPira7e
DarkPira7e's Avatar
Torque stress is lower on the rotating assembly as RPM increases. Lower RPM torque is what breaks things. I think the reason the torque line is so smooth is because boost is being tapered in gradually (this is how I had my car tuned). It's great because it helps with predictability, stabilization, and not being bored with the car after 5k RPM. When you have torque ramp in early by shoving boost in and then having to hold it there, it doesn't feel as rewarding to rev the car out
The Following User Says Thank You to DarkPira7e For This Useful Post:
Calum (11-21-2020)
Old 11-21-2020, 01:13 PM   #231
jflogerzi
jflogerzi's Avatar
I guess I will add mine even though I am going to puling it off the car PM if your interested
Sprintek 210+69mm+FF+Tuned by Zach@CSG
JDL 4-2-1 EL, Stock FP with Vibrant LN RES, MXP SP CB
E65
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
BrahmaBull1990 (05-19-2021)
Old 11-21-2020, 02:03 PM   #232
DarkPira7e
DarkPira7e's Avatar
E65
Why are you removing it? The Sprintex car I've been in felt perfect, it's exactly what I'd want if I were an OEM+ kind of guy
Old 11-21-2020, 03:59 PM   #233
jflogerzi
jflogerzi's Avatar
Keep it short and sweet:
1)CARB aka California and smog
2) I want to compete in the SoCal FT86 cup and with all my mods it would put me in the modified group which I have zero shot as a driver to compete in. Plus this Kit is the worst on the track as it does heat soak quickly in high temps. I want to get better as a driver and this will allow me compete in the street class which I have a much better shot at
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
BrahmaBull1990 (05-19-2021), DarkPira7e (11-21-2020)
Old 05-08-2021, 12:23 PM   #234
Ignore Your Doctor
Ignore Your Doctor's Avatar
Drives: 2015 BRZ WRB
Been running this tune from DBW Motorsports in Atlanta for about a year now and going strong!!! Ready to update my fuel system and see what she can do with racefuel/e85.
2015 BRZ JRSC c38 kit JDL 4-2-1 EL 3" JDL Double Resonated OP/FP combo 3" Perrin Resonated CBE
Ignore Your Doctor is offline   Reply With Quote
The Following 4 Users Say Thank You to Ignore Your Doctor For This Useful Post:
BrahmaBull1990 (05-19-2021), DarkPira7e (05-08-2021), PulsarBeeerz (05-20-2021), tomm.brz (05-08-2021)
Old 05-16-2021, 11:30 PM   #235
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
made 293 whp 8psi and 234 5psi on what is probably 93 RON in the US. 5 psi is just for putting around town.
Greddy T518Z
5 PSI AND 8 PSI MAP
Farbricated 3inch straight pipe exhaust with a big muffler
Lucky21 is offline   Reply With Quote
The Following User Says Thank You to Lucky21 For This Useful Post:
DarkPira7e (05-17-2021)
Old 05-18-2021, 10:09 PM   #236
dynarun55
Drives: 2015 midnight blue limited edition.
Quite literally the reason I will go with a Jackson racing C30 supercharger
dynarun55 is offline   Reply With Quote
The Following User Says Thank You to dynarun55 For This Useful Post:
DarkPira7e (05-18-2021)
Old 05-20-2021, 12:33 AM   #237
jflogerzi
jflogerzi's Avatar
Greddy T518Z
5 PSI AND 8 PSI MAP
thats perfect in my eyes. This car does not need much more than that
Lucky21 (05-20-2021)
Old 05-25-2021, 11:00 PM   #238
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
E65
Damn this sounds soooo good
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
jflogerzi (05-25-2021)
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 11:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
