Old 07-31-2015, 11:13 PM   #225
timmydatooth
Drives: Scion Frs
Was thinking of getting the 17x9 +35 rpf1's for my scion frs. Im gonna leave it on stock suspension. Are 9in wheels ok for daily driving or are wheels that wide mainly for racing? Just still want to remain functional and not worry about oversteering or understeering.
timmydatooth is offline   Reply With Quote
Old 08-01-2015, 07:10 AM   #226
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
I'm on 17x9 with stock suspension. But my wheels are +45. And they sit flush with the fenders. +35 clears suspension parts more but would stick out slightly. So would require camber adjustment to clear the fenders. But someone correct me if I am wrong. If you adjust the camber to clear the fender you will likely be rubbing the stock springs. That why 90% of everyone runny 17x9 +35 run coilovers. The springs smaller diameter helps with clearance.
BoxRZ_86 is offline   Reply With Quote
Old 08-01-2015, 08:01 AM   #227
timmydatooth
Drives: Scion Frs
Ok so +45 would be more suitable for someone on stock suspension? I just dont want to have to adjust anything after putting new wheels on. So im guessing +45 is probably better than +35 since its closer to the stock wheels offset
Old 08-01-2015, 08:04 AM   #228
BoxRZ_86
BoxRZ_86's Avatar
Just to let you know the clearance is very tight with +45 but I have been on 245 tires with no issues for 2months and driven long distances. But I have sumitomo htr z iii. All tires fit differently
Old 08-04-2015, 01:54 AM   #229
s2d4
s2d4's Avatar
No.
Old 08-04-2015, 05:58 AM   #230
Apexer
Drives: 15 Halo
Originally Posted by s2d4 View Post
No.
So +35 will fit a stock car with no problem's? I'm looking to buy a set, but wait on coil's.
Apexer is offline   Reply With Quote
Old 08-18-2015, 08:49 PM   #231
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by Lee358 View Post
Here are some pictures for you if you want anything more feel free to ask i love taking pictures of my car!
Attachment 44453Attachment 44454Attachment 44455Attachment 44456Attachment 44457Attachment 44458
did you add spacers on these?
BRZ RN is offline   Reply With Quote
Old 08-28-2015, 06:14 AM   #232
ravisraval
Drives: 2013 FRS
What BBKs fit these wheels? Wilwood 4 pots? 6?
ravisraval is offline   Reply With Quote
Old 09-06-2015, 09:53 PM   #233
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Why do you need 6-pots on a 165whp car?
The Following User Says Thank You to BlaineWasHere For This Useful Post:
trinidadj (03-28-2017)
Old 09-07-2015, 02:45 AM   #234
ravisraval
Drives: 2013 FRS
Who said I plan on it staying 165 whp
Old 09-07-2015, 02:51 AM   #235
BlaineWasHere
Grip>Drift
Drives: FRS
Well double it and 4 pot is enough. Lol.
Old 10-28-2015, 05:45 AM   #236
Vesalera
Drives: Infiniti g20, 14 scion Fr-s
Originally Posted by bryan767 View Post
Some tires are wider then others, even if they are the same spec.
Mine were touching the spring perch on eibach pro springs.
Since I went with coilovers I have 0 need for any spacers, however I am running a 3mm spacer in the rear just because I like the look.
Your fitment is relatively on point to what I'm aiming for. I just picked up a set of Rpf1 17x9 45+ 225/45/17 Bridgestone Potenza
My current setup Tein flex Z on stock wheels 25mm spacers rear 20mm front for flush fitment.
My first question is already answered as it will clear since I'm on coils
2nd question -What mm spacer would I need for a flush fitment on a 225 tire?
Vesalera is offline   Reply With Quote
Old 10-28-2015, 06:58 PM   #237
learnerspermit
learnerspermit's Avatar
Drives: C-17A
Probably going to inherit some 255/40/17 Dunlop Star Spec 2 from my TE-37's on my old S2000 and I think some RP's would be a suitable wheel to finish these tires off since they are almost brand new.
I daily my car and while plans are to go to coil overs at some point, my question is this is a fairly large tire (when measured) so would +45 RP's fit these alright on the stock body without rolling or rubbing? Even after coil overs Im not planning on lowering the car much at all due to daily driving.
Im not into the stance "life style" Im just looking for practicality.
learnerspermit is offline   Reply With Quote
Old 10-29-2015, 01:32 AM   #238
BlaineWasHere
Grip>Drift
Drives: FRS
You'll need coilovers for spring clearance. Lower offset will help like 35-40
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 05:18 PM
