#225 |
Drives: Stock
So did another high speed test this week let's just say it's bad! First off I changed rims and tires, still na. I got a cheap set of rims that weigh a lot but I figured it make it look better and I could test a fitment that I wanted with out spending 2000 and being disappointed. So for tires I went with a meaty tire a 245/40-18 instead of a 225/40-18 yea I know crazy right. So first few days there was rubbing because I hadn't got a alignment. After the alignment no rubbing unless I hit a big bump going to fast or let's say the was a steep inlince like a drive way. So all good there. ... so. The test run I was expecting to hit 160 165 because the bigger tires in effect lower final drive ratio. So yes it's a bit slower driving around town but it's smoother too! Well I end up hitting 137�� Wtf! Any thoughts. It's either the heavy rims or the cars power level doesn't have enough with the new final drive to push faster. I think that their is it not enough power now. Really sucks I guess il have to go back to a normal tire size and see what happens!
#226 | |
Drives: '17 Camaro SS 1LE
#227 |
Drives: Stock
#228 | |
Drives: 2017 manual BRZ
Sent from my Pixel XL using Tapatalk |
#229 |
Drives: '15 BRZ RA
Many times in the range of 140-145 mph.
#230 |
#231 |
Drives: Stock
#232 |
#233 |
Drives: Toyota GT86 Coupe Red (UK)
When you changed the tyre size did you recalibrate the speedo or are your driving with a broken one?
Don't know about over there but insurance companies here will invalidate your insurance if you change the size of your wheels (rolling circumference) unless you can prove you re-calibrated the speedo. Not to mention the police might be interested. If you fit larger circumference wheels the speedo under reads. Fit smaller ones and it over reads. By default on stock wheels the speedo under reads by about 10%.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#234 |
A fun piece of math and physics for you top speed masters.
According to the attached formula, what would be the theoretical top speed of a stock, 2013 FR-S with a manual transmission..?? Note ..... be sure to use estimated wheel horsepower. humfrz |
#235 | |
Drives: Stock
With 245/40-18 @ 7500 rpm math works out to 184 Sorry to say I didn't use your formula humfrz just used a basic program that figures tire size and gearing. Last edited by -Willis-86touge; 04-23-2017 at 04:55 PM. |
#236 | |
Drives: Stock
#237 | |
![]() Down here on earth, pushing air out of the way is a big factor, especially at higher speeds........ ![]() humfrz |
#238 |
Drives: United States
Got to about 120mph, took me about 37 minutes. there was more room but I was running out of road and patients waiting.
2013 BRZ limited, FBO stage 2 and more - SOLD
2015 Silverado LTZ Z71 Midnight edition - DAILY 2013 FRS turbo - coming soon! |
Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
Need For Speed... Really? | Texas BRZ | Tracking / Autocross / HPDE / Drifting | 61 | 01-11-2013 11:59 PM |
Top Speed | L3P47 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 12-18-2012 12:06 AM |
top speed | JLMtm | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 10-30-2012 09:23 AM |
speed | eindio | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-27-2012 10:59 AM |
