Old 11-02-2011, 07:35 PM   #225
nate89
nate89's Avatar
Drives: MR2
Originally Posted by WingsofWar View Post
otherwise maybe 2650 is still too heavy...and 200hp is still to much power for what im asking to feel.
Sounds like you need a bicycle lol
nate89 is offline   Reply With Quote
Old 11-02-2011, 07:40 PM   #226
Allch Chcar
Drives: N/A
Go-kart>Bicycle
NA Miata and Hachi-Roku were 2200lbs, so no not even close to go-kart levels of lightness.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-02-2011, 07:47 PM   #227
Aki
Drives: '96 beater Corolla
Here's another page. The text on the bottom is like a glossary, some of it is cut off and hard to read but it's not saying that much:
Aki is offline   Reply With Quote
Old 11-02-2011, 07:55 PM   #228
keiri
Toyobaru Wonder Twins™
keiri's Avatar
Drives: 2020 Subaru BRZ Limited w/ PP
A coefficient of drag .02 higher than the Prius' is fantastic. This thing cuts through air pretty well.
And a big thanks to all of the guys translating these leaks; Aki, Ichi, Fred. Hats off to you gentlemen!
keiri is offline   Reply With Quote
Old 11-02-2011, 08:01 PM   #229
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
You don't even know how much these can be bored out.
If its just a FB block, not much...
Kostamojen is offline   Reply With Quote
Old 11-02-2011, 08:06 PM   #230
ruskymx
ruskymx's Avatar
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
The aerodynamic stabilizer fin is most likely very similar to what they put on the 12 Camry.
Ruskymx
ruskymx is offline   Reply With Quote
Old 11-02-2011, 08:07 PM   #231
Aki
And another...
Old 11-02-2011, 08:11 PM   #232
KevinDuMa
Drives: 2004 Honda S2000
Thanks for translating Aki!
KevinDuMa is offline   Reply With Quote
Old 11-02-2011, 08:13 PM   #233
ryridesmotox
Drives: 2010 Chevy Cobalt SS, 59 Ford F100
Thanks AKI...
I wonder why they don't tune it for the DI injectors to run from Idle to redline and the port injectors to run on a demand level... as demand increases the flow to the port injectors would also increase, increasing the fuel into the cylinders, but the DI stays relatively constant.
Edit: I'm only saying that cuz via the "dyno chart" on that recent brochure post, it seems like it takes a huge hit right in the middle... It doesn't need to do that, it seems that they are switching between the 2 fuel systems rather than using one as a piggyback to the other to increase flow... God I hope that makes some kind of sense, it does in my head at least.
Treadstone Performance Stage 3 kit: CAI, Charge Pipes, TR8 intercooler, Maf Relocate, 52MM Turbosmart BOV, 3 inch catless downpipe, 3 inch catback, borla XR1 muffler, Exedy Hypersingle, TWM short throw shifter, 24PSI HPtuned by Terminator2 on E85/91
ryridesmotox is offline   Reply With Quote
Old 11-02-2011, 08:14 PM   #234
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Aki Thanks!!! Looking forward to the rest! (and tonight/tomorrows/whenevers next leak lol)
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 08:22 PM   #235
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by ryridesmotox View Post
Thanks AKI...
That's not the real dyno chart I'm fairly sure, the difference in torque is too big for a motor with one lift profile. With one lift profile the torque curve generally has one distinct peak, as below that the flow velocity into the cylinder is crappy and above that there is more restriction. With multiple lift profiles you get multiple "humps", and with continuous duration/lift you would probably get an inclining curve (although it's very programming dependent and such) since the extra intake duration at high rpm just spits air back out at lower rpm, but you most likely can't use the most lift possible at low speed. With a continuously changing lift profile like Ferrari, the "Williams Helical Camshaft" (basically Ferrari except more late intake closure focused, and a moving helical piece instead of one solid piece), or Fiat Multiair (which can change lift a tiny bit more flexibly than Valvematic/VVEL/Valvetronic), you can get just about anything, but in theory you'd be able to get a curve that just keeps going down: frictional losses and lower effective expansion due to relatively slower burning speed increase. However these systems tend to have very high lift built in and aren't as optimized for low rpm, so results vary a lot. They just drew some crap to show everyone how D4-S improves everything.
Old 11-02-2011, 08:25 PM   #236
GotBoost?
Drives: 2007 OBP STI (SOLD)
Well, lets just hope the ECU is tuner friendly, because if it is I'm not to worried about that little dip. I'm also assuming that the car is under tuned, and with a nice tune and your basic bolt-on parts you could easily increase your power by a fairly good amount.
GotBoost? is offline   Reply With Quote
Old 11-02-2011, 08:26 PM   #237
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
so NOO 4 tires/wheels....
for the FRS type R? cause it'll have a rollcage.
CyberFormula is offline   Reply With Quote
Old 11-02-2011, 08:28 PM   #238
Aki
Another...
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 10:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 07:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 02:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 01:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 06:35 PM
