Old 06-19-2015, 08:33 AM   #225
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Originally Posted by Gopherboy6956 View Post
Well I actually lucked out today. Walked in to Menards (where i always shop anyways) and low and behold - BAM
http://www.menards.com/main/plumbing...648-c-8553.htm
Home depot has brass ones http://m.homedepot.com/p/SharkBite-1...LFA/202270567/
These are also ok to install?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 06-19-2015, 02:50 PM   #226
xxscaxx
Drives: 2013 SWP BRZ
yes.
xxscaxx is offline   Reply With Quote
Old 11-10-2015, 03:08 PM   #227
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I didn't see it in the thread, but where can I get the actual lines that go to the PCV valves (is that the right term, valves)? Just bought a used catch can with no tubing.
Jyn is offline   Reply With Quote
Old 11-13-2015, 12:24 PM   #228
Astroboy
Astroboy's Avatar
Drives: None
I don't really catch anything in mine
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 11-13-2015, 03:10 PM   #229
Jyn
Noob
Jyn's Avatar
For future reference, I got all the hoses and even the step/reducer for 3/8" to 1/2" from O'Reilly's Auto Parts. The reducer I had to ask for, since they kept them behind the counter.
If you try to run 1/2", it will be too loose on the PCV Valve for even clamps to fix and you'll throw a P0171 lean code. Learned that
The Following User Says Thank You to Jyn For This Useful Post:
MJones_RB (06-15-2018)
Old 12-03-2015, 02:29 PM   #230
g0odspeed
Drives: 2013 Scion FR-S Asphault
This might be a dumb question. I've seen on some installs where they only vent the manifold and block the return. Essentially they vent into the atmosphere. I have a turbo installed and it doesn't have the return on the intake side so i would need to use a catch can and vent into the atmosphere. Why can't you vent both locations into one catch can using a y flange and vent both into the atmosphere, blocking the return on the manifold? Someone help me with this thinking. Can you even do this or will it cause issues?
g0odspeed is offline   Reply With Quote
Old 05-06-2016, 12:58 PM   #231
asnatlas
Drives: 2013 - BRZ - SWP
I think I am going to pick up the Radium Dual Oil Catch Can Kit to go with my Jackson Racing C38 kit...
asnatlas is offline   Reply With Quote
Old 10-25-2017, 04:50 AM   #232
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Has anybody considered just buying one radium catch can to save money a couple hundred?
Buy one radium catch can set, 2 Barb Tees, some tubing and connect both crank case + PCV, then rewire them back to both holes ... or plug up one of them?
I don't know much about the mechanical parts about cars or really modding .. but is there certain air pressures that these two outlets are at that makes this a bad idea? I'm pretty sure doing this is bound to save ~$150.
I guess the wiring might be a bit odd/clustered in the engine bay?
edit: NVM, apparently they're different pressures
Old 01-03-2020, 11:17 PM   #233
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Been a while... but I finally did what I wanted to do for a mount ever since I got the Radium catch can. Don't have it installed in car yet, but here's the difference between old and new:
Circa 2013:
Now:
I fabbed the pieces for the brace bracket and my brother welded it. Painted, clear coated, and waxed both L and R factory braces so they would match. I'll get pictures once it's installed...am using black racing hose to go OEM look this time.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-07-2020, 03:12 AM   #234
Vracer111
Vracer111's Avatar
And here's the installed pictures:
2013 FR-S Product Technical Info and Specs (from Las Vegas press event) ichitaka05 Scion FR-S / Toyota 86 GT86 General Forum 53 07-19-2021 06:59 PM
Fifth Gear reviews the GT86 (Full Video) lazyluka Scion FR-S / Toyota 86 GT86 General Forum 20 10-10-2012 07:09 AM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-03-2012 12:11 AM
