#225 |
Drives: '06 AM V8V Coupe
Oh, I had no idea. I assume they don't run the engine at the very limit for reliability, so I'm speculating on how much headroom they leave. So I realize if you give only like, 3psi boost, that's still a >10% increase in peak absolute temperature (assuming gamma=1.4, not that good of an assumption..but still), which is pretty significant.
#226 |
Drives: free Hyundai, 2006 Kawasaki ZX6R
What needs to be done to lower compression to make an engine more boost-friendly? Ie. if someone where to boost this car, what measures would you take to make sure it is as safe as possible? Does it depend on what type of FI you go with? SC vs. turbo?
#227 | ||
Drives: N/A
The power from adding boost more than makes up for the power lost from pulling timing. Plus you can keep the timing advance when off boost. Am I right WoW? |
#228 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
If we wanted to build peak performance on and off boost, having an adjustable timing map is the golden ticket. Here is the shitty part about this whole conversation, since we are ultimately applying this to the D4-S 2.0 flat-4, which would most likely have a compression ratio ranging anywhere from 12-13.5. This is not because the internal chambers produce that much compression, but due to the fact that the direct injectors themselves inject fuel DURING compression stroke, after port fuel has been injected via, intake stroke. Here we add boost, no matter how much timing you pull we might be reaching the limits of how much pressure each cylinder can handle even under small boost. There are a few other variables im not to sure of as well...
#229 |
With a fuel like gasoline that doesn't absorb that much heat upon vaporization, yea operating under max power with only direct injectors during compression stroke will increase pressure. But say the A/F ratio is 13:1, then we are adding 1/13 atm pressure, minus whatever the cooling effect is, so it's like adding less than 1 psi "boost"... is that significant? I don't have any context to take it out of, never owned a car :P
#230 | |
MODERATOR-SAMA
a 13:1 Target AFR under no load no boost idle will probably using port injection or direct injection but not both at the same time. This will probably make the ECU adjust timing more advanced to use that rich mixture for better performance and economy. a 13:1 Target AFR under Cruse load/ with no boost, (2500rpm) will probably be using both port injection and direct injection. if anything with a slight retard. 1 13:1 Target AFR under WOT, might be looking at a bit too lean of a mixture, and internal pressures could be hitting the limits.
#231 |
Wait I thought cars typically run stoichiometric since running rich too long screws the catalyst? If the engine runs rich at cruise, there is no way it can pass emissions... Rich is under power, to preserve the engine and get the most power out, right?
#232 | |
MODERATOR-SAMA
Every engine has a unique temperament, and when it feeds on fuel it has its own preference of peak power and economy. Which is not synonymous with stoichiometric mixtures. My rx7 has a happy starting fuel mixture of 11.5AFR which you can say..is that particular's engine preference for peak power and economy. 12-12.5-13 is too lean, and below 10 is overly-rich. Running rich isn't an issue for many parts, running overly-rich can foul up spark plugs and o2 sensors. Running rich isn't bad for emissions. Running overly-rich is. Running lean can bring out the best peak power the engine has to offer, but is also bad at a certain threshold, as it destroys catalysts, damages internals, and puts out very bad NoX.
#233 |
Drives: N/A
Well actually they usually run Stoich MOST of the time on a street engine. But it is only during closed loop operation, which is low load eg <70% load and not past a certain RPM like 4000 or so. Stoich is where the emissions are the least and it also happens to balance power with fuel economy.
But in open loop, it is exactly as WoW said. I think that should clear up the confusion.
#234 | |
MODERATOR-SAMA
#235 | |
Drives: my wife crazy
#236 |
If they are looking to getting ~200hp out of a 2.0l NA i4 then I would think the compression has to be at least 12:1. Which is what worries me about trying to run FI on this engine without some serious internals workup... I wish I would have boosted my 97 acura 2.2cl... compression ratio of 9.2:1, would have been boost city!
#237 | |
Drives: Scion FRS
So with premium fuel, and 12:1(or lower) compression we should still be able to see at least 8psi of boost. |
#238 |
Drives: 2010 Evo X MR-T
the ferrari 458 runs 12.5:1 CR. i honestly dont think they will go above that. yes the mazda skyactiv uses 13:1 (US cars) and 14:1 (world) CR but the engine also makes 150 hp. its an economy car tuned engine.
| Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 12:44 AM |
| The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 11:35 AM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 05:10 PM |
| FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 11:30 AM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
