Old 03-14-2013, 11:48 PM   #2339
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Am I the only fr-s/brz owner in corpus christi on this forum? Just wondering if anyone has seen anyone else from corpus in here
karma003 is offline   Reply With Quote
Old 03-15-2013, 11:54 AM   #2340
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
Got my new wheels and tires going on. As well as HPS pads, DBA rotors, Stoptech lines and Motul fluid. So now it should now be the twisted sisters monster it should be, now just need to figure out the power situation.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
The Following User Says Thank You to Boosted For This Useful Post:
tripjammer (03-15-2013)
Old 03-15-2013, 07:54 PM   #2341
BAS
Drives: Snow White
Quick review on some new modifications I installed and have been cruising around on for the last few weeks. Yes, they are mainly cosmetic...which I usually dont care for. Some are overpriced (TRD), but I was impressed more than I anticipated.
JDM TRD Door Stabilizers: Expensive!!! Easy to install. Noticeable more firm door close with "thud" sound. Substantially decreased wind noise at highway speeds. Increased chassis rigidity...I dont know/think so. They do look sharp though.
Subaru OEM Auto-Dimming Mirror w/ Homelink: Nothing special, does what it said, should have been stock. I believe its an option on the BRZ's out there. Decreases clutter of door openers and eliminates glare from headlights (our cars sit very low).
Full LED's TapTurn/Switchbacks: I missed tapturn blinker function from my VW R32, this upgraded blinker relay module replaces the factory one directly. It allows for adjustable blinks 3,4,5, or 6. And it allows for LED's and switchbacks without the dreaded hyperflash. Eliminates having to install annoying resistors and suck. LED's in the trunk, dome light, license plate and reverse backup bulbs much brighter and more pleasing spectrum of color.
Overall, I am pleased with these overly expensive and cosmetic modifications.
TRD Exhaust/Cold Air Intake/High Pressure Radiator Cap (1.3 bar/18.5 psi)/Door Stabilizer, Cusco Front/Rear Type OS Strut Tower Brace/Power Engine Member Brace/Rear Member Brace, 215/45ZR17 PSS, Perrin Master Cylinder Brace/Shorty Antenna/Front Tow Hook License Plate Mount, TWM M1 Abrams White Pearl Shift Knob, SilverStar Ultra H11/9005, OEM Auto Dimming/Home Link Rearview Mirror, Full LED's with Switchbacks and JDM Clear Sidemarkers
BAS is offline   Reply With Quote
The Following User Says Thank You to BAS For This Useful Post:
tripjammer (03-16-2013)
Old 03-15-2013, 10:58 PM   #2342
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I got my car tuned today at ddpr in sealy, and Jason did a great job tuning my car. Great customer service, and real clean shop.
Got a baseline of 171 and tuned to 188
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
The Following User Says Thank You to *KID* For This Useful Post:
Old 03-16-2013, 05:16 PM   #2343
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
How hard is it to install the TRD door stabilizers?
tripjammer is offline   Reply With Quote
Old 03-16-2013, 05:41 PM   #2344
BAS
Drives: Snow White
Easy, not really sure why people on different threads have had such issues. I tend to take my time and am probably overly cautious with most things I do, but if you have the right tools...simple.
Impact driver with rubber mallet on each of the bolts located on the chassis side to release blue locktite and then socket wrench/phillips head bit.
Then replace with TRD kick plate and remember to use new TRD bolts.
The door side is simple/straight forward and utilizes the OEM screws for the bracket, followed by the plastic shim snapping into place.
Old 03-16-2013, 06:19 PM   #2345
tripjammer
tripjammer's Avatar
If I get them, I might need your help.
Old 03-16-2013, 06:27 PM   #2346
BAS
Drives: Snow White
No worries.
Old 03-17-2013, 12:47 PM   #2347
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
^driver front wheel only
Had a blast on the run guys/gals! Now to wash the car and get the excessive amounts of rubber and brake dust out of the wheel wells and the dirt and bug remains off the car!
tuckdaddy is offline   Reply With Quote
Old 03-17-2013, 03:59 PM   #2348
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Wow, no one is chiming in! It must be lonely in CC...nobody at all to play with???? We've been having some pretty good size meets up here in the S.A. area.
Extreme86 is offline   Reply With Quote
The Following User Says Thank You to Extreme86 For This Useful Post:
karma003 (03-18-2013)
Old 03-17-2013, 04:05 PM   #2349
blunova
"Slyde"
blunova's Avatar
Drives: 2013 SWP BRZ
Ok so maybe i'm late to the party, buy I just have to say this. If you guys aren't using [ame="http://www.amazon.com/gp/aw/d/B0000AY69V"]"the absorber"[/ame] to dry your cars, you're missing out!! I bought one and tried it for the first time yesterday after the run. I've always used either a chamios or microfiber towel, but this thing takes the cake! No annoying water spots on the glass for the first time ever. Love it!!
blunova is offline   Reply With Quote
Old 03-17-2013, 04:17 PM   #2350
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Originally Posted by blunova View Post
Ok so maybe i'm late to the party, buy I just have to say this. If you guys aren't using "the absorber" to dry your cars, you're missing out!! I bought one and tried it for the first time yesterday after the run. I've always used either a chamios or microfiber towel, but this thing takes the cake! No annoying water spots on the glass for the first time ever. Love it!!
I used to use those when i had my Tacoma and didnt want to go through a ton of towels! Now all i use is the adams great white drying towel in conjunction with their detail spray and makes drying a breeze and leaves a streak free badass shine! Have not come across better products! On top of that everyting is scented and smells good so no harsh smells. Never need to use more than the one towel for the FR-S.
The Following User Says Thank You to tuckdaddy For This Useful Post:
tripjammer (03-18-2013)
Old 03-17-2013, 10:27 PM   #2351
BAS
Drives: Snow White
Anyone use ChemicalGuys stuff ever? I love it, awesome in my opinion. Used their light duty clay bar the other day, followed by a sealant/liquid wax. Looks sick good. Stuff is pricey, but I have really had a good experience with their products.
Old 03-17-2013, 10:56 PM   #2352
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Chemical guys is good stuff on some products but others not so much! Just all depends on which version of the product your buying! I have looked at the Hot Lava paste wax as well as Collinite's paste wax but settled on the Adams Americana wax and Brilliant glaze combo have not had a better shine. I do want to try out some of the optimum products but love my Adams stuff too much..
What all from the Chemical Guys line up do you use?
Official What are you listening to thread? TRDMAN Off-Topic Lounge [WARNING: NO POLITICS] 2332 12-24-2024 11:16 PM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 11:43 PM
The official hand drawn thread. LexusFman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 04-06-2013 06:11 AM
Official 2011 WRC Season Thread 4agze Other Vehicles & General Automotive Discussions 4 04-01-2011 05:13 PM
