Old 02-11-2015, 09:07 PM   #2339
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Quick question guys the harder I drive. The car in closed roads I noticed the drive by wire lag in my opinion is there a way to tune that lag. Out with my oft ?
Feel it the most when rev matching and coming out of corners
el-92 is offline   Reply With Quote
Old 02-13-2015, 03:45 AM   #2340
givemeporknow
Drives: 2015 brz series.blue wr blue pearl
Just received my OFT but after writing it tells me that there is no tune file or it could not generate one. I have a 2015 series.blue if it matters. super new to this and I have read the many threads but just trying to see if I could get some more guidance. I don't think the car has ever been tuned but I am the second owner. Thanks!
givemeporknow is offline   Reply With Quote
Old 02-13-2015, 04:01 AM   #2341
steve99
It fine just means the oft cannot auto generate a tune file from its preloaded database, only has the most popular roms.
go to oft site download latest 2.06x tunes and load up the tune that matches your mods and rom type see ecu info on your oft.
have a read of OFT TIPS link below
Old 02-13-2015, 04:10 AM   #2342
givemeporknow
Thank you so much for the quick reply! I cannot wait to test this out tomorrow morning.
Old 02-13-2015, 04:16 AM   #2343
steve99
if they dont have a tune for you rom id then email your stock rom to the openflash guys
Old 02-13-2015, 04:22 AM   #2344
givemeporknow
I was able to use the OFT OFS v2.063>BINS>ZA1J___C ROMS (US 6MT)>Stg 1 D00C.bin file and it said that the checksum of the file has been corrected. I should just now be able to write that "rom" on there correct?
Old 02-13-2015, 04:59 AM   #2345
steve99
yes you god to go
Old 02-13-2015, 06:34 PM   #2346
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
With the 93 tune is my best bet to run a full tank or 2 through before flashing over? Or running it down to E, filling up and flashing straight over alright?
I decided to try the stage 1 and do some datalogging tonight to see how things come out. I'm running an injen intake and my ltft stays under +5 WOT which I understand isn't too bad. My stock tune would be as high as the upper +9's WOT.. Still learning, what are some other things I should keep an eye on?
cameronjones239 is offline   Reply With Quote
Old 02-13-2015, 07:32 PM   #2347
steve99
run it down to E or the low fuel light and fill with 93 you will be fine.
read links below on logging ect
Old 02-13-2015, 11:32 PM   #2348
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Can one you guys help me look at my datalog please. I did a 3rd gear pull but not 100% sure if everything is okay. The only things that looked okay to me were the adv. multiplier/afr/command afr but I am not sure if the LFTF are correct. I am suspecting a leak somewhere in header since I've been having issues trying to have the nuts tight. Let me know if you guys notice anything that is off and needs looking into. Thanks..as always much appreciated!
http://datazap.me/u/ap5512/brz-datal...mark=7501-8673
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
Old 02-14-2015, 12:52 AM   #2349
steve99
yes look like still a problem possible exhaust leak, if the nuts came rearly loose its likely you will have to replace gaskets again as they only crush to shape once.
Old 02-14-2015, 10:02 AM   #2350
ap5512
ap5512's Avatar
Thanks @steve99 - I'm guessing everything else looks okay and in within normal range?
Old 02-14-2015, 10:47 AM   #2351
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Bump. Looking at going with the OFT, as it seems there are so many issues going with forced induction at this point.
Chad86 is offline   Reply With Quote
Old 02-14-2015, 05:00 PM   #2352
steve99
all looks reasnoble considering very high long fuel trims generaly indicates intake or exhaust leak or crook maf or 02 sensor but if your header bolts came loose money is on gasket leak.
it not knocking badly or anything iam is 1 and no knock correction
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
