#2340 |
Drives: Raven FR-S
Received my supercharger the other day. Right off the bat I checked to see if the fittings in the back were loose and as soon as I touched it the brake booster connection snapped clean off......gonna pull the rest out and replace with brass fittings instead. Hopefully nothing else messes up. Glad I've got mechanic friends that can help me with this kind of stuff
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#2341 |
WUB WUB
Drives: 2013 Firestorm
Another belt down. This time I didn't have to cut it off. It pulled off the first thread of the belt. Need to figure out WHY it's doing this really.badly.
Sent from my VS840 4G using Tapatalk
| The Following User Says Thank You to wrxgoose For This Useful Post: | Calum (12-15-2013) |
#2342 |
Drives: 2013 FR-S Matte Orange
Out of curiosity, how much do you guys pay for belts. The belt for the KWSC is $75 but it's for cogged pulleys.
#2343 | |
Make love
Drives: H8R.. Not really
#2344 |
WUB WUB
No visible pulley wobble, but the tensioner is visibly loose if I squeeze the belt
#2345 |
AutoX-10/10ths every run
I think the last std belt I bought at O'reillys was around $43.
| The Following User Says Thank You to whataboutbob For This Useful Post: | digital_assassin (12-15-2013) |
#2346 |
Make love
#2347 |
WUB WUB
If I've lost 3 belts from the OEM, I really think I should try an aftermarket one. Also, probably gonna try a little bit smaller belt
#2348 |
Drives: 2013 Black FR-S
#2349 |
WUB WUB
I'm running the 75mm still. And it seems to be running straight. Later tonight I'll get a vid of the belt going, see if y'all can see anything.
#2350 | |
NW Region Moderator
Drives: FR-S No More
#2351 | |
That Guy
Drives: 2013 asphalt FRS MT
I'm anxious to see the vid, can you also post a pic of the broken belts? How sharp/high are the ridges on the pulleys? They shouldn't be long enough to touch to valleys in the belt. |
#2352 |
WUB WUB
cost about $40 to get everything fixed, but that's because i work at a Pep Boys. I completely forgot to get a vid yesterday.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
