Old 02-03-2015, 08:59 PM   #2283
Racecomp Engineering
Originally Posted by YouShallKnow View Post
I think so too, thanks for the confirmation. What do you think about the bump steer kit with that setup? Is it still beneficial with stock ride height?
The bumpsteer kit is not very useful at stock ride height. Front control arm bushings including the ALK would be much more effective. Not sure on which costs more points for you but the bushings are the better choice.
- Andy
Old 02-03-2015, 09:00 PM   #2284
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
- Andy
They are free! I'll go alk and skip the bump steer kit. Thanks for your guidance I really appreciate it.
YouShallKnow is offline   Reply With Quote
Old 02-10-2015, 05:01 PM   #2285
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@TekPrime -his question, saving some time here.
"Would someone mind explaining how the roll center is adjusted on our double wishbone emulated multi link rear suspension? I'm looking to understand how the geometry changes under force. Thanks for your help!"
Old 02-16-2015, 03:59 PM   #2286
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
If you had to recommend a group or set of bushings to a beginner for upgrading, what would you say was the best bang for the buck to eliminate some o that elastic feeling in corners when grippier tires have been added. Is this one of those subjects where you should replace them all or you could do the rear subframe bushings then front control arms...? Thank you.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-23-2015, 09:37 AM   #2287
Front:
Front control arm (front) bushing.
Whiteline ALK
steering rack bushings
Rear:
trailing arm front
crossmember inserts
diff bushings
rear upper control arm bushings (either the camber adjustable or the fixed)
I bolded the ones I recommend most and are the better bang for the buck. The others are good too. Might as well do as many as you can stand at the same time since they're almost all kind of a pain to install.
- Andy
Old 02-23-2015, 02:43 PM   #2288
YouShallKnow
Drives: Man
So I ended up taking your advice, I removed the Swift Sports springs replacing them with BRZ front springs and FR-S rear springs for the stiffest OEM springs possible.
Then I installed (or tried to) the Whiteline ALK, but I thrashed my ball joint boots in the process so I need to replace them now.
No dealerships have them in stock, soonest they can get them is Wednesday.
So I'm considering picking up the Whiteline roll center / bump steer kit just so I can get my car on the road today.
But now that I'm at stock ride height, I know there won't be much benefit.
My question is, will using the roll center kit HURT my handling at stock ride height? Or will I just not see much of a benefit?
I'm fine having the kit installed because I sure as hell never want to take my control arms off again and I will probably go lower again in the future once I get money for proper coilovers, but I also don't want to spend time and money on a part that hurts my handling.
Thanks for all your help, this thread is massively helpful to newbies like me.
My other option is to wait 2-3 days for the dealership to get stock ball joints in.
What do you think?
Old 02-23-2015, 03:03 PM   #2289
was385
Drives: MT WRB BRZ Limited, 2007 911s
Front:
Whiteline ALK
Rear:
trailing arm front
crossmember inserts
diff bushings
- Andy
I keep going back and forth on the diff bushings. Half the people seem to say that the added NVH isn't bad, half say it's awful. Do you have any experience with the whiteline or a similar kit with regards to NVH?
was385 is offline   Reply With Quote
Old 02-23-2015, 03:10 PM   #2290
What do you think?
The WL RCK kit will not hurt your handling at stock ride height. There won't be much if any benefit either. I say go for it if you realistically plan on lowering the car later.
- Andy
Old 02-23-2015, 03:13 PM   #2291
Yes and IMO it's fine. My tolerance for transmission NVH is that I don't mind gear whine that much but can't stand clunks or too much vibration. Others may be different...
- Andy
Old 02-23-2015, 03:23 PM   #2292
YouShallKnow
Drives: Man
- Andy
Anxiety alieved, thank you.
I owe you guys some business!
Old 02-23-2015, 03:30 PM   #2293
Koa
I have those bushings as well- If one perceives it as "clearer feedback" than introduced NVH, then you'll love the mods
Old 02-23-2015, 07:17 PM   #2294
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That's really true. I have the subframe insets and rear UCA bushings and some would say NVH has definitely increased but I think it is just better connected to the road. However, I think its my limit so no more bushings for me as long as this remain my DD
Old 02-24-2015, 02:22 PM   #2295
sunset_blvd
sunset_blvd's Avatar
Drives: Lava 2014 Scion FRS
I just saw that you guys carry the "Whiteline MOTORSPORT Front Lower Control Arm Assembly Kit", but there is no picture or description. Can you give us some more information on this? Have you had any experience with it on your cars?
sunset_blvd is offline   Reply With Quote
Old 02-24-2015, 08:20 PM   #2296
That's a poorly named part. It's just the Whiteline rear toe arm.
Part number KTA147.
- Andy
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
