Old 11-25-2013, 11:55 PM   #2255
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Ryan86 View Post
@DarrenDriven
Can up my figures to 233whp 186ftlb, based on 75mm 91 OCT.
@DeliciousTuning is remarkable, my base line was 155whp
Did you resolve your issues? Was it the plastic elbows causing problems?
Old 11-26-2013, 01:18 AM   #2256
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Yeah. In fact this seems to be a little more common of a problem we are seeing on a lot of the Innovate Supercharger blower kits. So it is good to check them after installation as suggested by Sprintex.
Old 11-26-2013, 01:24 AM   #2257
DeliciousTuning
Originally Posted by Kodename47 View Post
69mm pulley and E85 will require more than stock injectors.
So far we have been able to make about 385 whp in stock DI and PI systems on E85. With EcuTeK I am able to accomplish this and it would not be possible with any other tuning solution.
So with the standard Innovate charger, intercooler, full exhaust, 69mm pulley and whatever mods you have, it can be tuned on stock injectors and the stock fuel pump. Though I usually do recommend an upgraded pump.
Cheers,
William Knose
Old 11-26-2013, 01:29 AM   #2258
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Cheers,
William Knose
you made 385 WHP with the innovate SC???
lbroskee is offline   Reply With Quote
Old 11-26-2013, 01:31 AM   #2259
DeliciousTuning
Didn't say it was an Innovate kit... But we are working on something...
Old 11-26-2013, 01:32 AM   #2260
lbroskee
lbroskee's Avatar
i would hope not or i woulda been at a loss for words why we haven't seen it lol.
can't wait to see this making over 300
Old 11-26-2013, 01:39 AM   #2261
DeliciousTuning
It is getting very close with the current setup, just a little more refining is needed to dial it in. Though it will require the folllowing.
Headers such as PPE or something equal length
Improved intake on Supercharger
Full exhaust system
69mm Pulley and Intercooler
And of course E85.
I believe with this setup it can get really close along with a massive powerband due to the twin screw design. Where it lacks in power it makes up in a powerband.
Cheers,
William Knose
Old 11-26-2013, 01:43 AM   #2262
lbroskee
lbroskee's Avatar
Full exhaust system
And of course E85.
Cheers,
William Knose
i already got the exhaust. was thinking perrins new MAF 3" intake. I'm waiting to see it pulled off on 93 octane. i am very anti e85, seen to many issues and bad gas around here to risk it
Old 11-26-2013, 02:35 AM   #2263
DeliciousTuning
FlexFuel, great solution. Get a bad tank of gas (too much 91 octane or whatever) and it it adjusts accordingly. Great solution, probably why GM and other manufacturers offer it.
Tuned quite a few cars on it now, it is a great option.
I do not think the 3" intake will help to much but it might.
Cheers,
William Knose
Old 11-26-2013, 02:43 AM   #2264
sw20kosh
So what is happening exactly? Enough un-metered air is getting in past those elbows and causing issues with fueling?
Old 11-26-2013, 03:07 AM   #2265
DeliciousTuning
Correct. There is definitely enough air bypassing the MAF sensor in turn causing the car to run rough under idle and partial throttle. We have also seen a loss in power across the powerband from this.
So it is important to recheck those fittings and make sure they are secure. If you feel they are loose then please apply teflon tape to the threaded ended to seal in better with the intake plenum on the back of the supercharger.
Cheers,
William Knose
Old 11-26-2013, 12:17 PM   #2266
xxscaxx
Drives: 2013 SWP BRZ
Mine are loose, guess its time to take them out and put teflon on them.
Anyone who has done this with the the supercharger in place - best way to pull them off? take off the whole supercharger from the manifold, or can we just remove the elbow on the back?
xxscaxx is offline   Reply With Quote
Old 11-26-2013, 10:20 PM   #2267
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Full exhaust system
And of course E85.
Cheers,
William Knose
I think that with a smaller pulley, and fine tuning, i'll be breaking 300 with this blower. Just need to get the right tune, and ensure that everything is working in concert. Just need some more work before I can attempt it. New axles (just CYA, to be safe), and I'll be there. Without E85, too.
wrxgoose is offline   Reply With Quote
Old 11-26-2013, 11:37 PM   #2268
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I don't mean to post w/o being an owner but, this is the only active inno thread it seems (I actively follow.)
My question is, "Is there any information on the larger blower that was shown a while back from presumed gains or an eta?"
Thanks~
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
