Sam Strano
Old 02-18-2015, 09:38 PM   #2255
u/Josh
Drives: GBS Limited 6MT
Originally Posted by TRev View Post
The other detail that was easy to see from the logs after our co-drive was that I also gained a bit of time off the line due to differences in launch technique.
Any more details on this? The launch is probably the easiest place to pickup time using datalogging and I always wonder how much time I'm leaving on the table when I launch less aggressively.
u/Josh is offline   Reply With Quote
Old 02-18-2015, 10:10 PM   #2256
TRev
I did many years of analysis on AEM logs drag racing so hopefully I have some decent insight. Look at RPM as the car starts to gain MPH, RPM drop (clutch engagement), RPM rate of rise (traction loss) and speed vs time (how well you did). A quick shift can also be good for a tenth over someone who shifts slowly. Fortunately for slow shifters, that is only typically once a run in Solo.
Here is a video from back in the day when I was drag racing my EVO with some fairly quick shifts.
[ame="https://www.youtube.com/watch?v=la6MN-QpVyY"]05 EVO 8 MR 6spd - 11.3@120mph In Car - BR20G & 110 Leaded - YouTube[/ame]
Having the drag start is one aspect of Pro's that I love. It is nice to have the 60ft metric.
TRev is offline   Reply With Quote
Old 02-18-2015, 10:42 PM   #2257
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Originally Posted by qoncept View Post
As a software developer I look at Solostorm and see a very, very ambitious attempt that's mostly there. But fixing the small issues above is probably an enormous task. I bought it more than anything to make pretty videos. I think a properly precise and trouble-free setup would have to be much more restrictive with the hardware it can use - probably exclusive.
I think you just saved me $400. Thanks.
I've used other systems and they end up being such a fight to use that they often get left at home. No one local to me uses solostorm, so I was thinking I'd give it a go despite my skepticism.
Sounds like passing is a better idea.
Cueman is offline   Reply With Quote
Old 02-19-2015, 10:10 AM   #2258
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
Perhaps this has been already discussed somewhere and I missed it, but what's your guys take on tire shaving? Anyone doing it, to what depth, and how much of an effect does it have on run times and tire life?
Briankbot is offline   Reply With Quote
Old 02-19-2015, 10:38 AM   #2259
qoncept
qoncept's Avatar
I was kind of hesitant to click submit. There are a number of issues but I am admittedly not incredibly knowledgeable. I've never really been fully committed to getting the most out of Solostorm. My first year with it I made a very conscious decision to get my videos and other than that just concentrate on driving. And the developer has been very involved and responsive.
But like I said, I'm afraid it's just too ambitious a project, especially for a single developer, and it will probably always take a fair amount of tinkering even when everything works.
qoncept is offline   Reply With Quote
Old 02-19-2015, 10:40 AM   #2260
renfield90
The Stig's German cousin
I think it's really only necessary on the R1R due to some pretty serious tread squirm.
I've heard some tires have a slightly harder "base" compound that you see around 4/32" so there is a risk you run into that. Part of the reason the 195/50/15 R1R was so trick is it was nice and gooey all the way to the cords (hence the tread squirm issue).
I personally don't and won't shave. I show up with full tread tires (new, but enough scrub-in to clean off mold release) to competitions I care about and then they can double as rain tires. When they heat cycle out they have enough tread left to daily drive in sunny Arizona. If I'm going to burn 1-2 sets of tires per year you bet your ass I'm gonna get my money's worth out of 'em.
The Following User Says Thank You to renfield90 For This Useful Post:
Briankbot (02-19-2015)
Old 02-19-2015, 10:52 AM   #2261
qoncept
qoncept's Avatar
I remember when Falken phased out the Azenis one of the new tires to have was their FK451. Rumor was the last 4/32 were the same compound as the Azenis, but before that was typical hard, high mileage summer compound.
Edit: What a useless bit of knowledge to still be holding on to, eh?
The Following User Says Thank You to qoncept For This Useful Post:
Old 02-19-2015, 11:07 AM   #2262
renfield90
Totally not useless - I think on RRAX they call that an M&M tire. One fear for the street tire class is someone makes a tire with a hard enough shell to pass a 200TW test, but with a gooey inside that's soft like an A6. Shave it, get maybe twenty runs out of it, and you're done.
That's exclusion list material for sure, but let's say it's not quite as extreme as A6 soft. Does it still end up on the exclusion list? I wouldn't discount a tire like this showing up in the future, especially with Falken getting back into the contingency game this year. Wouldn't surprise me if they're cooking up something new given the current Azenis can't hang with the current heavy hitters.
Old 02-19-2015, 07:59 PM   #2263
Cueman
Cueman's Avatar
Ha... and maybe I actually haven't made up my mind. Ultimately, I'm sure it's not everything I want it to be, but maybe the price tag allows for that...
Old 02-22-2015, 07:56 PM   #2264
bslate3
Drives: 2015 CWP BRZ
Today was my first event in the new car. I'm coming from a 2011 WRX.
The weather conditions were terrible, 45° and rainy, but I think it was a good way to learn a new car.
Only mods so far are Subaru camber bolts and 225/45 Z2 Star Specs.
I think these tires were a good fit for the weather.
I managed to get 1st in CS and 9th overall in PAX. I could have placed higher if the first run groop didn't get 3 dry runs before the rain hit.
[ame]http://youtu.be/q1S1DHgjp7U[/ame]
Driving tips appreciated.
bslate3 is offline   Reply With Quote
Old 02-24-2015, 05:50 PM   #2265
DaWorstPlaya
Drives: 2016 FR-S
My experience:
- Auto start/stop is a complete crapshoot. I trusted it for a single event and ended up with nothing usable. Half the runs never recorded and a couple ended up split in to 2 weird runs (minimum speed trigger, I guess). Now I start and stop recording manually.
- Because I can't rely on autostart, full run times are off by enough that they are no good for comparison.
- GPS ends up with an offset frequently. I don't have any examples, but if I overlay consecutive runs, the overlays will end up "off" by about the width of a runway sometimes. As in the traces are like a double image. This is with the Qstarz receiver sold on by Petrel.
- I CANNOT get the TPS calibrated correctly using a generic OBD-II dongle. Last attempt got it to max out at 103%.
- The calibration for videos is off no matter what I do, even though it's supposed to be automatic, and I think by a varying amount in each video. I just can't get the gopro and internal camera synced, and Solostorm doesn't offer any manual adjustment to the overlay videos.
Having used Solostorm maybe I can help shed some light. I also used to the use MaxQdata when they were still in business.
1. Auto start/stop is/was made better through the use of the marker option. You can set the staging area, the start and the stop manually. Do that when you walk the course and Solostorm will ALWAYs record the runs correctly.
2. See one.
3. The offset (aka GPS drift) is an issue with your Qstar GPS. I had the same problem with an older GPS I was using (from the MaxQdata days) until I bought and replaced it with a Qstar unit from Amazon. Since then the GPS drift/offset became a none issue. Sounds like there may be an issue with your Qstar unit.
4. TPS issue is probably related to the Bluetooth OBD2 reader you are using. There are know issues with the cheapo OBD2 readers. It's basically a crap shoot when you buy the cheap no name brand ones. I've been lucky with mine.
5. There is a calibration tool in the setup to help you sync your video to the GPS. You can use it for both the built-in camera or GoPro, although it is much easier with the GoPro. And you can manual sync the video as you do the overlays if it is off by a bit using the export tool.
Coming from the MaxQdata days, Solostorm is a much better product IMHO. It helps you make comparisons between runs. You can make changes DURING the event, that's when it counts the most. Probably the best racing tool I have used.
DaWorstPlaya is offline   Reply With Quote
The Following 2 Users Say Thank You to DaWorstPlaya For This Useful Post:
Briankbot (02-24-2015), qoncept (02-25-2015)
Old 02-25-2015, 10:06 AM   #2266
qoncept
qoncept's Avatar
@DaWorstPlaya,
I'll try some of those things out, and I'll talk to Petrel about the GPS. It's been 2 years so I better cross my fingers.
As for #5 though, I've calibrated the video delay over and over and over again, and when emailing the developer asked repeatedly for a per-video calibration method because they are out of sync by a different amount every time. I've more or less given up.
Old 02-25-2015, 10:16 AM   #2267
vroom4
You can sync them per video can't you? I've always done it tht way where I can math the video to my data timeline manually...
vroom4 is offline   Reply With Quote
Old 02-25-2015, 10:42 AM   #2268
qoncept
qoncept's Avatar
Not according to all the digging I've done and complete silence after I've asked Petrel at least half a dozen times.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
