#211 |
The kit was close to production, but not production. They are still playing with some mounting, notably the coolant lines and some fuel line mounting points. e.g. the mounting tab/horn shown on the driver's side of the bay closest to the front of the vehicle - this was threaded but due to some issues, won't be used anymore, it will be removed in production.
The intake housing was made to look like the powdercoated aluminum manifold, but its actually plastic. Fitting a strut tower bar will be nigh impossible. The exchanger was silver (a lot of other kits are blacked out) and yes, very close to the radiator - you could hardly even tell it was there. They mentioned a release to be coming within the next 2 weeks, but I believe that was limited only to pricing. When pressed on pricing, they mentioned south of 6k but likely north of 5k. Guess we'll see in a couple weeks... They made the kit to be modular for future updates. What/when/if, all unclear at this point. However, there are 3-4 different pulleys that are smaller diameter with smaller pulleys that would increase a couple psi between them to get to roughly 20psi. You would undo the 4 bolts holding the wheel on, install the new wheel and belt, and be on your way. Although, if you do so, you would void the warranty on the kit (maybe the unit as well) since in the production version there will be a sticker to never remove those bolts or you will void the warranty. They reinforced where the extra pulley for the kit is, and where it mounts at the alternator. Something about 60-80 lbs of extra downward force at WOT and wanting to beef up that area. They haven't tested with E85 yet, everything has been CARB testing so far. Installation mentioned removing the AC condenser. I forget the exact name of the part it taps into, but they made their own fitting for where the fuel goes into the solenoid or something? I can't remember exactly, but its on the driver's side, lol. Weight was roughly 60 lbs. No color options right now, black/red powdercoat on the top is currently the only planned option. K&N filter was in there. (today at least) Again, no cutting of anything. Bolt on install. ![]() ![]() ![]() Another pic (coming soon)
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor Last edited by SPCorBUST; 08-01-2015 at 10:22 PM. |
| The Following 13 Users Say Thank You to SPCorBUST For This Useful Post: | 10Stars (08-02-2015), BigFatFlip (08-01-2015), civicdrivr (08-02-2015), DieselDog (08-03-2015), Freeman (08-01-2015), funwheeldrive (08-02-2015), GhostOp86 (08-02-2015), hmong337 (08-02-2015), Hyper4mance2k (08-02-2015), Lonewolf (08-02-2015), P86RAVES (08-05-2015), SkiRideDrive (08-02-2015), swarb (08-01-2015) |
#212 |
Drives: WRB BRZ
#214 |
Drives: 2013 Black FR-S
This plus e85 plus 15 psi... Mmmmmm
#215 |
Panda Trueno
Drives: No twin now.
Wow.... that is probably the best looking setup for this car. Clean and the tvs 1320 leaves a lot of room to grow. Who will be the first vendor for this?
| The Following User Says Thank You to Summerwolf For This Useful Post: | sato (08-02-2015) |
#217 |
Drives: Whiteout FR-S
Thanks for the info. If ecutek(license, tune, and cable) is included for under 6k it's not a bad deal. Nobody else offers that kind of warranty either that I am aware of.
I noticed something today when looking at the new Lotus Evora 400. It uses an edelbrock supercharger also. If it's good enough for them I think it should be good enough for us. |
#218 |
| The Following 2 Users Say Thank You to JoeBoxer For This Useful Post: | Summerwolf (08-02-2015), zc06_kisstherain (08-03-2015) |
#219 |
Drives: 2015 FRS
Awesome thanks for the report guys.
#220 | |
Sent from my SM-G925T using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
| The Following User Says Thank You to SPCorBUST For This Useful Post: | zc06_kisstherain (08-03-2015) |
#221 |
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Kit looks promising, looks like I'll have to choose between this or the JRSC in the future.
| The Following User Says Thank You to menikmati For This Useful Post: | funwheeldrive (08-02-2015) |
#222 |
1337
Drives: 2013 BRZ WRB S/C
Thanks for the pics and info guys. The attention to detail is very impressive, it looks very OEM (aside from the red).
I'm not sure what you mean about the warranty though. If you had 20k miles, and owned the car for 2 years before installing the kit does that mean: A) you are covered to 56k miles, and 5 years of owning the car B) you are covered to 56k miles and 3 years of owning the car C) you are covered to 36k miles and 5 years of owning the car D) you are covered to 36k miles and 3 years of owning the car (factory warranty) It's definitely a cool proposition, and may help to convince some people to take this over the alternatives when the company is backing their product firmly enough to offer you engine warranty. |
#223 | |
Drives: Whiteout FRS
It looks like their warranty is specific to them and not the factory warranty. For example, you have the sc installed at 10,000 miles on 8/1/15 from their dealers. Any damages caused by the install or the sc will be covered from 10,000 to 46,000 miles or until 8/1/18. |
#224 |
1337
Bummer, my factory warranty expires today which means I'm not eligible. Car needs to be less than 3 years old and less than 36k at the time of supercharger install.
| Tags |
| boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger |
| Trunk needs a bit of force to close..... | Hachiroku14 | Issues | Warranty | Recalls / TSB | 30 | 06-19-2018 06:09 PM |
| X-Force 3" Exhaust | mwjcyber | Engine, Exhaust, Transmission | 19 | 03-13-2017 02:55 PM |
| The force is strong with this one (2015 STi) | blackhawkdown | FR-S / BRZ vs.... | 39 | 08-01-2014 01:26 AM |
| X force or Invidia N1 | JakeG | AUSTRALIA | 8 | 01-18-2014 05:16 AM |
| G-force meter | mikepaul21 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2013 02:24 PM |
