#211 |
Is that actual AFR, or is it the requested AFR from the ECU? If it is requested AFR, mine is doing the same thing. If actual AFR is too rich, then the requested AFR goes lean to pull it back to where it needs to be. The actual AFR is what we need to concentrate on, Especially in Open Loop.
If I say yes, will that make you think I understand?
#212 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#213 | |
http://www.datazap.me/u/yobiwan/sc11...zoom=4991-5146
Intent > Content
#214 | |
#215 | ||
Drives: UK GT86
.: Stealth 86 :.
#216 | |
Drives: Toyota 86
Would be interested to see your ROM and defs. |
#217 | |
I loaded a previous tune, and I'm back in business. So, making the AFR richer with Port Injector scaling will end up making Open Loop leaner, correct? Ideally I want a Closed loop AFR of 14.7, so that Open Loop will be just right.
#218 | |
Drives: Toyota 86 Turbo, Lexus NX300H
and logged from OFT HKS sc removed stock 2nd o2 sensor, using AEM UEGO wideband now. and AEM wideband shows 15.6 AFR too. but I changed back to stock PI/DI table and everything is fine now. I'll send my roms & def to you. |
#219 |
Drives: GT86
Yes. We don't want corrections from CL applied in OL in this case. Assuming our MAF scale was done properly before we changed our di:pi ratio table.
#220 |
I'm aware engines designed for lean burning, question is can this engine handle it specially since this engine has a history of burning DI seals. I suppose if he was running E85 then this would actually be closer to ideal and the engine wouldn't have as much trouble with possible problems associated with running this lean. Not so sure about doing this with petrol.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 12-11-2015 at 02:13 AM. |
#221 | |
Drives: UK GT86
.: Stealth 86 :.
#222 | |
Drives: Scion FRS
Sent from my HTC One_M8 using Tapatalk |
#223 |
#224 | |
Intent > Content
| FR-S Gear Ratio Comparison | SpeedR | Engine, Exhaust, Transmission | 36 | 02-25-2016 09:34 AM |
| Best pistons to use and Comp ratio? | Fabron757 | Forced Induction | 36 | 02-05-2014 03:21 PM |
| Rear End Ratio | White64Goat | Engine, Exhaust, Transmission | 6 | 07-07-2012 11:37 PM |
| FR-S to BRZ Ratio | MannyO | New England | 11 | 03-08-2012 02:23 AM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 02:40 AM |
