Old 06-22-2015, 12:55 PM   #211
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
@celek sorry to get back on the topic of rods but I just thought about this. Being that you plan to spin some pretty high rpm are you at all concerned with rod stretch? If so have you factored it into the rod length or piston height?
As a disclaimer, this question is just based on rods in general. Im not trying to debate alum rod vs steel rod stretch.
WHITE is offline   Reply With Quote
Old 06-22-2015, 03:35 PM   #212
celek
Resident Gear Head
celek's Avatar
Originally Posted by Tim Radley View Post
Not really sure why you'd want to go to ali rods as they add unecessary windage and clearance issues to bottom of bores. Plus the fact the FA20 rods have the big-end offset it's going to require a custom forging. Much cheaper materials out there that really don't weigh much.
bore is 89.5mm so it is larger biggest concern is case clearance.
As for custom forging there are a lot of 45 degree angle rods out there besides the FA20 it already may exist.
celek is offline   Reply With Quote
Old 06-22-2015, 03:38 PM   #213
celek
Resident Gear Head
celek's Avatar
Rod stretch is a non issue Aluminum rods do expand with heat as are specifically made shorter than the steel equivalent to compensate.
This is only something I am looking into for lighter components.
Aluminum still retains original shape after running its not like they get longer and longer over time
Old 06-22-2015, 04:15 PM   #214
burdickjp
Drives: 2013 ultramarine Scion FR-S
Thermal expansion and the relationship between stress and strain are not the same thing.
From what I've seen of the aluminum rod business, it's frighteningly easy to put little to no engineering into a rod and have it achieve success in drag racing.
I would suggest getting some light steel rods, or if you're wanting to be exotic some titanium rods. Aluminum rods are for drag racing.
burdickjp is offline   Reply With Quote
Old 06-22-2015, 07:18 PM   #215
WHITE
Thats pretty neat
WHITE's Avatar
Im not talking about thermal expansion. Im talking physical rod stretch from the rpms youll be spinning. From what little ive read it would appear the consensus is that a steel rod can stretch from .030" to .050" depending on how high you spin, and alum rods stretch an additional .010" to .015" more then the equivalent steel.
Wich means if you figured for your piston to be flush with the top of the block deck once you start spinning high your rods can stretch and start smacking your head.
Im just trying to make sure youve looked into every variable of this engine before putting it together.....i wanna see this thing running just as much as you and everybody else becuase its going to be pretty badass.
Old 06-30-2015, 11:04 AM   #216
celek
Resident Gear Head
celek's Avatar
Today marks the 3 year purchase date for the car... SOA keeps warning me the warranty is expiring. Sorry to burst your bubble Subaru of America, Inc. I am out to crush hopes and dreams.
Still searching for rods, need to make some calls but also need to save some funds for SEMA in November.
Old 08-03-2015, 11:30 PM   #217
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
any updates? I am getting a free motor to build and like what you have done so far just not sure how I want to attack this project yet
Scavanger is offline   Reply With Quote
Old 08-04-2015, 08:48 AM   #218
celek
Resident Gear Head
celek's Avatar
Still need to order Rods then off to the machine shop. From what I understand talking to HKS & Greddy the stroke causes bottom cylinder interference issues with piston skirts so some modifications might need to be done to the cylinders or the pistons.
Still saving some cash for SEMA as well, main reason for not putting in the order for rods.
Will be visiting some valvetrain manufactures at SEMA and Piper Camshafts told me they will be at PRI in Indy so I want to talk with them as well since they are over in the UK.
Old 08-04-2015, 06:52 PM   #219
86drift
86drift's Avatar
Drives: Toyota 86 GT
Interested to see what Piper say about valve to piston interference. I'm guessing there's lower limits on the cam timing. I can't wait to get myself some 280 deg cams.
86drift is offline   Reply With Quote
Old 08-05-2015, 11:47 AM   #220
celek
Resident Gear Head
celek's Avatar
When I had my pistons produced I have the valve pockets made to compensate for 1mm over valves and 13mm lift at a 280 I am pretty sure.
I Thought ahead for the future
Old 08-19-2015, 08:32 AM   #221
celek
Resident Gear Head
celek's Avatar
Shortblock dropped off last Friday at Accelerated Performance... No ETA on being finished though. They seem to have more rapport with the rods manufactures because they can get stuff in under a week.
Old 08-31-2015, 02:38 PM   #222
celek
Resident Gear Head
celek's Avatar
Happening now bored and honed
Rods ordered.
Old 08-31-2015, 02:40 PM   #223
celek
Resident Gear Head
celek's Avatar
Mockup for measurements.
Old 08-31-2015, 07:39 PM   #224
Traktor
Drives: Subaru BRZ Limited
Loving this build! Can't wait to see what cam setup you come up with to make power above 8000 rpm and how you get around the oiling issues at those Revs.
Traktor is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
