#211 | |
Speed Chaser Thrill Seekr
Drives: 2014 Asphalt Monogram FR-S 6MT
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint My Build |
#212 |
Drives: Attitude
#213 | |
#214 |
Drives: Attitude
No, you're not removing the driveshaft. Even if you do, I've *heard* that only a small little bit comes out of the tail section - though that rear seal CAN be damaged so be careful. Either way there's no reason to remove the driveshaft entirely with this mod.
#215 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#216 | |
#217 | |
I Love custom Turbo kits
Drives: Limited BRZ
I installed mine, no lift.
#218 | |
Drives: Attitude
Check the Kartboy DIY...it's informative and the kit you bought comes with instructions that are readily adaptable to the Kartboy DIY. There's almost nothing to this install compared to replacing the lever on an actual shifter kit. |
#219 |
Drives: Whiteout frs
I did my install without a lift, just using two factory jacks most cars come with. The only problem one may face when doing the install is that without the recommended 8" and 3" extenders, those bolts for the rear bracket will be difficult to reach...
#220 |
Drives: 2014 WRB BRZ Limited
I used my uncle's lift to do the install. I'd be happy to do a video walkthrough, but it's so easy to install, nobody is going to need this. Seriously, this is on par with an oil change or rotating your tires.
#221 | |
Drives: 2013 BRZ Silver M/T
Mtec did a video for their springs and I will be using that as a guide next week. |
#222 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I installed the quick shifter tonight. A WORD OF WARNING! If anyone has an aluminum drive shaft this will not work with it! The drive shaft has a slightly larger diameter and will rub the shifter linkage. I found out the hard way, fortunately I didn't break anything when I tried to drive off.
Aside from that the shifter is incredibly short. This is in my top 5 mods to my car I think, and I've done maybe 40 mods so far. Selling my aluminum drive shaft now since it's not compatible for $425 for anyone willing to pick it up from me. Not willing to ship. Install was super easy (not counting the drive shaft issue). I already have the Perrin rear shift bushing so I skipped that part. Since I didn't do that part I didn't need to undo anything with the drive shaft or any other parts. Just unpin the shifter, remove the boot, install new boot, install the extender thing, put pin back in, put boot over new goodies. Would have been a 30min job (15mins jacking up the jack and getting ready), if it weren't for my aluminum drive shaft. Took 2 hours instead.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#223 | |
Which brand aluminum driveshaft did you go with? Sent from my SAMSUNG-SM-N900A using Tapatalk
#224 | |
Just the tip
| TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 12:14 AM |
| Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 04:42 PM |
| The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 08:23 PM |
| Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 01:42 AM |
