Old 04-13-2018, 12:52 PM   #211
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by assbox View Post
I used a x-acto knife to cut the two black caps on the backside of the needle. I slowly wiggled the knife back and forth while giving it a little pressure. Go slow so you dont stab yourself or put the blade through the black plastic. Once the two caps are sliced off, you can take a fine flat head screw driver and pry up using the little notch. Once you have the plastic cap off, you can lightly pull the needle through the black cap. After scraping the paint off all the needles using a box-cuter style razor, just re-assemble as you took apart. Lastly i used a fine solder tip, to melt the plastic post to the back cover of the needle. You just have to touch the cap for a fraction of a second to get it to seal up, so be careful.
I recommend painting the back of the needle with white or silver model paint. This will reflect the light from the LEDs and help fill the needle. Very noticeable in pictures. I will see if I can find some.
Edit: Non-painted:
Painted:
DustinS is offline   Reply With Quote
Old 04-13-2018, 01:52 PM   #212
MJones_RB
MJones_RB's Avatar
[/QUOTE]
That looks great!
MJones_RB is offline   Reply With Quote
Old 04-13-2018, 02:21 PM   #213
DustinS
DustinS's Avatar
Originally Posted by MJones_RB View Post
That looks great!
Thanks! I'll be diving into a 2017+ digital cluster here soon as well. Hopefully it comes out just as nice.
Old 04-13-2018, 03:33 PM   #214
assbox
assbox's Avatar
Drives: Whiteout FRS
Ah nice, you saved me some time this weekend then. it does look better painted white. Ill pick some up later tonight and get them painted before re-assembly.
IG: ft86carbon
assbox is offline   Reply With Quote
Old 04-23-2018, 09:49 AM   #215
assbox
assbox's Avatar
Finished everything up this weekend. did some foot-well illumination for when im night drifting on the track.
IG: ft86carbon
Old 10-10-2018, 08:44 PM   #216
Joveen
Joveen's Avatar
Drives: Bone stock
Sexy
Sent from my SM-G935T using Tapatalk
Joveen is offline   Reply With Quote
Old 11-04-2021, 10:40 AM   #217
Skylord_Crow
Drives: 2014 Subaru BRZ
@DustinS Did you end up swapping the leds on your 17+ cluster?
Skylord_Crow is offline   Reply With Quote
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
