#211 | |
Drives: CBS Subaru BRZ Limited
#212 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I am on ebay searching for the brz front lip ABS by bayron R but i dont see the posting. Does anyone know how long til they get some back in stock?
#213 |
Is the genuine STi lip ABS or PU?
#214 | ||
#TeamAURA
Drives: BRZ Limited Lighting Red '13
#215 |
#216 | |
#TeamAURA
@Dr. BRZ Also, all the parts of the kit is back on the ebay listings!
#217 |
looks like his store is closed for vacation = /. Was just about to place an order too.
#218 | |
Drives: BRZ Limited
#219 | |
#TeamAURA
I don't have much painting experience but are you planning to seal it with a matte clear coat seal? I think that's a good idea to go about. I would imagine the skirts will get dirty. Fast. Last edited by OoLong; 03-07-2014 at 12:50 PM. |
#220 | |
Drives: BRZ Limited
I don't want anything glossy |
#221 | |
#TeamAURA
#222 |
#TeamAURA
Here are the full steps from my friend painter friend in case anyone wants them:
*Before painting, make sure you are in a decently clean area without much debris in the air and also with the temperature around 50-90 degrees. (One piece at a time, try not rush the process if you want a good result) 1. Wash the body kit and dry it with something that leaves no fibers behind. (If you have compressed air, that works best). 2. Sand it with 300 grit sandpaper, for matte painting the surface doesn't have to 100% perfectly smooth. 3. Wash the body kit again, dry it and do a IPA wipe down. 4. Apply an adhesion promoter to the body kit. 5. Get some matte black spray paint and paint the color layers from light sprays to heavier sprays, with 15-20 mins between each layer. The technique is to progressively do more as the layers builds up. I would suggest at least 5 and probably good withe max of 10 coats. 6. Take your time! Seriously, there is no hurry even if your life is depended on getting the body kit painted... 7. After you feel like you got enough paint layers on there, nice and even, then apply a matte sealer to seal the whole deal up. Waterproofing it and protecting the all the hard work you put in. 8. If you can, it is best to leave the body kits to cure over a course of at least 24hrs before any polishing or removal of paint. |
| The Following User Says Thank You to OoLong For This Useful Post: | sklimo (03-07-2014) |
#223 | |
Damn I'm glad I placed my order Monday!!! Fedex tracking says will be here next Wednesday
#224 |
Drives: 2013 WRB BRZ Sport Tech
whats the quality like of the sti badges that come with this kit??
http://www.ebay.com/itm/12-14-BRZ-tS...ht_2330wt_1219 wondering if i should order a set seperately or if these ones are good enough. if they are crap anyone know where i could get a set cheap?? |
| STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] | JPxM0Dz | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 12-03-2013 10:57 PM |
| CS Style Polyurethane Side Skirts | Jive Turkey | Exterior Parts (Aero, Lighting, Etc.) | 14 | 11-04-2013 09:49 PM |
| WTB CHARGESPEED STYLE SIDE SKIRTS. | bahanii | Want-To-Buy Requests | 1 | 10-18-2013 02:06 PM |
| FS: CS Style Side Skirts and Rear Spats | FRS2000 | Exterior Parts (Aero, Lighting, Etc.) | 4 | 09-23-2013 12:15 PM |
| 2013 SUBARU BRZ J STYLE PU SIDE SKIRTS | JPxM0Dz | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 05-10-2013 11:29 AM |
