#211 |
Drives: 2015 blue series blue
here is my 2500 - 7500 rpm pull.........OFT UEL stage 2 93 octane
any advice is great as I have no idea what is supposed to be going on here http://www.datazap.me/u/bandit0289/l...7-8-9-10-11-12 |
#212 | |
Drives: 14 Ultramarine FR-S
In your WOT pull everything looks to be normal. I think that if you had a leak you would be seeing higher AFRs (>14.7) which would indicate a lean condition thus you would be seeing high positive LTFT during heavy acceleration. The ECU would be dumping extra fuel in to compensate for the lack of air, trying to correct the AFR.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#213 | |
You should log FLKC, Knock Corr. as well this will determine if your ECU is pulling timing & correcting knock conditions.
#214 |
here is the new 3rd gear pull with knock correction and flke included
http://www.datazap.me/u/bandit0289/l...=0-1-2-9-13-14 |
#215 | |
Drives: JAWS
You also have similar high LT fuel trims at light throttle/low rpm like I do with the stage 2 uel tune, how many miles have you driven on the tune so far before doing that log? |
#216 |
@JB86'd
What brand of 91 are you running? If you're running a 91 tune, something I've learned is that the higher your Ethanol percentage of the petrol the higher the fuel trims you'll see, particularly at idle/low loads. I found this out because when I was switching from E85 to 91 I seen insane LTFTs ~20% in some cases, once the ethanol percentage went down so did my fuel trims. I didn't research too much but most stations are E10-E15 I believe.
#217 | |
Drives: JAWS
I found that Shell is more knock resistant than the Chevron station near me, which could be due to higher E%...you may be on to something there. |
#218 | |
http://www.popularmechanics.com/cars...ence-13747431/ I'm currently running Chevron, I'll have to take a look at some pumps. I thought something got passed in CA where all gas is E15 not quiet sure though.
#219 | |
Official anti-BS squad
Drives: Toyota 86 High 6MT
I've finally managed to check mine out and guess what? 0.7 Not perfect but not nearly as bad as it was made out to be or am I misunderstanding?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#220 | |
86 Nut
Drives: 86 Satin 6MT High
#221 |
Thanks, so am I right in understanding that things are not nearly as bad as they were made out to be?
95RON SAV Tuned |
#222 | |
Drives: .
FYI, see attached. Stock logs, all different cars. Altitude would lessen the effects of the stock maps aggressiveness for our fuel, having said said, 0.7 is still in the upper regions of what we have seen at altitude. Driving style and conditions during the log will also play a big factor. Your findings go hand in hand with my theory about the higher than "normal" amount of engine problems being experienced at the coastal regions of SA compared to the highveld.
"Some will follow your footsteps, easier than they will your advice."
#223 |
Cool, so our engines are not about to blow up at altitude, that's at least good to know.
![]() BTW. My driving usually consists of lots of traffic then hard driving when it opens up.
95RON SAV Tuned |
#224 | |
but other logs I looked at from someone in SA cannot remember who did have Iam about 0.5 on petrol. It unlikely to blow up as ecu is managing knock and still has more ability to correct knock but will nobble power somewhat , I have seen stock cars in Austrlaia with similar IAM on 98 ron and they are still running. Even if the IAM was 0.1 it could still pull another 5 degrees FLKC i believe. |
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
