Old 08-02-2018, 02:52 PM   #211
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Originally Posted by nkobns View Post
Does anyone know if there are some drivers to make the cable work with win10 32bits ?
Thanks !
Not sure about 32bit but there is a hack for the W10 64bit. That’s what I’m running. Search online you will find it.
el-guapin is offline   Reply With Quote
Old 08-02-2018, 03:09 PM   #212
misterfly
Drives: Toyota 86 2017
Thanks !
I have bought one cable with techstream 13 and it's work on win 10 64 and 32
misterfly is offline   Reply With Quote
Old 08-02-2018, 04:19 PM   #213
ermax
ermax's Avatar
Thanks !
Why do you need it to work on Win10-32? It's not hard to get it working in Win10-64. What cable do you have? I had a cheap Mini VCI cable and with some registry changes (moving some keys from \SOFTWARE to \SOFTWARE\WOW6432Node) it worked fine on Win10-64. Now I have a Tactrix and the installer for it's drivers put the registry entries in the correct place so you don't have to mess around to get it to work.
Old 09-12-2018, 03:41 AM   #214
kiki2015
Drives: cool
Hello, where did you buy from? You mean VXDIAG NANO Toyota interface?
kiki2015 is offline   Reply With Quote
Old 03-07-2019, 05:03 PM   #215
misterfly
I bought it on amazon .com
it's a generic cable
Old 03-13-2019, 12:09 PM   #216
Gunman
Drives: 2019 Mazda Miata RF
Is this the latest version "available"? looking to pick up a cable soon.
Gunman is offline   Reply With Quote
Old 03-13-2019, 12:19 PM   #217
ermax
ermax's Avatar
13.30.018 is the latest
The Following User Says Thank You to ermax For This Useful Post:
Gunman (03-13-2019)
Old 03-13-2019, 04:16 PM   #218
Gunman
So, what's a good cable, since they are all clearly knockoffs from china?
Old 03-13-2019, 04:47 PM   #219
ermax
ermax's Avatar
I got a cheap one for $18 and it worked but later got a Tactrix because I wanted to be able to flash. If I did it all over I would skip right over the cheap one and go directly for a Tactrix.
https://www.tactrix.com/index.php?op...ed=1&Itemid=53
Gunman (03-13-2019)
Old 03-19-2019, 12:18 AM   #220
durtdonthurt
Drives: White series.blue / CWP tS
I need some help....I am trying to get this to work on my 2018 BRZ and I have tried installing version 13.00.022 on both my windows 10 x64 and windows 7 x64 using this method and continue to get the error code: "unable to connect to VIM"
I am using this cable and it is firmware ver. 1.4.1. When I run the Xhorse firmware update tool, I get the status as "connected"
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When you say "moving some keys from \SOFTWARE to \SOFTWARE\WOW6432Node) it worked fine on Win10-64" What exactly are you doing with this? I made sure the registry file matched the one that was in the guide I was following, added it to the desktop and "merged" it successfully.
Thanks!!
durtdonthurt is offline   Reply With Quote
Old 03-25-2019, 12:48 PM   #221
ermax
ermax's Avatar
14.00.019 is the latest now.
You can always see what the latest version is by going here:
https://techinfo.toyota.com/techInfo..._features.html
Old 07-15-2019, 11:40 PM   #222
xkenx1995
Drives: 2013 Subaru BRZ
Any mirror links for the drivers and software? It seems dead.
xkenx1995 is offline   Reply With Quote
Old 09-08-2022, 09:13 PM   #223
Windycity
Drives: 2013 Scion frs
I have an ECU that has no VIN associated to it. I bought a tune from Delicious Tune and now I can't use it because the car has no VIN in the ECU.. Can I use Techstream to put a VIN on the ECU??
Windycity is offline   Reply With Quote
Old 07-08-2023, 03:08 PM   #224
HotRodPA
My old Delicious tune had no vin attached to it, so I'm having this exact issue, how did you resolve it?
HotRodPA is offline   Reply With Quote
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 01:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
