#211 | |
Drives: 2013 Whiteout FRS
#212 |
Drives: 2013 Subaru BRZ Limited SWP
Got these last week. 245/40 tires.
#213 |
Drives: 6MT Hot Lava
235 potenza re-11 with 17x9 +45 rpf1 rub on full lock for me. only notice this usually in parking lots. its not terrible but you can feel it
#214 | |
Drives: 13' AVO Whiteout
The rear has 3mm spacers btw. Stock, springs or coils? Last edited by bryan767; 04-18-2015 at 08:12 PM. |
#215 |
#216 | |
Don't go +45 on springs/stock suspension. Only coils won't rub a +45
Pros drop 1" all around. This is +45 with a 10mm spacer, stock suspension. Quote:
#217 |
#218 |
So I'll be picking up a set of rpf1's with these specs and I plan to do a 245/40 tire lowered on ST coils. Should I expect any clearance issues ?
#219 | |
I would say no. As I am running stock suspension with 245/40 and the tire just grazes the perch. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to BoxRZ_86 For This Useful Post: | Ripp91 (04-24-2015) |
#220 |
Do you guys think if I ran a 3mm spacer with these just to get them to get a bit more flush when lowered would be unsafe. Or should I just stick to running just the wheels without spacers ?
#221 | |
Mine were touching the spring perch on eibach pro springs. Since I went with coilovers I have 0 need for any spacers, however I am running a 3mm spacer in the rear just because I like the look. ![]() ![]()
| The Following 4 Users Say Thank You to bryan767 For This Useful Post: |
#222 |
So I picked up a set In 17x9+45 With 245/45 Tires On Them With A Decent Amount Of Life Left. But I'm undecided if I wanna keep these tires or not
Coils will be going in tomorrow too to get rid of the wheel gap ![]()
| The Following User Says Thank You to Ripp91 For This Useful Post: | BoxRZ_86 (05-05-2015) |
#223 |
Well here's my contribution to this thread finally.
17x9+45 On Nitto NT555 255/40/17
#224 |
Wheel Directory: Enkei RPF1 17x9.0 +45
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 801 | 06-18-2024 06:31 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
| Wheel Directory: Enkei Kojin 17x9.0 +45 | Clipdat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-02-2016 04:18 PM |
