Old 03-27-2012, 01:36 AM   #211
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by FT-86 View Post
Sorry for my ignorance as I have never bought any TRD kit (or any aftermarket parts) before but I am liking the TRD kit a lot.
My questions is whether it would be better to get the car now and add the kit later or wait til the kits are out and get them then?
Will the dealer take into consideration that since I will not be using the stock parts (i.e. wheels, seats and etc), the prices for the kits will be lower compared to the later add-ons?
Your input will be very much appreciated.
it will be more expensive in the long run paying them to put on the parts to keep warranty
so buy all at once
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 04-09-2012, 12:23 PM   #212
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Anybody know if i can fit 17 inch wheels with the upgraded brakes??
track_warrior is offline   Reply With Quote
Old 04-10-2012, 05:30 PM   #213
trackmagic
Drives: 1994 BMW 318i
I didn't see this question asked...Is the diffuser a functional aerodynamic part or just bumper art?
trackmagic is offline   Reply With Quote
Old 04-17-2012, 11:31 AM   #214
StuttterButtter
Yes i have a stutter
StuttterButtter's Avatar
Drives: 94 Acura Integra
Only thing i don't like on the TRD kit is the front something i just done like about it. Think im leaning more towards the 5axis kit but i like the back of the TRD better. Most likely ill go with what ever 1 is cheaper
StuttterButtter is offline   Reply With Quote
Old 04-20-2012, 12:07 PM   #215
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
A diffuser is designed to smooth out airflow under the car giving it less drag. As with all performance parts, some are more effective than others.
Old 04-20-2012, 02:00 PM   #216
trackmagic
I am aware of what a diffuser is designed to do. However, most street cars with a "diffuser" is just a few ribs added onto the bumper to look cool. If a diffuser has an angle that a laminar airflow cannot stick to (~>20°) then the "diffuser" does nothing other than make kids think they are driving a race car.
A real diffuser is a large panel that would extend from the bumper about up to the rear axle. This is becuase of the gentle slope required to make it function and because the larger surface area will generate more downforce (Force=Pressure * Area)
Also one more thing: The airflow entering the diffuser should not be turbulant either. The turbulent air will not give the same "suction" effect because turbulent air fills the void left by the diffuser easier and therefore does not generate as much downforce. This is why most race cars will have a smooth undertray before the air even gets to the diffuser. The airflow should be laminar when it enters the diffuser.
This is why I asked if it functional or bumper art. I imagine it is the latter, but it would be cool if it was functional since some people want to use the FRS as a track car.
example:
diffuser
Old 04-20-2012, 02:03 PM   #217
trackmagic
Looking at the pictures again I'm pretty sure it is not real. The big picture that you can see it is kind of blurry though so I could not tell.
Old 04-21-2012, 04:54 PM   #218
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
are you guys arguing about 300 crank or wheel hp?
has anyone found out what door stabilizers do?
Old 04-21-2012, 09:27 PM   #219
DeepHunta
Drives: '05 Outback Wgn, '05 Lotus Elise
"push to start" option! I'm sold! So long as scion gets this, I'm switching from a BRZ to FR-S!
DeepHunta is offline   Reply With Quote
Old 04-21-2012, 09:29 PM   #220
Ikaros
Solar wind surfer
Ikaros's Avatar
Drives: 2013 FRS
Where are you seeing push to start? All I'm seeing is push start switch from that list.
Ikaros is offline   Reply With Quote
Old 04-21-2012, 11:56 PM   #221
HotLavaMann
First 86 member
Drives: FRS, Tacoma, Honda CB1100
They eliminate flex between the door and the frame. This makes the door rigid relative to the rest of the car and helps to reduce overall flex through the whole car. That is the theory. Supposedly they work quite well.
I've seen videos of cars (Genesis Coupe FWIW) on the track where the camera was behind the car door looking forward and the gap between the door and the body varies as the car slaloms through turns.
Not clear if Scion is going to bring this particular piece of equipment to the US. It may have something to do with crash tests or something, don't know.
HotLavaMann is offline   Reply With Quote
Old 04-22-2012, 12:44 AM   #222
DeepHunta
Isn't that the same thing? I mean the current special edition Scion TC has the same option of "push start switch" and it is exactly the "Push to Start" button idea.
Old 04-22-2012, 10:59 AM   #223
Ikaros
Solar wind surfer
Ikaros's Avatar
Drives: 2013 FRS
That's like saying if you go and buy a light switch and install it on the wall, a light bulb will magically appear out of nowhere. This is just a switch, it doesn't include any wiring, or the actual push button start system
The tC RS 7's website says it has "Push Button Start" not just "Push start switch" If you had done some you would have seen that the first thing that pops up on a google search when you search "TRD Push start switch" you would see that it's just a switch, and you can buy one to replaces the original push start switch.
Old 04-22-2012, 04:19 PM   #224
DeepHunta
Well darn! I guess I just got skooled! Looks like I'm sticking with my BRZ Limited pre-order.
trd 86, trd fr-s, trd frs, trd scion fr-s
Scion FR-S OFFICIALLY REVEALED (Details, Specs + Live and Press Photos) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 857 05-30-2012 03:57 PM
Cusco Parts Announced JSC Speed Scion FR-S / Toyota 86 GT86 General Forum 46 04-13-2012 04:13 PM
UK Price officially announced!!! DkHachiroku Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2012 08:13 AM
Tom's parts announced for 86 Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 36 02-04-2012 05:21 AM
Lexus IS-F parts wish list aspera Engine, Exhaust, Transmission 21 08-18-2011 01:59 PM
