Old 01-30-2014, 01:04 AM   #211
eromsdal
ERO
eromsdal's Avatar
Drives: '16 Subaru BRZ Series Hyperblue T
Can you use a stock shift knob with the KartBoy Short Shifter?
eromsdal is offline   Reply With Quote
Old 01-30-2014, 01:15 AM   #212
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Of course. KB didn't change the thread pattern from OEM.
^GT5 Replay Photo Mode^
Old 02-01-2014, 04:59 PM   #213
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
Installed!!!
Originally Posted by G_Rossney View Post
I noticed your re-assembly didn't show putting the shift cushion back on the car. Was there a reason for that?
This was an excellent write up! I like the images that show the actual differences in Shift throw.
So there are a few differences with the BRZ limited. For instance, the push start makes it a little harder. I found removing the trim around the shifter allowed me to get better access to the panel and push it out. Also, you have the seat warmer buttons to disconnect.
All in all, pretty straight forward. I didn't think removing the dust cover was all that hard, until I realized I tore it when I was putting it back on :-(
I have the Mtech springs to install and when I do that I'm going to change the transmission and differential oil to Motul. I'm curious how those changes will affect the feel.
Overall, I like the shorter shift lengths. I have yet to give it a real test drive, but that will be after a shower.
Great write up.
G_Rossney is offline   Reply With Quote
The Following User Says Thank You to G_Rossney For This Useful Post:
SirBrass (02-01-2014)
Old 02-14-2014, 01:42 PM   #214
coolaron
Those of you who installed Kartboy short shifter kit, are you guys having same concern like I do?
The reverse is pretty tough to put in than stock. The lock-out itself feels like it it uses much stronger spring..
coolaron is offline   Reply With Quote
Old 02-14-2014, 02:04 PM   #215
SirBrass
SirBrass's Avatar
Nope, no problems getting into reverse here. The feel going into the gate in all gears is certainly firmer, but none of them are HARD to get into.
Old 02-15-2014, 11:37 PM   #216
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
I'm not sure if it was the grease I put, but it seemed very stiff at first. But now, about one month later I am so happy. In the back of my head I feel that someone changed it back to the stock shifter when I wasn't looking. That is how comfortable I feel with it now. It is so easy to shift. The only thing different feeling from the stock as far as force needed to shift is pulling up on the reverse lockout. It is hard in a good way. Stopped me from playing with it when I am driving.
DrDuquette is offline   Reply With Quote
The Following User Says Thank You to DrDuquette For This Useful Post:
SirBrass (02-16-2014)
Old 02-16-2014, 04:46 PM   #217
bama_brz
bama_brz's Avatar
Drives: '14 SWP BRZ
Did this install in 45 mins. without any tears thanks to this DIY tutorial. I've got the BRZ with push-button start but these instructions work as it's the same 6 tabs that keep it in place as in the pictures. Best investments for this install: telescoping magnet, panel removal tool, and paper towels/rags.
bama_brz is offline   Reply With Quote
Old 02-16-2014, 09:54 PM   #218
SirBrass
SirBrass's Avatar
Got the rear bushing installed yesterday. Removing the old bushing was easy. Putting in the new one was decidedly not. Required help, as I didn't want to remove the FP or driveshaft, & thus replacement meant working around those two pieces. It was doable, but a pain in the shoulder blades , ass, and elbows (I've got interesting bruises in all of those places from having been laying flat on concrete for several hours straight yesterday putting in the rear bushing, transmission mount bushing, and Mtec springs).
It was worth it, though. Shifting feel is much more precise.
I'm on my phone so if I make mistakes, blame Sportsguy83
Old 02-17-2014, 09:47 AM   #219
Cridland
Cridland's Avatar
Drives: 2013 Whiteout FRS
for people with the kartboy installed, can you put a reverse lockout on the kartboy ss?
Cridland is offline   Reply With Quote
Old 02-17-2014, 11:04 PM   #220
Venator
Venator's Avatar
Drives: Asphalt FR-S
KartBoy Short Shifter DIY and Review
Does the rattle mean I put something on wrong?? What is the cause of the rattle? Also how do I know if it's in backwards?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
Old 02-18-2014, 04:08 AM   #221
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
i got mine ! can't wait to install it lol
sweetfrs is offline   Reply With Quote
Old 02-20-2014, 04:27 PM   #222
RSConsulting
Drives: 14 BRZLtd 6MT-12 Pilot EX-L
Thanks for the good DIY.
Should add - if you USE HEMOSTATS (aka: ROACHCLIPS) for the clip - you stand a better chance of not crawling around under the car to look for it (more than once - ask me how I know).
LOL…
Good writeup…
Rick
2014 BRZ - Dark Metallic Grey
Innovate Supercharger - Invidia Q300 Cat-Back - AIRRAID Intake
RSConsulting is offline   Reply With Quote
Old 03-05-2014, 07:17 PM   #223
GH05T
Undercover Batman
GH05T's Avatar
Can the reverse lockout for the kartboy shifter be removed? I have a beatrush reverse lockout ring that i want to install.
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
GH05T is offline   Reply With Quote
Old 03-06-2014, 11:14 AM   #224
SirBrass
SirBrass's Avatar
I'd really like to know the answer to this as well. I don't think it can be, but I don't know.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
STI Short Shifter Kit Hanakuso Engine, Exhaust, Transmission 37 01-18-2016 08:19 PM
Kartboy Short Throw Shifter!! RallySport Direct Transmission and Driveline 16 04-18-2013 01:18 PM
Kartboy Short Throw Shifter!! RallySport Direct Announcements, Contests, Giveaways 34 03-18-2013 02:18 PM
