Old 06-14-2013, 11:29 AM   #211
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
Robi,
As I anxiously await the replacement inserts for the top hats, I was looking at the inserts that came with the top hats, and a couple of questions came to mind. What is the orientation of the inserts? Is the lip on the bottom or the top. Also, do I reuse the brass washer that came with the Ground Control top hats under the nut, or do I need a specially sized washer. All my kit had was the top hats and inserts so I am just trying ensure I am installing them correctly.
MotoEast ECUTEK tune; PPE Engineering intake, EL headers, overpipe, front pipe w/ hi-flow cat, midpipe, and single exit axle-back; GC camber plates; GC coilovers with Koni Sport (r) and Koni 8612 (f); Eibach front springs and Hypercoil rear springs; Hotchkis rear sway bar; Eibach front sway bar; Whiteline positive traction sub-frame inserts and differential support outrigger bushings; 17x9 Enkei RPF1 w/ 245 Hankooks.
Evil86 is offline   Reply With Quote
Old 06-20-2013, 01:16 AM   #212
robispec
Drives: Black frs project
RADITOR updated and READY FOR SALE
robispec is offline   Reply With Quote
Old 06-25-2013, 09:50 PM   #213
FAER
Drives: Silver BRZ
Originally Posted by robispec View Post
SO here are some NEW picts and info on our SUPER HEAVY DUTY COOLING UPGRADE READY TO SHIP TODAY
At Robispec we are fans of extra credit work and so we went to an "overkill cooling solution" stock radiator is 15mm core we replace this with 2 22mm tube core add a liquid to liquid oil cooler in the "cold side tank" and have less than 2.5 feet of total lines to complete the whole "kit".
The best thing about this is that you dont need to thermostaticly control the oil temp (a big potential problem with the Air to liquid cooler solutions) as the water thermostat does this for you and actually heats the oil faster during warm up then stabilizes it to run about 20-30 degrees hotter than the water temp. this is better in many ways than the current kits on the market.
1. lighter overall
2. short hose runs,minimal resistance to flow = no extra strain on the stock oil pump
3. "fixes" the Water cooling issues sure to develop with the stock radiator.
4. Uses existing cooling airflow and leaves fender locations for brake ducting
5. Uses all factory connections/hoses fits with bumper beam and all plastic parts
6. Works with VORTECH and almost all aftermarket intakes and the Stock air box (PM for fitment details)
Picts in the car
here are the cores for comparison. BIG PROBLEM and no oil cooler included with the car either.
Even the A/C condensed is thicker than the Stock radiator!(3/4" vs 5/8 ")
here is the BEST solution...to the above problem
system out of the car
NO cutting plastec to mount
Cold air or turbo/FMIC piping over the top as needed
STOCK mounting points used
OVER TRIPLE THE COOLING CAPACITY and an extra Qt of engine oil.
takes 2 hours to install Install is the same as Stock radiator install with the addition of the oil cooler fittings.
total system cost Radiator oilcooler takeoff plates hoses, an fittings, fans
EVERYTHING INCLUDED for John Q Public to install $985.00
Robi
Will you marry me?
FAER is offline   Reply With Quote
Old 06-25-2013, 10:35 PM   #214
robispec
let me see if my wife is ok with that ;-)
Old 06-26-2013, 10:03 PM   #215
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Could you post a direct link for ordering the radiator / oil cooler combo please
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 06-26-2013, 11:05 PM   #216
robispec
pm me for the details plz
Old 06-26-2013, 11:06 PM   #217
robispec
Originally Posted by JackSmiley View Post
How can we order a set?
pm me
Old 06-27-2013, 12:31 AM   #218
robispec
Current numbers with the innovate Super Charger with a 70mm pulley E85 fuel are
249.7/201 on a dyno dynamics conversion to a dyno jet would be 280/240 whp/wtq
charts later tonight..hell yes I'm HAPPY!
Old 06-27-2013, 01:41 AM   #219
DriftEm
DriftEm's Avatar
Current numbers with the innovate Super Charger with a 70mm pulley are
Is that pump gas? what numbers does stock car get on that dyno?
DriftEm is offline   Reply With Quote
Old 06-27-2013, 02:36 AM   #220
robispec
Yeah pump e85...
Old 06-27-2013, 04:14 AM   #221
robispec
final #s were 253/213.
Old 06-27-2013, 04:24 AM   #222
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You. DaMahn.
Old 06-27-2013, 01:53 PM   #223
robispec
graphs DYNO DYNAMICS dyno
75mm pulley vs 70mm pulley
This image has been resized. Click this bar to view the full image. The original image is sized 1440x676 and weights 200KB.
Stock car stock fuel vs 70&75 mm pulleys on E-85 fuel
This image has been resized. Click this bar to view the full image. The original image is sized 1440x676 and weights 213KB.
70mmand 75mm with BOOST
This image has been resized. Click this bar to view the full image. The original image is sized 1440x676 and weights 217KB.
Old 06-27-2013, 02:04 PM   #224
pics are broken
Canu_50's FR-S Time Attack, drift car!! canu_50 Member's Car Journals 28 12-05-2013 02:04 AM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
Ontario Time Attack - TMP July 7th 7thgear CANADA 8 07-07-2012 06:14 PM
Vancouver auto-cross, time attack.. ? EsoBOFH CANADA 4 06-20-2012 03:23 PM
Tsukuba time attack review in the Car Top magazine yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 05-18-2012 05:12 PM
