Old 03-28-2012, 02:10 PM   #211
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Originally Posted by Allch Chcar View Post
0-62. That's as high as I'll go.
Sorry I didn't clarify. 60-70 horsepower. The family sedans you generalize have 60-70 more hp than the FRS, not 100.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 03-28-2012, 04:11 PM   #212
Allch Chcar
Drives: N/A
OOh, okay. thanks.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 03-28-2012, 04:27 PM   #213
ahausheer
Re-member
Drives: Toyota camry
Originally Posted by SuqMadiq View Post
You couldn't be more wrong. For straight line performance torque is going to be the determining factor. HP is essentially torque measured over time. What you want for acceleration is torque. Let's recall high school physics days... F= MA, or Force = Mass * Acceleration. Now to solve for Acceleration we get A= F/M. Toque is a force measured in lb-ft.
So ultimately that leaves us with Acceleration = Force (torque) / Mass (of car). Now if you're wondering how HP and gearing are part of the equation. Well, HP measures the amount of power over time. So high HP will net high speeds as it is an extended period of torque to the wheels. The gearing is also very important because it derives how much force is actually being sent to the wheels. The reason a high revving engine is good, is because the car can maintain the high torque being applied to the wheels. So having a high revving engine will also help your acceleration.
I'm not wrong, apparently you didn't read the link I posted. Torque is what you feel, but Hp is what gets the job done. If you had two cars, all else being equal, and one had more Hp, the higher hp car will win in a drag race, but at max torque each will ''pull'' just as hard. To oversimplify, torque is instantaneous acceleration, merely the potential to actually move something, Hp is what determines how long that torque can move something. You can have a lot of torque, but if it is not moving anything no work is being done by the object. F=MA, when you stand on a scale you are not moving but you apply your potential to move (the force of gravity) to A. Force does not imply motion. F=MA even for a stationary object. Torque measures a force with the potential to actually move something, Hp measures how much actual movement is being done.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 03-28-2012, 05:44 PM   #214
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by ahausheer View Post
Not really. The S2000 weighs about 2,800 lbs, has about 155 ft/lbs of torque and it will get to 60 faster than the BRZ and the GTI. I think its more a function of gearing, tires, manual shift times and Hp.
Read this, http://www.vettenet.org/torquehp.html check the Corvette comparisons. You want Hp, not torque to win a race.
An S2000 is only like .2 seconds quicker than a GTI and it should've been even better than that by like 1 whole second but it isn't. Let's see here.
240hp in a 2750 lb RWD roadster
vs
200hp in a 3200 lb FWD coupe
You would think that with the extra 400+ lbs and 40 hp disadvantage paired with FWD traction that the GTI should be at least 1 second slower but it's not.
http://www.motortrend.com/roadtests/...0/viewall.html
http://www.motortrend.com/roadtests/...t/viewall.html
Sometimes power 2 weight ratio is overrun by other things.
Also I like this little quote from the S2000 in MT.
The S2000 numbers came after launching at 8000 rpm (producing little tire spin) and shifting at 8300. On one run, we launched and shifted at 5500; the 0-60 time rose to more than 11 seconds. Herein lies the car's biggest problem: Most people will never drive in the best rpm range (7000 to 8500), shifting too early. Our advice is to treat the S2000 like you hate it and you'll get the most out of it. We did and loved every minute of it.
SUB-FT86 is offline   Reply With Quote
Old 03-28-2012, 08:01 PM   #215
catharsis
Drives: honda civic si 08
vs
You can't go by crank HP. GTI's are underrated from the factory and are FWD so there is less drive train loss. I'd also like to point out that s2k's are 2800 something pounds not 2700. Anyways the s2k has more drive train loss being that its rwd. Put them bought on a dyno, and then weigh them. Crunch the numbers, and you'll see the s2k has the power to weight advantage and does indeed out accelerate the gti. power to weight never lies, except when its an issue of applying the power.
catharsis is offline   Reply With Quote
Old 03-28-2012, 08:30 PM   #216
serialk11r
Drives: '06 AM V8V Coupe
The reason the GTI is fast is it has a turbo that makes a lot of low end torque but dies off at high rpm. Thus it has more horsepower available at low speed. NA cars have crappy looking 0-60 because they make approximately constant torque, and this means in first gear they are only putting down an average of about half their maximum power.
Old 03-28-2012, 09:14 PM   #217
SUB-FT86
86 Member
EXACTLY!!!!
Old 03-28-2012, 09:41 PM   #218
ahausheer
Re-member
^Ow my digital ears are ringing, stop yelling so loud
Old 03-28-2012, 09:57 PM   #219
OrbitalEllipses
Drives: Attitude
Originally Posted by jor8888 View Post
sooo the GTI with same HP and heavier is faster? the Japanese are falling behind.
Old 03-29-2012, 07:29 AM   #220
Levi
Drives: Toyota
How do so many dare compare the S2000 to a GTI ?
GTI<---------------------------------------------------------------------------<S2000
Levi is offline   Reply With Quote
Old 03-29-2012, 08:43 AM   #221
SUB-FT86
86 Member
Because you failed to see what the comparison was about. I feel a lot of people just see the words "GTI" and "S2000" and assume that people are saying that they are rivals. We are talking about Power 2 Weight ratio and how sometimes it doesn't add up to a much better acceleration as expected. Nobody is talking about handling or feel here we all know which is the champ at that.
Old 03-30-2012, 02:51 PM   #222
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
[u2b]0QZLlFLUh98[/u2b]
i used a stop watch, started it when the car started moving, stopped it when he chirped tires going into third
got 6.5 with that horrible launch, 5.9 is possible, hes a good driver though when it came to the cones
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 03-31-2012, 09:24 AM   #223
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
{snip}
Originally Posted by Scion FR-S View Post
^ I 'm neither engineer nor physicist but even with mostly-forgotten high school physics something smells oversimplified or just plain wrong with that statement, simply on the basis of dyno charts.
Lots of cars have near-flat torque curves these days. So keeping things simple, if you have a CVT car with a flat torque curve, according to your explanation it would never have to rev faster than say 2000 rpm where the torque curve levels off since reving any higher would provide no additional torque. But of course we all know that is not what happens in practice - stomp on the gas in a CVT'd car and the revs shoot up and stay there until you ease off the gas. That obviously is necessary to get more power to the wheels or the engine would not be programmed to do that (it burns gas more quickly in that state) so torque alone is not the explanation for acceleration. Something about horsepower's (force X distance)/time must come into play here making hp important.
Can anyone offer a more complete understanding? Wikipedia on horsepower was not directly on point.
Power is the determining factor:
http://www.ft86club.com/forums/showthread.php?p=129241 (see item #3)
http://www.ft86club.com/forums/showthread.php?p=129439 (bicycle comparison)
http://www.ft86club.com/forums/showthread.php?p=78781 (wheel torque examples)
http://www.ft86club.com/forums/showthread.php?p=78973 (math)
Engine torque is also relevant because you don't always drive around at peak power, and you can't make high power at low/medium engine speeds without high engine torque.
Part of the confusion might stem from some people using the general term torque when describing engine torque while others use it when describing wheel torque (and not everyone understands the difference).
Deslock is offline   Reply With Quote
Old 03-31-2012, 10:03 AM   #224
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
^ Big thanks for this! Will be an interesting read.
Sport-Tech is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 02:02 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 05:07 PM
Forget the NA vs Turbo debate!!!! Midship Runabout Engine, Exhaust, Transmission 69 04-05-2011 06:24 PM
AE86 handling video... Blokatos FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 02-07-2010 05:20 AM
