#211 | |
Drives: Some rust bucket
http://www.roadandtrack.com/go/news/...a-racing-japan |
#212 | |
#213 | |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
Anything else you want to know please PM me so we don't keep clogging up this oil cooler thread with gauge stuff. I'll be happy to answer. |
#214 | |
Drives: 2013 SWP BRZ
So no, sorry, I don't see that as solid evidence at all. 260* is some arbitrary number that no one can tell me why this is the max safe temp. I understand cooler is better, but I have no reason to throw on an oil cooler if the engine was designed to be capable of handling 290-300*f for 30 minute sessions without issue, like many other factory cars are capable of. I can't imagine Subaru didn't think of taking the car out to the track to get some stock sensor readings before they put it into production. |
#215 |
Drives: Black frs project
I did I did!!
and I think the oil running the cams is the cuprate as the ECUTECK logs all show preset setings but the total load trace is dropping when the oil temp trace crosses the 230 mark...(even when you defeat the temp sensor. ecu input...lol |
#216 | |
2013 Subaru BRZ
#217 |
#218 |
Drives: FRS
We only have one data point on this topic and it was provided by Perrin. They provided this data before their oil cooler came to the market..... I actually believe it was this dyno generated data that provoked them to make an oil cooler in the first place.
So you guys are saying we need to go by the data and not speculation and assumption, yet you ignore the one data point we have..... That makes a ton of sense....
#219 | |
#220 | |
#221 |
Site Moderator
Drives: Stuff
Actually I wouldn't be surprised at the ECU pulling timing based on various parameters, including oil temp. That should be easy to find in the ECU for those who can look. Oil temps most likely aren't the only thing increasing so I agree with the others that it's difficult to make that direct correlation as the sole cause of timing being pulled, etc.
This wouldn't be the first car to pull timing based on coolant and oil temp sensors though, assuming that's all the car does is just pull timing. I haz no idea. Either way I just prefer my oil to run cooler and pull heat out of the rest of the components in the engine.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#222 | |
Drives: FRS
#223 |
#224 |
my prob is the question WHY isnt that important to me. We just developed a system that never lets the parameter get to a point to cause the loss in power.
http://www.ft86club.com/forums/showt...35#post1013035 or http://www.ft86club.com/forums/showt...13#post1023713 |
| Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
| ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
| One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 05:42 PM |
| Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 09:48 AM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 12:55 AM |
