#211 |
Drives: 2013 Scion Frs(Scarlet)
I had almost a full take of gas in the car and i also dropped my speed a couple of mph below 60 before flooring it. the floor was just a little wet so it cud have affected the run
#212 |
Drives: BRZ Limited
Using some of the information I have gleaned from other posts I have come up with what looks like a very accurate reading of how much fuel is in the tank. It seems to be much more accurate than the default fuel percentage that is in Torque.
Torque PID setup for accurate fuel remaining. PID: 2129 Long name: Fuel Remain (or whatever you want) Short name: Fuel Remain (or whatever you want) Minimum Value: 0.0 Maximum Value: 100.0 scale: x1 Unit: Gal Equation: ((A*13.2)/100) OBD Header: 7c0 The 0 in 7c0 is a zero not the letter O. |
#213 | |
Drives: BRZ Limited
Unit: L Equation: ((A*50)/100) |
#214 |
Drives: Raven FR-S 6MT
Should I be monitoring AFR (commended) or AFR (measured)?
The Following User Says Thank You to so26 For This Useful Post: | lazyluka (02-18-2013) |
#216 | |
Drives: 2011 Porsche Cayman S
#217 |
Drives: Ultramarine FR-S 6MT
Is there a sensor for transmission oil temp?
#218 |
#219 |
Drives: 13 White MT FR-S
I haven't noticed but is there a oil pressure sensor available?
#220 |
Only for no pressure.
Sent from my SCH-I535 using Tapatalk 2 |
#221 |
#222 |
Drives: Hot Lava FR-S
No problem. PM me and I'll help you through the process I went through to find it.
#223 |
Site Moderator
Drives: Stuff
Since this seems better than any current IOS setup what's the cheapest way to get into a Android device that will support/run Torque? An old beat up phone? Cheap tablet? Just needs bluetooth and I'd guess some min food-related OS or whatever?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#224 | |
SLO NO MO
Plenty of cheap options out there, but you can't go wrong with the Google Nexus 7 @ $199. |
Tags |
android, app, boost, gauges, torque |
Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 04:53 PM |
Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-22-2012 11:05 PM |
Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 04:14 PM |
Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 01:15 PM |
Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 08:23 PM |
