Old 02-06-2020, 03:32 PM   #211
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by DustinS View Post
Pretty sure that is a crash sensor. Most of the time airbag/crash sensor stuff is denoted by the yellow plugs. I could be wrong. But I made sure to keep the bracket it was attached to as I didn't want to mess with how the sensor read or anything.
Thanks
Seeing as my airbags are removed, I could remove these then
SuperTom is offline   Reply With Quote
Old 02-06-2020, 09:31 PM   #212
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by SuperTom View Post
Thanks
Looking good. They are the airbag sensors.
What about the resonator on your airbox?
Old 02-06-2020, 09:44 PM   #213
SuperTom
SuperTom's Avatar
There are some reports that there were some HP loss removing that resonator due to messing with some of the frequencies.
I did order the Injen Evolution intake (taking a while to ship but I got it at a much lower price). Im not expecting 15hp like advertised but I think its the closest to the Gruppe-m style with a straight shot to throttle body for a fraction of the cost. Main difference is it only pulls in air from one side instead of 2 like the Gruppe-m. So the stock style setup will be gone soon
https://injen.com/i-30497562-injen-e...m-evo2000.html
Old 02-06-2020, 09:52 PM   #214
new2subaru
Weight Weenie
Drives: 15 FR-S
It should be a nice addition.
Could be, I have mine off and didn't notice a loss in power. Maybe my high flow air filter evened it out
Old 02-07-2020, 11:19 AM   #215
fika84
fika84's Avatar
Thanks
They are definitely airbag sensors I think there's 5 or so (could be 6) on the car.
I pulled all of mine out when I pulled the airbags and airbag module.
fika84 is offline   Reply With Quote
Old 02-07-2020, 01:41 PM   #216
SuperTom
SuperTom's Avatar
Yeah im gonna wait until I pull the dash then remove all the airbag Wiring & module!
Plus there was some extra wiring upfront there for fog lights as well.
Should be good for a few pounds of copper out
Old 02-08-2020, 04:01 PM   #217
SuperTom
SuperTom's Avatar
Lighter Rear Brake Kit
Finally got around to this, my Lightweight Rear Brake kit
So what is involved in this kit:
-Rear Subaru 2-pot conversion (Refurb Calipers from Rock Auto), Torque Solutions adapter
-Metal Bar from home depot for pad spacers
-Single Vane Rotors from "base" gt86 overseas. $35 on ebay
I recall an old post with Robispec claiming 3lb lighter per side with the Subaru 2pot. Counting in the adapter I only got 1lb lighter per side fully loaded.
a little over 5.5 lbs for the 2pots + adapter
+ spacers added .25 lbs. Only showing 4 here I ended up using 6
Stock loaded Caliper 6.75 lbs
Single Vane Rotor 11.25lbs
Stock Rotor 13.25lbs
Had to do a little grinding to get it on better but really on a small 1mm casting was removed
Adapters Bolted on
I used this stuff sandwiched between each backing pad to keep them from vibrating against each other
So I used 3 plates on the front side, no plates on the back side. Although I will probably make a 1/16" thin plate for the back side so far it hasn't been necessary
Looking Good !
Haven't done any crazy 100-0 stops but bedding in and driving around no issues or noises so far. Stops like it normally did
If this has issues I can just put the stock rear rotor in and keep my 2pot setup
So what was the point of this? To get lighter of course!
So you lose 2lbs in the rear from the 2pots, and 4lbs of rotation mass from the rotors
6lbs Total!
New vehicle weight 2331.25 LBS
Old 02-08-2020, 07:25 PM   #218
WC-BRZ
Drives: Black BRZ
This thread always delivers...keep up the great work, SuperTom!
WC-BRZ is offline   Reply With Quote
Old 02-09-2020, 08:25 AM   #219
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
Thanks for all of the details.
I think ScoobySouth did a similar setup with the KNS adapters a few years ago.
Are the shims required? I know these 2 pot brakes were from the old WRX, and one model of the WRX had the solid rotors. I wasn't sure if the 2 pots would be fine without the shims.
Sent from my SM-G930P using Tapatalk
sifl is offline   Reply With Quote
Old 02-09-2020, 11:06 AM   #220
SuperTom
SuperTom's Avatar
If you use the stock frs/brz rear rotors then it should be a direct swap without any shims.
The single vane rotor im using is much thinner about 10mm thinner, don't know if the brake pistons have that much travel to not use shims
The best setup would be these calipers with stock size 2pc rotors. People say these exist but Ive yet to see them
Old 02-09-2020, 12:56 PM   #221
ML
ML's Avatar
Drives: 13 White MT FR-S
nice, do you have a link to those rotors?
Old 02-09-2020, 07:13 PM   #222
SuperTom
SuperTom's Avatar
These are the ones I got, Cheapest I could find for this experiment
https://www.ebay.com/itm/Rear-286-mm...72.m2749.l2649
Old 02-13-2020, 01:47 PM   #223
SuperTom
SuperTom's Avatar
Finally installed my swizz cheezed ebrake. Was waiting on my new ebrake handle to show up
So drilled down the ebrake to save .5 lb of it, new handle added .25lb back on.
While I had everything apart was able to take over .25 off the brackets for the ebrake lines/ removed rear most bracket for center console not needed
Stock 3.1
swisscheesed with new heavier handle
Ebrake line brackets
One less bracket and material removal
Installed
Weight saved .5lbs total
New weight 2330.75 LBS
Old 02-13-2020, 02:46 PM   #224
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Have you considered 3D printing any items to save weight? I think you could skeletonize your e-brake with this technique without sacrificing any functional integrity.
Sent from my Pixel 2 using Tapatalk
ROFL it's Waffle is offline   Reply With Quote
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 05:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 01:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 07:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-01-2013 11:45 PM
